AnswerID: 281795 Submitted: Tuesday, Jan 15, 2008 at 16:53
jayeff
replied:
I have a Subaru Forester X manual towing a Coromal popette. GTM is 960Kg and towball weight is approx 118Kg.
Subaru specs say that you must have a 50mm weight distribution hitch receiver to be able to tow 140/1400Kg. Also if you have an automatic a transmission oil cooler is advisable.
I have had no trouble towing however a minimum of a 4 bar level ride or better is required to obtain a level tow due to softish rear
suspension. (2bar level =85Kg, 4 bar = 130Kg, after that there are adjustable units for heavier loads 250Kg etc)
Have noticed even with my light tow weight that starting on a hill is better done in low range then changing to high when going. Better than burning the clutch!
Fuel consumption is acceptable at around 8.5 k per litre. Like all caravan towing this drops with headwinds which seem to be everywhere.
Hope this has been of some help
Reply 3 of 3
FollowupID: 546155 Submitted:
Tuesday, Jan 15, 2008 at 18:53
mark&shell posted:
Hi Jayeff,
Thanks for the information, very helpful.
We have a 50 x 50 Hitch towbar and Oil Cooler fitted by Subaru but will definately look at the 4 bar level ride you recommended.
Happy travelling around Oz.
Thanks mark&shell
