help with camp kitchen
Submitted: Monday, Oct 29, 2007 at 21:39
garfield
Hi everyone, I wanna build a free-standing
camp kitchen and I'd like your help and advice.
I'd like to build it similar to the drifta
camp kitchen more or less.
I was wondering whether anyone has a design of one they have - or are going to build they'd like to share with me.
Thanks in advance people.
Geoff
Reply By: PradOz - Monday, Oct 29, 2007 at 21:54
i think i have seen some new ones advertised for sale somewhere recently. not sure where though?? it may have been in a 4wd or caravan magazine, or otherwise on ebay.
good luck, sorry for being so vague
269016
Reply By: mfewster - Tuesday, Oct 30, 2007 at 08:24
I built a unit to go into the swing out door on a camper trailer, not freestanding, but same principles could apply. I cut down on the weight and joinery problems by making a frame of aluminium, QBlock, I think it is called,with a number of compartments. Just joins up by tapping plastic corners where you want them. I designed it around plastic drawer units from Bunnings and this saved lots of construction time, joinery and weight. Covered the whole thing, except for drawer fronts of course, with plywood which was bolted onto the QB using light bolts. This also added rigidity to the whole structure. Then painted with marine grade estapol. There is a panel which slides over the front of the plastic drawers when travelling and becomes a shelf when set up. Whole unit has worked very
well for quite a few years and has been much copied
If you wouild like to give me an email address I can send some photos.
269058
Follow Up By: garfield - Wednesday, Nov 21, 2007 at 06:59
I'd love to see the photis mfewster if I still can
536187
Reply By: flappa - Tuesday, Oct 30, 2007 at 08:57
My new one isn't free standing but the design idea is similar.
This is a direct drifta ripoff.
269064
Follow Up By: Member - MrBitchi (QLD) - Tuesday, Oct 30, 2007 at 09:13
Geez flappa, puts my effort to shame :-(
531894
Follow Up By: flappa - Tuesday, Oct 30, 2007 at 09:27
Lol . . . hardly.
This is my 4th effort at a kitchen unit.
Pretty happy with this one though.
Worked out
well , and is very functional , as are the proper Drifta Units
531898
Follow Up By: garfield - Wednesday, Oct 31, 2007 at 22:20
May I please ask where you brought the adjustable post that are showing in the first picture please?
532307
Follow Up By: flappa - Thursday, Nov 01, 2007 at 12:03
Sure, they are cut down tent poles
532368
Follow Up By: garfield - Thursday, Nov 01, 2007 at 18:42
Smart :-) can i also please ask did you use 7mm - or 10mm ply? and did you build it on a base or just the box with legs added?
Geoff
532414
Follow Up By: garfield - Friday, Nov 02, 2007 at 14:20
I tried to look at the link you said had more pics on it, and I can't view them. Says I need a
sign on and password to view
532585
Follow Up By: garfield - Tuesday, Nov 13, 2007 at 21:00
Where did you buy your ply? the ply I brought has really stuffed my job. I'm gonna have to start again as it warpped.
I put all the pieces together for a dry run and it really looked so sh@thouse I felt like crying! I don't know if I just got a bad product or if I stuffed up along the way. I cut everything to the same measurement and the cuts were done on my Triton 2000, so I know my cuts were sqaure and true.
534570
Follow Up By: garfield - Tuesday, Nov 13, 2007 at 21:01
534571
Follow Up By: Member - MrBitchi (QLD) - Wednesday, Nov 14, 2007 at 08:53
Garfield, the secret to using ply (or any timber) is never allow it to get wet. Buy it, build it, paint it as soon as possible. If conditions are really bad, give the timber a coat of primer as soon as you buy it. That will seal it and keep the moisture out.
Never lay the timber flat on the ground or concrete to store it. It will absorb moisture unevenly and warp. Store it off the ground or on its edge if you have to.
534646
Follow Up By: garfield - Wednesday, Nov 14, 2007 at 12:51
What I'm getting at is, in the pictures you have posted your
camp kitchen looks very straight - like there's no bend in your shelves, or your walls by the looks of it. So I was wondering if you brought a different type of ply or from a ply wood specialist.
I kept
mine off the floor. I had it cut and stack on a bench top in the shed, and when I went to dry run putting it together it was warped.
Is yours as straight as it looks?
534678
Follow Up By: Member - MrBitchi (QLD) - Wednesday, Nov 14, 2007 at 12:55
Yep.
Mine's straight.
534679
Follow Up By: garfield - Thursday, Nov 15, 2007 at 21:37
It looks straight :-)
one more question for you - where would I buy one of them pump action taps you have on yours there please?
Geoff
534950
Reply By: Member - MrBitchi (QLD) - Tuesday, Oct 30, 2007 at 09:11
Built this one last year. Its was built as a prototype but has become sorta permanent ;-)
Built to fit in my camper which is 500mm deep.
