L300 conversion
Submitted: Tuesday, Jun 10, 2003 at 21:17
Ian
I am in the middle (old motor out, what a bugger of a job without a 4WD manual) of swapping the original 1800cc motor for a 2600cc
astron can anyone give me some tips or tell me what I can expect when I get it going again?
Reply By: Member - Martyn (WA) - Tuesday, Jun 10, 2003 at 21:50
Ian,
From what I've learnt cooling
water is very important, make sure you use distilled or reverse osmosis
water and a good coolant concentrate, the Mitsubishi aluminium bits are prone to cooling
water corrosion / erosion. Only a small item but can be costly in the long term.Keep the shiny side up
22251
