Solar GPS Logger
Submitted: Tuesday, Oct 30, 2007 at 07:53
ThreadID: 51071 Views:2601 Replies:4 FollowUps:3
HI I have got a Solar SPS logger attached to OZI Explorer. I am using a Bluetooth connection. I have noticed that after running the GPS for about 15 minutes the GPS stops communicating via Bluetooh and I have to econnect the GPS. Any Ideas
Reply By: Member - Doug T (Qld) - Tuesday, Oct 30, 2007 at 08:48
Have you got a Bluetooth Phone trying to compete with the S..PS logger, or some other bluetooth device nearby
AnswerID: 269061
AnswerID: 269062
Follow Up By: Member - Doug T (Qld) - Tuesday, Oct 30, 2007 at 08:49
Sorry for the ECHO
FollowupID: 531888
Reply By: Member - Michael P (NSW) - Tuesday, Oct 30, 2007 at 09:11
No there is no other Bluetooth device connected
AnswerID: 269065
Reply By: Member - Andrew (QLD) - Tuesday, Oct 30, 2007 at 10:52
Just confirming.....you are using OziExplorer on a laptop/computer? (not OziCe on a PDA)
If we are talking about OziCE, there were some issues with Pocket PC2003 and bluetooth connectivity when the PDA is turned off (PDAs tend to do this often when not required :-)).
AnswerID: 269092
Follow Up By: Member - Michael P (NSW) - Tuesday, Oct 30, 2007 at 11:19
No I am Just using Oziexplorer on a laptop. The Bluetooth works well with the Mobile Phone. I suspect that that it may be the GPS. The problem is I cant monitor the devices and log which one fails. Other that that the Bluetooh Solar GPS works well and communicates very effectively with Oziexplorer.
FollowupID: 531920
Follow Up By: Member - Andrew (QLD) - Tuesday, Oct 30, 2007 at 11:50
Do you have any power mangement settings enabled on the laptop? Things like hibernation etc can affect the bluetooth protocol, so your laptop settings may be at fault. Try it with power supply plugged in, screensavers off (shouldn't be an issue though), and any power management settings set to full (harddrives, LCD etc not turning off after set time).
Some of these GPSr's have "smart power save" which turns off the bluetooth connectivity if no NMEA sentences are required, however i'm not sure why they would stop for you.
Hope this helps
FollowupID: 531924
