HJ61 Cruiser info?
Submitted: Wednesday, May 28, 2003 at 18:27
Brett
Am chasing faults with a 12HT powered Landcruiser which have been induced by the clown that pulled it apart and wired the preheat & vac lines incorrectly.
Can anyone assist me with the terminal connections on heated manifold and throttle close diaphragh vac diagram.
Reply By: Bob Y. - Qld - Wednesday, May 28, 2003 at 20:47
Brett,
Might have what you want, straight out of factory manual.
Is the "throttle close diaphragm vac" a vacuum switching valve that controls the throttle valve? If it is, then I've got it, but the manual doesn't show any wiring dia. Also the connections for heater manifold are shown in a circuit dia that would help you sort them out.
Have you got a fax, I'll just photocopy and send when you give the nod. Hooroo...
21323
Follow Up By: Brett - Wednesday, Jun 04, 2003 at 19:31
Sounds good,if only i had access to a fax.
Thanks for the offer.
Brett
14276
Follow Up By: Bob Y. - Wednesday, Jun 04, 2003 at 19:43
Brett,
Can stick the photocopies in the post if you wish, just give me an address or PO Box #.
Hooroo...
14278
Reply By: Dozer - Thursday, May 29, 2003 at 11:10
Be careful, the throttle valve is what actually stops the motor.
There are a few manuals on sale at ebay for a good price-i sold
mine with the 60-sorry. (go to www.ebay.com.au and put in landcruiser under search)
21370
