Section Image
Specific Question For GU 3.0TD owners running 265/75/16's tyres
Submitted: Thursday, Jun 05, 2003 at 11:42
I'm after some specific feedback on the 265/75/16 tyres on the GU 3.0td.
I have the 'off the shelf' 265/70/16's and am tossing up the pro's and con's of going to the 75's
The info I am specifically looking for from those currently running 75's is
1. Any increase/decrease in fuel consumption?(most important)
2. Have they effected power on take off?
3. Is there more brake pedal pressure required to stop the car?
4. Any other comments you have?
Thanks in advance to all.
Andy
ThreadID: 5299 Replies: 8
Views: 539 FollowUps: 14
AnswerID: 21907   Submitted: Thursday, Jun 05, 2003 at 11:45
Andrew replied:
Sorry people...
Also, are you running a manual or Auto????
Reply 1 of 8
AnswerID: 21912   Submitted: Thursday, Jun 05, 2003 at 12:41
Member - Rohan K replied:
Andrew, the 265/75-16 is 27 mm larger in diameter than the OEM tyre and is therefore technically illegal in some states like NSW (unless you get an engineer's certificate).
Fuel economy will be determined by many things, much of it up to you, such as the load you place on the motor. For example, as acceleration will be slightly slower, if you push the gas pedal harder to make up the difference, you'll use more gas. However, at cruising revs and speeds, you should achieve better economy.
The increase in circumference is about 3.5% so you could expect a slight negative impact to acceleration (not sure you'd notice it) and a reduction in revs for any given speed (of approx 3.5%).
With larger diameter tyres, there is less engine breaking effect so, yes, more brake pedal pressure is required. However, with a relatively small increase like 3.5%, I'm not sure you'd notice much difference, if any.Life just ain't that serious.
Rohan (Sydney)
Reply 2 of 8
AnswerID: 21914   Submitted: Thursday, Jun 05, 2003 at 13:03
Pete G replied:
Andrew,
I have done this with Bridgestone AT's - same as fitted to the Utes. That way you get a stronger sidewall cf the passenger vesion AT. (265/75R16 LT's (D693's)). Note that these are different to 265/75/16's which are a "passenger radial".
There is a small increase in diameter of about 24mm which equates to about 3kph at 100kph - in fact this reduces the over-read of the speedo from 6-7 km to 3-4km.)
Personally the only -ve is a slightly harsher ride. No noticeable differences in other factors ie power, braking or fuel economy. This is with a manual. I run 36-38 Psi on road. So far 50k's and looking like they will do another 20-25k's easily.
To make things leagal you need to get a sticker for the alternative tyre size from Nissan and stick on the tyre placard (The part No was posted on this forum a few months ago) . In NSW this is necessary for an increase of more than 15mm in diameter.
If you have been watching this site previous posts refer to issues with Coopers and BFG's.
Yes it is somewhat confusing - you also need to consider the speed and load ratings specified on the vehicle tyre placard (for ST Patrol this is 112S) the 112 is load rating which is minimum the S is the speed rating which is allowed to be as low as N (any lower requires a label to be affixed to Windscreen)).
For further info refer to RTA and Bridgestone websites.
PeteG
Reply 3 of 8
FollowupID: 14331   Submitted: Thursday, Jun 05, 2003 at 13:09
Pete G posted:
Further to the reply previous to mineno engineers certificate is necessary in the case of the nissan as long as you fit the alternative tyre size sticker. This is because the manufacturer has allowed the alternative tyre size to be used (on another vehicle in the range).
If the sticker were not available then an engineers certificate would be required.
PeteG
FollowUp 1 of 5
FollowupID: 14333   Submitted: Thursday, Jun 05, 2003 at 13:29
Member - Rohan K posted:
Peter G, is that because the 265/75-16 are run on the cab-chasis model?Life just ain't that serious.
Rohan (Sydney)
FollowUp 2 of 5
FollowupID: 14334   Submitted: Thursday, Jun 05, 2003 at 13:31
If so, that means under the regulations, you could go to a 275/75-16, as you are permitted 15 mm above what's indicated on the tyre placard sticker.Life just ain't that serious.
Rohan (Sydney)
FollowUp 3 of 5
FollowupID: 14368   Submitted: Thursday, Jun 05, 2003 at 18:01
Pete G posted:
Folks: apologies for some clumsy typing.
The 70 profile tyres from bridgestone are a "passenger radial" type construction. In the first para the 2nd sentence should read 265/70/16's
The 75 profile tyres have a much stronger sidewall. If you reference the Bridgestone site the 265/75R16 LT's in Dueller D693's come with a lot of added strength features compared to some other sizes in that range of theirs.
