Using a Magellan 310 GPS with a laptop
Submitted: Friday, Jun 06, 2003 at 08:08
Time
Has anyone had any experience using a Magellan 310 GPS with a laptop running Ozexplorer. If so does it run OK, don't want to upgrade the GPS if I don't have to.
Buggerlux
Reply By: Wazza (Vic) - Friday, Jun 06, 2003 at 10:32
Buggerlux, Click Here ...
Wazza
21976
Follow Up By: Time - Friday, Jun 06, 2003 at 10:39
Wazza,
Yes I had read that thread, but it doesn't confirm that the 310 worked OK with Ozexplorer.
Buggerlux
14408
Reply By: Wazza (Vic) - Friday, Jun 06, 2003 at 11:00
Ok, just checking. I have OziExplorer working right here beside me using the NMEA string from a trimble gps. The only thing you can't do is upload/download waypoints to the receiver. As the 310 outputs NEMA as
well, I would almost bet you my emap that it can work.Cheers,
Wazza
21979
Follow Up By: Time - Friday, Jun 06, 2003 at 11:15
Wazza,
Thanks for that, I was a bit reluctant to spend the $99 on the data/power cable if there was a chance it wasn't going to work for me.
Buggerlux
14412
Follow Up By: Member - Melissa - Friday, Jun 06, 2003 at 12:04
Buggerlux,
A mate of ours made a powew/data cable for our Garmin for about $8. He made one for his Magellan months ago too. Both work a treat and not hard to do.
:o) MelissaPetrol 4.5L GU Patrol &
Camprite TL8 offroad camper
14417
Reply By: ExplorOz Team - David - Friday, Jun 06, 2003 at 11:29
Time,
This is a supported GPS unit for the OziExplorer Software.
Good luckRegards
Always working, not enough travelling ;-)
21980
Follow Up By: Time - Friday, Jun 06, 2003 at 14:04
David,
Thanks, it isn't clear in the Ozexplorer GPS options that the 310 is supported, it makes reference to the 315, 320 etc and "other Magellans," my assumption therefore is the "other" category will be the choice for config.
Thanks everyone for your help.
Buggerlux
14420
Reply By: Truckster (Vic) - Friday, Jun 06, 2003 at 16:37
Theres an Oziexplorer Yahoogroup, few thousand members, they will tell you everythign you want to know.....
www.yahoogroups.com search for oziexplorer
21991
Reply By: Owie - Tuesday, Jun 10, 2003 at 08:41
I have just had a look at the config of Oziexplorer, it does not list the 310. I have a 315 as I didn't think the 310 had the data output. On the back of the unit there should be four stainless steel contacts to connect the cable.
Though if it outputs NMEA then it should work.
Cheers.
22176
