OZI ce Issue
Submitted: Tuesday, Oct 30, 2007 at 13:24
ThreadID: 51080 Views:1991 Replies:5 FollowUps:3
I have ozi ce on my HP 2200 + BS4100 b/t gps which normally works fine, but the other day i took out the tomtom card and put in the ozi maps card when after about 2-3 minutes, ozi froze up, so i restarted ozi and the same thing happened. I tried agian and guess what, it froze agian!.
I dont remember changing any settings only that I put a maps on a new SD card. HAs this happened to anyone else??
Signed frustratingly DAve.
Reply By: StormyKnight - Tuesday, Oct 30, 2007 at 13:31
When exactly does it freeze? When you try to access a map off of the card or before?
Have you tried the original card?
Richard
AnswerID: 269110
Follow Up By: selasticman - Tuesday, Oct 30, 2007 at 13:35
HI Richard,
Sorry, should have said that I have a map on screen and it freezes about 2-3 minutes after I start navigating.
FollowupID: 531935
Follow Up By: StormyKnight - Tuesday, Oct 30, 2007 at 17:59
OK so if you don't navigate does it still respond 2-3 minutes later & is it trying to change maps at the 2-3 minutes later?
Also I don't know if this is possible, but can you load 1 map into the memory of the unit & see if it plays up on that map.
FollowupID: 531973
Reply By: StormyKnight - Tuesday, Oct 30, 2007 at 13:32
Richard
AnswerID: 269113
Reply By: Member -Signman - Tuesday, Oct 30, 2007 at 15:54
Just a suggestion (no responsibilty accepted)...try a 'soft' reboot..
AnswerID: 269128
Reply By: John R (SA) - Tuesday, Oct 30, 2007 at 18:29
I quite often have to do soft reset with my ipaq (4150) & ozi.
I'm not sure if that's what you mean when you say you restart ozi, however be aware that although a soft reset should not delete any info (unless there's an open frozen/unsaved program), it can do. Particularly if the system's had a major hissy fit.
So I'd suggest ensuring all info is saved next time you sync, then when ozi next freezes do a soft reset and start over.
AnswerID: 269159
Follow Up By: John R (SA) - Tuesday, Oct 30, 2007 at 18:32
Just re-read that post . . . . . sorry if I sound condescending - it's entirely possible you know more about pocket pcs than me!!!
FollowupID: 531991
Reply By: JTPrado - Wednesday, Oct 31, 2007 at 11:54
I had the same problem with a particular SD card. Tomtom would freeze when planning a route if it was a long distance. Some SD cards are not as compatible as others and will cause problems. Only thing to do is try a differenent SD card. Do a Google search on SD card compatibility and you will find lots of information about the issue.
Regards,
AnswerID: 269268
