Jayco Toilet
Submitted: Tuesday, Oct 30, 2007 at 22:20
ThreadID: 51102 Views:3529 Replies:3 FollowUps:6
Used my new Jayco Pop Top for the first time last weekend. Heavy rain on Friday night,used toilet during night and the shower floor was dry. Next morning, a few mm of water covering shower floor (didn't miss). Dried floor and was dry all day and next night. Used toilet during Saturday night , no rain. Next morning, water on floor again. We were at a van park and did not use the shower. We did not use the toilet during the day. Seems to me the water is coming from the toilet flush - any ideas?
Reply By: 96 GXL 80 series - Tuesday, Oct 30, 2007 at 23:24
Your not Jewish are you?
As I heard when they circumcise jews they do it side ways.
That way when you are standing at the urinal you can wash the shoes on the blokes either side of you.
Hope this helps.
might pay to check.
AnswerID: 269217
Follow Up By: bing - Tuesday, Oct 30, 2007 at 23:42
Checked that - all o'k!!!
FollowupID: 532112
Follow Up By: 96 GXL 80 series - Tuesday, Oct 30, 2007 at 23:48
Do you sleep walk?
FollowupID: 532114
Follow Up By: 96 GXL 80 series - Tuesday, Oct 30, 2007 at 23:59
I just noticed your name "Bing" gees anything could happen if your related to Mr Crosby.
Probably one of his bouncers.
FollowupID: 532116
Follow Up By: bing - Wednesday, Oct 31, 2007 at 00:02
Don't think I sleep walk but not sure about my wife - have to keep an eye on her next time!!
FollowupID: 532117
Follow Up By: 96 GXL 80 series - Wednesday, Oct 31, 2007 at 00:08
Check your wifes back ground history, as she might be Jewish
FollowupID: 532118
Follow Up By: bing - Wednesday, Oct 31, 2007 at 20:08
Thanks. I will check the hoses and the shower waste outlet. The water seemed to be clean water.
FollowupID: 532246
Reply By: herkman - Wednesday, Oct 31, 2007 at 07:55
If you open the outside door on the cassette exit, check the two hoses where they join for the toilet flush. Depending on the guy who put the unit in, the method of joining may not be satisfactory,
It can and does occur at that point you can get a water leak whilst flushing, but it will take a while to run inside.
Also trying switching the 12 volt off after flushing and see if that stops the water appearing.
Col
AnswerID: 269242
Reply By: Member - DAZA (QLD) - Wednesday, Oct 31, 2007 at 15:58
Hi Bing
Have you checked to see if the water is coming back out of the
shower floor waste outlet.
I have seen this problem before, when you let the plug out of the
kitchen sink, (BEING HIGHER THAN THE SHOWER OUTLET)
water will sometimes back up if the outlet pipe is restricted.
Daza the Plumber.
AnswerID: 269309
