Stowing Highlift jack??
Submitted: Tuesday, Jan 01, 2008 at 13:06
Member -Signman
Any clever ideas out there for the stowage of a highlift jack?? Vehicle is a Troopy with ARB roof rack.
Priced the Kaymar spare wheel attachment- and it's almost the price of the jack!!
Any options would be appreciated.
Cheers- and best wishes to all for 2008!!
Reply By: Dave from P7OFFROAD Accredited Driver Training - Tuesday, Jan 01, 2008 at 13:43
we had a combined shovel/jack holder on teh side of the roack on our troopy, it was really good!
it was only about $60 some years ago, from memory
I have the jack mounted on the ARB carrier on the Datto now, but the old holder has been modded and now carries the shovel only...
279185
Reply By: Member - BIGDOG G (WA) - Tuesday, Jan 01, 2008 at 14:13
spend some $'s and do it properly......or get some second hand fencing wire and wire it to the bullbar'
Cheers...............BIGDOG
279187
Reply By: Member - Roachie (SA) - Tuesday, Jan 01, 2008 at 14:22
I've sold my high lift, but when I did have it I tried a few options for mounting. Initially I had an Opposite Lock bracket that bolted to the spare wheel holder on the Patrol, but that used to interfere with the camper trailer.
I also had an ARB rack and eventually decided to drill 2 half inch holes in the middle and rear uprights on the passenger's side. Through these holes I inserted a couple of lengths of half inch threaded rod, secured with a nut on either side of the roof rack. About 2" protruded out and I made sure the 2 bolts were the correct distance apart to match the holes in the high lift. It was a simply matter of sliding the jack onto the 2 bolts and follow with a suitable washer and a nut. You could also drill a hole through each bolt and use an "R" clip to hold the jack in place too (quicker....but also quicker for some low life to knock it off too).
Roachie
279190
Follow Up By: Member - Douglas M (SA) - Tuesday, Jan 01, 2008 at 23:39
I have been tempted to attach my "High Lift" to the wheel carrier but have shied away from it because I considered the mass and the wheel, the HF antenna and the jack to be too heavy for the construction of the carrier. I would like to hear what other people have to say about this.
Cheers Doug
543434
Reply By: Member - Kiwi Kia - Tuesday, Jan 01, 2008 at 15:07
If you want to stop the handle rattling try this; Rubber insulation for air con pipes comes in lengths that you slide over the pipes. I slide a couple of off cuts about 15 cm long onto the jack handle and use a shock cord to wrap the handle to the body of the jack.
I was all set to dump my hi-lift till I had a friend recently found himself on the wrong side of a
locked gate. The lock was up inside a pipe to stop it being cut but the Bl***dy vandals had managed to swap a new security type lock with the original padlock. The only way out was through the
gate as the track behind is strictly one way down
hill. The hi-lift was used to force a brace on the
gate to break a weld and let the party escape. I found out latter that a very wise person had deliberately left a weak weld on the brace so it could be busted using a jack. The rogue lock was gas axed off a few days later.
279197
Reply By: PeterInSA - Tuesday, Jan 01, 2008 at 15:08
Signman,
Have an ARB spare wheel carrier on my cruiser. Have mounted the highlift jack on the back of the carrier. Between the carrier and the back of the cruiser. Welded a piece of steel on the top of the carrier, with a bolt thru it and thru the appropriate height hole in the jack.
For the lower mount drilled a hole thru the 90mm x 50mm approx section of the carrier, inserted a 3/8 bolt approx 3 1/2 long used a nut to hold the bolt firm on the carrier and the part of the bolt that suck out fitted into a hole underneath the jack step and firmed it up with a washer and nut. The jack step is that part of the jack that connects to your vehicle to do the lift, on my unit I have two holes underneath.
This was the easy part, making the fittings to be able to use the jack on the front bumper left and right hand sides and the rear (middle via the tow tongue fitting) was the challenge.
279198
Reply By: Member - Doug T (FNQ) - Tuesday, Jan 01, 2008 at 15:10
279199
Follow Up By: Member -Signman - Tuesday, Jan 01, 2008 at 18:09
For $130 ??? I think the HT fencing wire will be the go..
543387
Reply By: furph - Tuesday, Jan 01, 2008 at 20:32
Whever you decide to store the jack fore heavens sake do it a mechanical favour, find a piece of canvas and stitch up a decent bag to cover up the working end with.
Dust will surely get into and jam the pins just when you dont need it,
mine is a treasured part of our recovery gear and looked after accordingly.
So often see one (
well, what looks like one) bolted to a spare wheel carrier like some badge of honour. Full of mud then dust. Nope, not for me
furph!
279271
Follow Up By: Member -Signman - Tuesday, Jan 01, 2008 at 20:49
Yup- I do have a 'condom' over the working parts...
543404
Follow Up By: equinox - Tuesday, Jan 01, 2008 at 21:12
If it is dusty just spray a bit of WD40 on it before each use.
Mine sits in the back of the ute, where ever there is a spare bit of space.
543407
Follow Up By: Member - Davoe (Yalgoo) - Tuesday, Jan 01, 2008 at 23:30
Ive got one of my never ending supplys of green placcy bags over
mine with zip ties not fancy but oh
well
543432
Follow Up By: Member - Cocka - Tuesday, Jan 01, 2008 at 23:57
These jacks are solid & weighty and are basically just a piece of back-up safety gear. Hopefully you'll never have to use it.
Hanging it off the side of the R/rack or spare wheel carrier creates terrific jarring leverage on what ever's supporting it especially on corrugations etc.
Depending on what's being carried in the rack, if you can find space to lay a flat board to suitable length and width and wrap tie-down straps around the jack/board to the bars of the r/rack it wont move & the weight is distributed much more evenly.
I've seen two spare wheel saddles split because they carried a jack - they are not made for this despite the strength of the Kayma clamps.
543437
Reply By: Member - Coyote (QLD) - Wednesday, Jan 02, 2008 at 11:06
IFWIW I recon you can't go past the mount that you can get for your ARB roof rack. It is readily accessible, out of most of the dust etc and with a 'condom' over it up on the roof it's clean and not in the way yet still readily accessible. for $60 you buy the combined jack/shovel holder...
279318
Reply By: Truckster (Vic) - Wednesday, Jan 02, 2008 at 12:48
Honestly, how often do you use the highlift?
I've only ever been out with someone who has used one once in 6yrs+ - that was November only to break the bead on a GU wheel after the wheelnuts came loose nuffin' up the rim.
$130 for a Toorak Tractor accessory, sort of like the bolt on Ski's on the roof of X5's/Volvo/BMW's in general - in the city come ski season...
PS. those flags I got started falling apart :(
279332