Made from plywood. Drawer is a prefab unit from Bunnings on standard kitchen style runners with a ply front.
Aluminium struts and hardware from Whitworths Marine, canopy bits.
269066
Follow Up By: flappa - Tuesday, Oct 30, 2007 at 09:12
Sweet looking unit.
Well done.
531893
Follow Up By: Member - Brian A (NSW) - Wednesday, Oct 31, 2007 at 14:42
G'day John.
on seeing your posting, I thought I was seeing double. These photos are of a unit my son built as part of his "Design & Technology" assessment for year 12 last year. Extremely similar to yours - appears to have the same legs - ours from Bunnings. 12 months on, and it hasn't been used or sold. He achieved quite good reviews for it school.
Brian
532180
Follow Up By: Member - Brian A (NSW) - Wednesday, Oct 31, 2007 at 14:44
Well that was real successful.
Shall have to find out how to insert images.
Brian
532181
Follow Up By: Member - Brian A (NSW) - Wednesday, Oct 31, 2007 at 14:45
There are a couple of pics in "my rig"
Brian
532182
Follow Up By: garfield - Friday, Nov 02, 2007 at 18:27
Could I please ask where you brought the elastic thingy? The hocky strap material thing that catches onto those white thumb tack looking things please
532619
Follow Up By: Member - MrBitchi (QLD) - Saturday, Nov 03, 2007 at 14:11
Garfield,
Whitworths Marine. Any chandlery should have them. They're called "Canopy Loops"
532774
Follow Up By: garfield - Saturday, Nov 03, 2007 at 19:15
Great.... thanks for that. I'll be needing a couple of those
532821
Reply By: AndrewX - Tuesday, Oct 30, 2007 at 09:45
Well the above are really great and put my
camp oven and dual burner Coleman to shame!! But Geoff before you start building do consider how much space particularly and also weight you are prepared to dedicate to just eating. I apportion my load with consideration to sleeping, eating, washing, navigation, recovery, maintenance, clothing. I just wouldn't be prepared to give so much space and weight to just eating.
269073
Reply By: Member - Barnesy (SA) - Tuesday, Oct 30, 2007 at 13:19
There are a couple of photos on my member page of my kitchen. It isn't free standing but could easily be made like that with different legs. I used mdf and painted it. May give you some ideas.
Regarding the post above about extra space etc. I find my kitchen actually creates space for little things by having them within easy reach and organised right up to top of trailer. Weighs about 18kg empty. Less than a full gerry. Don't have to put just food in the plastic boxes.
Barnesy
269108
Reply By: DuxLux - Tuesday, Oct 30, 2007 at 22:58
Hi DuxLux,
Not exactly free-standing but this is as cheap and yet as serviceable as they come. Check the photos at the bottom of the page for my el-cheapo
camp kitchen.
http://
forum.
camping.com.au/viewtopic.php?t=1095&postdays=0&postorder=asc&start=30&sid=3d750e75b399a9726e1e816c1232118e
If this doesn't work go to -
http://
forum.
camping.com.au
On page 2 of the
forum , down the bottom under the topic of
"Organizing your kitchen", go to page 3 of that thread and down
the bottom. Let me know if you want any details.
NotherLux
269214
Reply By: garfield - Wednesday, Oct 31, 2007 at 12:13
Some goodies in there.... Does anyone have like a plan of any of theirs? some measurements and the like
Geoff
269273
Follow Up By: flappa - Friday, Nov 02, 2007 at 08:55
The external dimensions of
mine were off the drifta website.
I just made the internal dimensions up to fit my purposes.
I dont draw plans , they are located between my ears.
532548
Reply By: AdrianLR (VIC) - Friday, Nov 02, 2007 at 13:05
Geoff,
Have a look at these "Patrol Box" plans that some scout troops use. A few have detailed construction plans.
http://www.troop168.net/forms/patrolboxa.htm
If you google "Patrol Box" you'll get some others.
Adrian
269706
Reply By: garfield - Friday, Nov 02, 2007 at 14:21
Thanks for that
269716
Reply By: garfield - Thursday, Nov 15, 2007 at 21:34
Well for all that have helped me with my queries, here's the project so far.
P.S thanks for your help
How do I insert a
pic?
271883
Follow Up By: garfield - Sunday, Nov 18, 2007 at 08:39
Actually I was wrong. This is how you can view my pics :-)
my camp kitchen
535517
Follow Up By: garfield - Sunday, Nov 18, 2007 at 21:50
some more pics of the
camp kitchen in progress
" href="https://
" target="_blank">tea towel holder
535678
Follow Up By: garfield - Sunday, Nov 18, 2007 at 21:53
disregard that last attemp to past a link..... try this one instead
tea towel holder
535679