In Followup No. 1 mineno should read as 2 words.
Basically to depart from the placarded tyre sizes you need either a revised placard (sticker) from the manufacturer or if this is not available then an engineers certificate.
The RTA regs apply relative to the largest tyre listed on the placard
(ie 15mm dia and xxmm wider etc)
PeteG
FollowUp 4 of 5
FollowupID: 14379   Submitted: Thursday, Jun 05, 2003 at 19:56
Thanks Peter. That's as i understand it too. The xx above, is 26 mm in NSW.Talk is cheap ...
Rohan (Sydney)
FollowUp 5 of 5
AnswerID: 21919   Submitted: Thursday, Jun 05, 2003 at 13:41
tristjo replied:
If you are in QLD,
The law states that you are able to use a tyre that is up to 50mm larger in diameter than the largest factory fitted tyre for that particular model.
Example: (I beleive this is how it works)
In a GU Series 3 patrol, the largest tyre fitted is on the 4.8ltr. It runs 265/75/R16's This size has an rolling diameter of approx 810mm. Therfore you could run a 34inch tyre legally, as long as all the other conditions were met.
There is no doubt about it, changing sizes can be a nightmare, but IMHO, it is well and truly worth the trouble. The difference can be quite amazing, and anyway, you've gotta love shopping for new rubber!! Don't ya just love the smell!!
Tristjo.
(oh, and by the way, if any of my info is incorrect, please let me know. Thanks.)
Reply 4 of 8
FollowupID: 14361   Submitted: Thursday, Jun 05, 2003 at 16:47
Member - Bill posted:
Tristjo,
I think the new petrol wagons run 275/70 like the tojo's.
As for the original question, I just put 265/75LT's on my new 3.0Di Auto. No economy figures yet, but it's sure to be no worse on the highway. It does feel a little more suggish up steepish hills, but from take-off it's not real different. I think the Auto probably takes up the slack. Definitely more pedal pressure to stop but not a big deal.Regds
Bill
Activities Index
Candlelit dinner and wine for two guests Candlelit dinner and wine for two guests
Mornington Peninsula - VIC
Rekindle some romance with a candlelit dinner at Woodman Estate.
Freycinet 4 Day kayak, walk & cruise Freycinet 4 Day kayak, walk & cruise
Hobart - TAS
Slow to the rhythm of the sea on this relaxed 4 day experience.
Kayaking, Snorkelling & Dolphin Watching Tour Kayaking, Snorkelling & Dolphin Watching Tour
Gold Coast - QLD
KAYAKING, SNORKELING, DOLPHINS, ABORIGINAL CULTURE. Several tours in one.
Romantic Luxury Picnic For Two Romantic Luxury Picnic For Two
Sydney - NSW
Indulge in a luxury picnic experience , complete with chauffeured prestige vehicle, sparkling wine a
Private Surf Lesson for 1 Private Surf Lesson for 1
Byron Bay and Northern Rivers - NSW
A private one-on-one surf lesson with your own qualified instructor.
Vintage Winetasters Tour Vintage Winetasters Tour
Hunter Valley - NSW
Journey by mini coach or 4WD through the peaceful Watagan Mountains, looking out for wildlife, to th
Jet Boat Blast In Sydney Harbour - 35 Mins Jet Boat Blast In Sydney Harbour - 35 Mins
Sydney - NSW
This jet boat ride races at 75 km/h for 35 heart-stopping minutes, through magnificent Sydney Harbou
1 Day Mornington Peninsula Ultimate Tour 1 Day Mornington Peninsula Ultimate Tour
The charming Mornington Peninsula showcases Victoria's natural treasures.
Whale Watching on the Gold Coast Whale Watching on the Gold Coast
Gold Coast - QLD
Magnificent... Breathtaking...
Book Now - Things To Do
AnswerID: 21921   Submitted: Thursday, Jun 05, 2003 at 13:50
Pete G replied:
Rohan,
The 265/75R16 LT's are standard on the Ute (Cab Chassis).
The RTA website - vehicle standards has a data sheet on this issue. The 275's would be a larger dia than the 265's given as the sidewall height is a function of the width.
In NSW it is permitted to fit tyres that are less than 15mm larger diameter and (25mm I think) in width than the largest listed on the Tyre Placard. Hence if a 265/75 is permitted (as per the new sticker applied) then as long as dia is not more than 15mm more then this would b e OK.
Also refer to the Bridgestone website.
Reply 5 of 8
FollowupID: 14348   Submitted: Thursday, Jun 05, 2003 at 15:50
Thanks Peter. That's also how I "read" it. The 275/75-16 is exactly 15 mm larger in diameter than the 265/75-16 so I assume it's OK.
