Info about Patrol engines
Submitted: Wednesday, Oct 31, 2007 at 09:57
ThreadID: 51111 Views:3161 Replies:5 FollowUps:4
I want to buy a 2001 Nissan Patrol. 3.0 Lt Turbo Diesel.The original motor blew up which was replaced with a 2003 motor.
Apparently there were two types of engines used between 1999 to about 2003.
One with rubber timing belt and the other with timing chain.
Is this correct, what are the year dates and how do you tell the difference?
Can anyone advise please?
Barra
Reply By: Member - Roachie (SA) - Wednesday, Oct 31, 2007 at 10:16
Have a search around on the Patrol forum.........
http://www.patrol4x4.com
AnswerID: 269260
Reply By: BARRA - Wednesday, Oct 31, 2007 at 11:18
Thank you and cheers
Barra
AnswerID: 269262
Reply By: Motherhen - Wednesday, Oct 31, 2007 at 14:27
Check out http://www.lonards-automotives.com.au/patrol.html for the sublte differences. The series III commenced October 2001.
AnswerID: 269291
Follow Up By: BARRA - Thursday, Nov 01, 2007 at 16:39
Thaks Motherhen,
This ai all I wanted to know!
I take it the series 111 has a steel timing chain?
Yes?
Barra
FollowupID: 532404
Follow Up By: Member - 120scruiser (NSW) - Thursday, Nov 01, 2007 at 21:03
All ZD30 engines run a single row timing chain.
The 2.8 diesel which was discontinued in 1999 runs the rubber timing belt.
FollowupID: 532446
Follow Up By: BARRA - Friday, Nov 02, 2007 at 08:27
120scruiser
You are a good man.
Thank you,
Barra
FollowupID: 532543
Reply By: stefan P (Penrith NSW) - Wednesday, Oct 31, 2007 at 16:23
quote the new engine number to Nissan, they should be able to tell you any differences between the two
Cheers Stefan
AnswerID: 269316
Follow Up By: BARRA - Thursday, Nov 01, 2007 at 16:36
Thanks Stephan
Yes I have already done that but they still could not help/
Barra
FollowupID: 532402
Reply By: Brew69(SA) - Thursday, Nov 01, 2007 at 21:33
Good luck.
AnswerID: 269594
