AnswerID: 21605 Submitted: Monday, Jun 02, 2003 at 13:32
Bob Y. - Qld
replied:
G'day Crowe,
If your fuel problem is as bad as you say, I feel you'll get little joy from the inline filters, they are just too small to last too long. How about dropping the offending tanks out, and flushing them out, or even getting them professionally cleaned. Otherwise you could try 2 of the Lucas/CAV water trap filters, the elements are only $5 - 8 each.
A mistake some people make is to use every last drop out of their tanks. This sucks up all the gunk from the base of the tank, giving thse sorts of probs. Caterpillar recommends refuelling once the tank gets to 10% capacity, this is a good guideline for any diesel.
As an alternative to removing the tanks, you could leave a few litres in each, take for a lively drive somewhere, then drain all fuel out. Doing this 2 or 3 times may remove a lot of the gunk. Good luck, hooroo...
Reply 1 of 3