Not that any of this helps me - I own a Pathfinder and unless I can convince them that the 285/70-17 used on the US Pathfinder Amarda (yet to be released), is an eligible alternative size, I don't have much option in tyre sizes. Back to the engineer, I guess.Life just ain't that serious.
Rohan (Sydney)
FollowUp 1 of 3
FollowupID: 14364   Submitted: Thursday, Jun 05, 2003 at 17:46
Pete G posted:
Rohan,
In your case you need either an approved tyre placard from the manufacturer or an Engineers Certificate if the placard is unavailable.
In the case of the GU ST Patrol to upgrade to 265/75R16 LT's all you need to do is to purchase the sticker from Nissan (about $8.00).
PeteG
FollowUp 2 of 3
FollowupID: 14377   Submitted: Thursday, Jun 05, 2003 at 19:51
Thanks peter. I've spoken with Nissan and have been told there is no alternate size for the Pathfinder, so if I want to up the size, I'll need a engineer's cert.Talk is cheap ...
Rohan (Sydney)
FollowUp 3 of 3
AnswerID: 21935   Submitted: Thursday, Jun 05, 2003 at 17:34
GUPatrol replied:
No engineers certificate required, Nissan Supplies the sticker (genuine NIssan part) to replace the original with when you do this change.
I got one in mine.
We aware that the cab chassis are 4.2TD engines and so is mine, I cannot comment on the other aspects of the 3.0L performance, just on the compliance of that change.
Will
Reply 6 of 8
AnswerID: 21958   Submitted: Thursday, Jun 05, 2003 at 21:20
sean replied:
Nissan 3 litre 2000 66,000kms.
I have 265/75/16 BFG AT with are new and they replaced set of same.
Economy - reduced. I never get the figures quoted by some and I got better economy with tyres that came with car. Guess (note guesss) is 1 litre/100km increase in consumption due to lugs.
Acceleration. No difference noted. Power is never a problem.
Take off no probs - not even a consideration.
Brake pedal - 2000 model does not have best of brakes to start with.
Speedo. At 100km/h indicated GPS has it at less than 0.5km/h error.
50km run on dead straight had odo at 50km and GPS at 50km so error is very little with these tyres. Old and new tyres made very little difference to these figures.
Hope this helps some.
Sean
Reply 7 of 8
FollowupID: 14389   Submitted: Thursday, Jun 05, 2003 at 21:29
Andrew posted:
Thanks Sean, you are one of a few who actually answered the question. Not that I'm complaining, I need all the help I can get.
Your 2000 model, manual I guess???
And what ecomony figures are you actually getting, if you know??
FollowUp 1 of 4
FollowupID: 14407   Submitted: Friday, Jun 06, 2003 at 10:27
sean posted:
I run a roof rack also and get mostly 7.2 km/l at 100 to 110km/k (say 14l/100ks) average highway. Remove rack and 7.5 to 8.2 litres per 100km.
Car is manual.
PS - If you have a 3 litre make sure you check oil level correctly and then always check it on long runs between the 10,000 km services.
Sean
FollowUp 2 of 4
FollowupID: 14429   Submitted: Friday, Jun 06, 2003 at 16:02
Member -BJ (Sydney) posted:
Sean, if you haven't changed your brake fluid yet do it as i just did mine as recomended after 3 years & it improved brakeing heaps, same model as you but auto.Regards Bob
3 Weeks till Gulf trip
FollowUp 3 of 4
FollowupID: 14430   Submitted: Friday, Jun 06, 2003 at 16:12
sean posted:
thanks for that.
Enjoy and make sure you Keep us posted on your gulf trip you lucky B*****d.
Sean
FollowUp 4 of 4
AnswerID: 21959   Submitted: Thursday, Jun 05, 2003 at 21:23
Andrew replied:
I'm in WA. Spoke to my insurance Co (SGIO) and asked them about going to the 75's
I spoke to a guy in their resolution section who said over here we can only put up to an 8inch rim on the GU, which it has standard anyway, and you can put what ever size tyre on the rim you want, as long as it is rated for the particular rim you have. Overall diameter etc doesn't matter (he said)
He said he had noted it in my file that I intended to go to 265/75's and there is no issue with that.
Any one had any probs in WA contrary to this.?????
Reply 8 of 8
FollowupID: 14457   Submitted: Saturday, Jun 07, 2003 at 01:48
Goodsy posted:
Same as in Vic but you will need an engineers with the larger tyres. Insurance is concerned about rim size aparently because "cars" with larger rims are more likely to be stolen. Tyre size is a roadworthy thing. Larger tyres no road worthy no insurance if they can say the tyres caused the accident.
