New AT 265/70/16
Submitted: Tuesday, Oct 30, 2007 at 17:10
ThreadID: 51086 Views:3377 Replies:5 FollowUps:14
Which tyres to buy...this is deadset a minefield of opinions and facts. I have been looking at Coopers, BFG's, Bridgestone, Goodyear, Yoko's, etc, etc. Now I have found Maxxis and Severos...and at a price it's hard to say no. Can the big brand tyres be that much better, $500 better for 5 tyres.
Has anyone had experience with Maxxis or Severos?
Reply By: Andrew from Vivid Adventures - Tuesday, Oct 30, 2007 at 17:50
No, but if no one knows what tyres you are talking about, other than the brand, and no one knows where you're taking them, what you're puting them on, what you carry, etc., you are not going to get any information - just opinions and data.
Get a tyre dealer to give you advice, ask for the whys are wherefores, and then come here and check it out.
AnswerID: 269146
Follow Up By: JackMack - Tuesday, Oct 30, 2007 at 20:35
Fair enough...new to this forum stuff.
I have a Pajero NP 2003 DiD and am taking into the desert, Cape York etc. I have been looking at all types of AT tyres in the size 265/70/16's. I will be carrying normal camping stuff plus steel bullbar, lights etc.
The price on the Maxxis AT's are approx. $500 cheaper than the big name brands. My question is how good are the Maxxis AT in that size?
Jack
FollowupID: 532045
Follow Up By: Member - Scoof (SA) - Tuesday, Oct 30, 2007 at 21:05
JackMack I have been wondering the same thing.
I've seen about every tyre brand in the tyre repair place either being repaired or totally written off.
So what is the difference apart from the dollars,,, I wonder.
Some of the tread patterns are even very similar and the amount of ply's and constrution similar or the same ???????.
Regards Scoof . :-)
FollowupID: 532056
Follow Up By: JackMack - Tuesday, Oct 30, 2007 at 21:14
Scoof,
I know some tyres have a silica compound in them which makes them grip well in the wet, but the tyres I have been looking at are all rubber i.e. Coopers, BFG, Mickey T's etc. Also the Maxxis are all rubber. So go figure on why the great price difference, unless the cheaper tyres return crap milage...maybe thats it but I would like to confirm.
By the way that a big rig!
FollowupID: 532062
Follow Up By: Andrew from Vivid Adventures - Tuesday, Oct 30, 2007 at 21:26
Tyre construction and materials are anything but not simple.
The factors to consider when choosing tyres is also - or should be also quite complex.
Unfortunately, even when the magazines in this segment of the market do a review, they don't always do it impartially or well (eg. scientifically) and make many subjective assessments.
In my view if you are going to be doing the desert and Cape York, ATs are not the ideal choice. They might be fine. Plenty of people have been up there and across there with them, but you are stretching the friendship in terms of what they were designed for.
That said, they will be a little nicer on the black stuff for a while until they wear a bit.
Tyres are complex composite structures that are bearing huge loads, and there is nothing simple about their performance. Hit any of them hard enough, and they will break. Mistreat any of them and they will fail. Put any of them on or against anything sharp enough and they will get staked.
Do you fly Aeroflot or even Garuda? They fly the same planes that Qantas fly. What can the difference be apart from the dollars?
It's your call.
FollowupID: 532075
Follow Up By: Member - Scoof (SA) - Tuesday, Oct 30, 2007 at 22:12
Andrew maybe the pilots. LOL in Garuda's case anyway..
FollowupID: 532098
Follow Up By: Member - Davoe (Yalgoo) - Wednesday, Oct 31, 2007 at 10:39
Sorry didnt see you had a Paj and where you were going. Definitly go the 265x75 10 ply tyres in LT construction. 7 ply tread and 3 ply sidewall.
check out the specs of the tyres you are looking at i doubt they have this type of construction
FollowupID: 532147
Follow Up By: JackMack - Wednesday, Oct 31, 2007 at 12:25
Davoe,
Thanks for the advice. I have been told that by increasing the tyres size to a 265/75 from a 265/70 I will use more fuel and lose power as a result. Have also recieved advice that this is not the case. Most of my driving is on the blacktop around Brisbane but I do want the advantage of taking the Paj anywhere. Gotta comprimise somewhere soon.
Jack
FollowupID: 532156
Follow Up By: Andrew from Vivid Adventures - Wednesday, Oct 31, 2007 at 12:52
Well of itself it won't increase your consumption - if anything decrease it because of the higher gearing.
You don't actually lose power, but effectively it makes you geared a little higher... which has the same feel as less power...
The tyres weigh a little more, but not enough to make a difference to consumption.
People thing they have a consumption issue, but in fact they have travelled the same actual km - it is just that the speedo is underreporting the distance by whatever the difference in circumference of the wheel - perhaps 5-10%.
