NEW Turbo Timer
Submitted: Sunday, Oct 28, 2007 at 17:07
KiwiAngler
Hi guys
Just had this new turbo timer fitted to my Nissan Patrol ST, replacing the previous one which was sitting above the steering column in front of gauges.
This unit is completely hidden and this is all you see
I reckon it looks pretty damn fine actually :-)) (but hey I AM a little biased :-))
Reply By: Member - Wayne B (QLD) - Sunday, Oct 28, 2007 at 17:08
impressive so how much and where from ?
Wayne
268773
Follow Up By: KiwiAngler - Sunday, Oct 28, 2007 at 17:11
Thanks - I was pretty chuffed too :-))
Cost was $140 plus post
from T-Rat off the Nissan
forum
531511
Follow Up By: KiwiAngler - Sunday, Oct 28, 2007 at 17:16
T-Rat contacts
0404875084 or
email williamhay@optushome.com.au
just notice T-Rat is NOT on the Nissan
forum but the 4WD Action
forum
531512
Reply By: Member - Doug T (Qld) - Sunday, Oct 28, 2007 at 17:18
KiwiAngler
Looks neat, I like it. Now I will have to fir a Turbo to my tired old Troopy so I can get one.....
268778
Reply By: Member - Smithy (VIC) - Sunday, Oct 28, 2007 at 17:20
what's it like to install, am looking to do the same
268779
Follow Up By: KiwiAngler - Sunday, Oct 28, 2007 at 18:57
Hard to say as I had it done when I was getting some other stuff done. They had the dash off to do the other stuff so I took opportunity to get this done at same time.
I am NOT practical so wouldnt attempt it on my own :-))))
Quote: " It is a wise man who knows his limitations"
531534
Follow Up By: Member - Graham H (QLD) - Monday, Oct 29, 2007 at 21:09
Have talked to him Its only 4 wires If I remember 1 is ign 1 is acc 1 is earth and one can go to handbrake switch
531824
Reply By: Member - shane (SA) - Sunday, Oct 28, 2007 at 17:22
where has the sub
tank switch been moved to?
268780
Follow Up By: KiwiAngler - Sunday, Oct 28, 2007 at 18:53
The sub
tank switch was always down below the CD/radio (see pic) so the new TT switch went into a blank spot
531532
Reply By: DIO - Sunday, Oct 28, 2007 at 19:10
A very neat installation, however, be mindful that in some Council areas and States it may be an offence to leave a vehicle unattended with the engine running. Just in case you weren't aware.
268793
Follow Up By: KiwiAngler - Sunday, Oct 28, 2007 at 19:21
I have had TT for a number of years so was aware
In fact my central locking is set up so that I cannot lock doors while TT is still on without it setting off the alarm
mind you this isnt the only thing that will set off my alarm - if Itry a selcall on channel 2 HF it sets it off even if it isnt on :-))))
So if you ever see a guy talking on his
HF radio with the siren going off - yep - it will be me :-))))
531539
Reply By: obee - Sunday, Oct 28, 2007 at 20:45
If I had to leave the engine running every time I stopped I would get rid of the turbo.
I have 3.0 turbo hilux and I only let the motor run if its been working hard. Normaly I get the chance to back off a few minutes before destination and the turbo slows down enough.
It probably has oil feeding the turbo after shut down anyway but I never checked on that.
Owen
268818
Follow Up By: Member - Graham H (QLD) - Monday, Oct 29, 2007 at 21:08
No it doesnt Turn it off the oil pump stops
Can boil what little oil is in therel if its toooooo hot as
531823
Reply By: Member - Dunworkin (WA) - Sunday, Oct 28, 2007 at 22:42
Hi KiwiAngler, on the dash behind the steering wheel in the pic there is a light on, to me it looks like the subtank light, am I right? If I am, and assuming that you are not emptying the sub
tank whilst you are taking that pic why is it on? or is it because you have an after market pump on therefore the switch on your patrol is in a different place to where ours is/was. Just wondering
D
268855
Follow Up By: KiwiAngler - Sunday, Oct 28, 2007 at 23:38
Whenever I disconnect te battery ( as was done to do some recent electrical work) when I reconnect the battery the sub
tank light is permanently lit.
To 'fix' it I have to re disconnect the battery,leave it for about 20 minutes and then reconnect. Allows time for the puter to reset itself I guess.
I havent got around to doing it yet :-))
531623
Follow Up By: Member - Dunworkin (WA) - Sunday, Oct 28, 2007 at 23:53
Aaah that would explain it, thanks for that I thought that you may have had an after market pump fitted.
D
531630
