Idler Pulley on 1HZ Diesel Siezed
Submitted: Sunday, Oct 28, 2007 at 20:48
ThreadID: 51020 Views:3284 Replies:3 FollowUps:3
The Idler Pulley on my 1HZ Diesel Seized today, can I just buy a new bearing to put in it or do I have to get the whole thing.
If any one out there could help it would be greatly appreciated.
Thanks in advance.
David
Reply By: Member - 120scruiser (NSW) - Sunday, Oct 28, 2007 at 21:00
I presume you are talking about the A/C idler pulley or the timing belt idler pulley???
If its the timing belt one you have to replace the whole lot. If its the A/C one you should be able to purchase a complete after market one. Some you can replace the bearing and some you can't.
AnswerID: 268824
Follow Up By: David - Monday, Oct 29, 2007 at 08:02
Hi 120scruiser,
You are right it is the A/C idler pulley,will pull apart and see what I have to do.
Thanks , David
FollowupID: 531653
Reply By: Get down &dirty - Sunday, Oct 28, 2007 at 21:02
Hi Dave,
Replaced mine the other day. Pull off the pulley and press the bearing out with a socket in the vice. Any bearing place will have one. Approx $8.
Cheers.
Col.
AnswerID: 268825
Follow Up By: David - Sunday, Oct 28, 2007 at 21:08
Thanks Col,
That's what l was after, thanks. David
FollowupID: 531569
Reply By: Ozboc - Monday, Oct 29, 2007 at 06:38
Had the same prob with my 4runner --- just remove it and have a look at it - it may have a welded plate so you can not access the bearing easily - If you are On the tools - removing the cover will be a simple process - and then just tack it back into place when BRG replacement has been done. BRG should not cost more than $10 - if its easily removed - then i suggest you buy a second one as idler brgs are always the first to go especially if you like muddy water
Boc
AnswerID: 268873
Follow Up By: David - Monday, Oct 29, 2007 at 07:58
Thanks Ozboc,
I am pulling it apart today and will see what l have to do?
It has done 405000 km, so it has done ok. I think it was the last mud hole that l got stuck in done the damage as you stated. I will get a spare as well as you never know about these thing as soon as you start replacing parts how long they will last.
Thanks, David
FollowupID: 531652