Andrew.
FollowupID: 532161
Reply By: marq - Tuesday, Oct 30, 2007 at 21:43
You have to look at a few things including load ratings and speed ratings.
Some of the brands you mentioned do not have the load ratings (min 112).
Speed ratings - hay are you ever going above 150km/h - I doubt it (min N?).
I went into a tyre dealer wanting a particular size (thinking BFG) - compared BFG, Coopers and Goodyear - surprisingly I selected GY on the way they felt etc (I was not interested in any crap the dealer was saying mainly trying to flog coopers at $300/tyre vs $225 for the GY). The coopers felt light and thin compared to BFG and GY.
But at the end of the day it is up to you to decide on the tyre for your vehicle.
AnswerID: 269198
Reply By: JackMack - Tuesday, Oct 30, 2007 at 22:14
Still no opinion on Maxxis AT's...just a comment on what you pay for is what you get and choice of air carriers. Mmm...
AnswerID: 269206
Follow Up By: Dan26aus - Tuesday, Oct 30, 2007 at 23:26
Hi there JackMack, i have Maxxis AT's on my Patrol, which were close enough to being new, and whilst i wasn't very keen on them at first, i must admit they have definately grown on me. Have been pretty much everywhere with the exception of in the mud & they have handled fine. In the beginning i didn't like the feel of em on the blacktop just after a shower of rain ( felt like they weren't the best of grips ), and all i wanted to do was wear them out and go for a set of m/t, but now 2 yrs later & 51,000 k's, i would recommend them for sure. they are probably down to about the 50% mark for tread & a bit of wear on the outers ( from me putting of a couple of wheel alignments ). I have down a few trips to Cairns (from Gladstone), with a trip to cooktown added in & i was more than impressed with how they handled the sand to Elim beach & the gravel back through the bloomfield. So when it's time to renew em, i will be going for the Maxxis a/t's at $170 instead of the Good Year m/t's at $325....
Good Luck with what tyre suits you!!
Dan
FollowupID: 532109
Follow Up By: JackMack - Wednesday, Oct 31, 2007 at 12:35
Dan,
Thanks for the wrap on the Maxxis...your the first person that has any experience with them. I don't know wether that is good or bad. Most of my driving will be on bitumen around town but need to have half decent rubber for those trips to the Cape and the desert. As I have said before it's going to be a comprimise.
Thanks again,
Jack
FollowupID: 532159
Follow Up By: Dan26aus - Wednesday, Oct 31, 2007 at 16:36
No worries mate, i don't think you would be too disheartened from them at all. Like i said, i don't have any issues at all with them, & i think they are good as gold on sand. As much as i liked the look of the muds, i would realistically do more on the sand or gravel & the muds would only bite into the sand more..... I just think they are value for $...Good luck when you get to go to the cape. Hopefully i will also make that trip next year sometime.....
Dan
FollowupID: 532200
Reply By: Member - Davoe (Yalgoo) - Tuesday, Oct 30, 2007 at 22:41
Pretty sure the choices for that size in a decent construction are pretty limited
Im guessing they are a 6 plywit 4 tread plys and 2 sidewall- thats why there cheap.
unno what vehicle youhave but unless yo are sticing strictly to the bitumen you wold be FAR better off squeezing 265x75 tyres in
Gives you the widest choice of decent constructed tyres under the aussie sun.
Without naming brand if you aregoing off the bitumen you should be looking at 6-7 tread plys and 3 sidewall in a 10 ply LT construction
There are only a few makers of this type of tyre all the rest are cheaper for a reason
AnswerID: 269210
Follow Up By: Member - Davoe (Yalgoo) - Wednesday, Oct 31, 2007 at 08:07
Sorry bout the poor typing i reeeely hate that laptop keyboard it makes me look drunk
FollowupID: 532128
Follow Up By: JackMack - Wednesday, Oct 31, 2007 at 12:30
Davoe,
Your right...the better tyres are in the bigger size. I think the BFG in a 265/70 come in a LT version though. News is I should go for the larger tyre...just dont want nto lose power and use more fuel.
Jack
FollowupID: 532158
Follow Up By: Member - Davoe (Yalgoo) - Wednesday, Oct 31, 2007 at 13:33
bigger tyres will use a bit more but you really arnt talking about much of an increase here.Most people would be talking when they changed from there 265x75 tyres to 285x75ior even 315 tyres.
Off road suitable tyres will always use a bit more than the HT tyres it probably came with but for the increase in bushability a 265x75 tyre will give you you wont notice the difference
FollowupID: 532170
Reply By: Ianw - Tuesday, Oct 30, 2007 at 22:47
I was going to buy Maxxis Bravos in 255/70 16 for the Nav but they only have load index of 109. Nav has to have 111 to be legal
Had to change to 265s so got Hankooks instead
Ian
AnswerID: 269212
