Site Search
Section Image
Frdige wiring question for Derek or those with first hand experience
Submitted: Saturday, Feb 02, 2008 at 18:07
Cobes
Hi all,
I would like to get some advice from others regarding the wiring to my fridges.
I have a Nissan patrol with a Rotronics dual battery system (rdc12m). I currently run 4metres x 6mm wire to the rear of the wagon to run my 40litre and my 50 litre waeco. When running the waeco normally the voltage drop is about .2 of a volt. When running the Waeco on Turbo mode the voltage drop is near to .4 volts. I have not tested running both the Engel and Waeco together but assume the drop would be even greater.
The waeco usually shuts down just below 12 volts even when the battery protection switch is set to low. This greatly reduces my fridge running time when stationary.
I can only assume that the size of the wire needs to be increased?
If this is correct could you please recommend the type and size of wire that i should be using to reduce most or all of the voltage drop?
My current wiring from the aux battery runs via a relay which under load reduces the voltage by around .04 volts. (is this normal?).
Obviously the relay accepts a fairly small connector and if you were to recommend say 10mm square wire can you get a connector for this to connect to the relatively small relay?
Also what fuses do people recommend? I would be looking at around 30amps?
Thanks in advance
Chris.
Advertisement
ThreadID: 54157 Replies: 7
Views: 1252 FollowUps: 15
AnswerID: 285189   Submitted: Saturday, Feb 02, 2008 at 18:36
MEMBER - Darian (SA) replied:
Interested in the age and specific model of your Waeco - my CF60 has just been in for a warranty repair - playing up with low voltage response when voltage was ok - the techs here (I'm def. not one) may want to know exactly where you are measuring your voltages ?
Click Image to Enlarge
By the time I'm too old to go bush, I'll have all my gear set up just right !
Reply 1 of 7
FollowupID: 550004   Submitted: Saturday, Feb 02, 2008 at 18:41
Cobes posted:
Hi Darian,
My waeco is a cf50 Ac vera and about 2 years old.
I am measuring the voltage whils't under load from a junction box in the rear of the car that has three hella sockets on it?
Chris.
FollowUp 1 of 5
FollowupID: 550010   Submitted: Saturday, Feb 02, 2008 at 19:05
MEMBER - Darian (SA) posted:
From my measurements with my budget meter, there is a sig voltage drop in the genuine Waeco 12V power lead too. So I check my voltage at the point where the lead plugs into the fridge, by spiking the sharp meter probes in through the cable insulation and contacting the copper strands inside - non destructive in my view, but tells the story (or seems to) while the fridge is running.
FollowUp 2 of 5
FollowupID: 550044   Submitted: Saturday, Feb 02, 2008 at 21:37
franku posted:
Darian,
I too have a CF60 which is about 9 months old.
There is a KNOWN FAULT with them - some of them - not all of them because a mate of mine with a 5 month old one did not have the issue have a problem with a special fuse which is soldered onto a board.
This $1 part neds to be replaced which is probably what you had done.
The symptom is that the "error light" will flash even with a fully charged battery with even zero voltage drop.
What actualy happen is that the compressor starts up - as soon as it winds up to 4.5AMP current draw it shuts off - so it cycles on and off constantly. This had about a 45% increase in amp hour draw over 24 hours on mine (monitored on a Xantrex Battery Monitor).
Also, Put it in Turbo mode and the compressor winds up to 7.5 AMPS and shuts down within 1 minute and wont stay on and the rror light comes on too.
Since it has been fixed with the new fuse, when in turbo mode, the compressor will stay on until it gets down to the set temperature.
If people out there have a CF60 - I suggest they check theirs before their next buig trip - it had a major impact on amp hour consumption.
FollowUp 3 of 5
FollowupID: 550094   Submitted: Sunday, Feb 03, 2008 at 09:58
Yep - even with plenty of voltage in the supply, mine was continually moving to "low voltage error mode" - one flash - but only in hot weather (when you need it most) - cooler weather was fine. Following reports here, I spoke directly with Waeco and they referred me to an approved repairer in Adelaide - I have the fridge back and it seems to be happy, but I have not been posted the actual repairer's report yet. It has been suggested that the whole PC board has been replaced. Whatever - I'll find out soon I guess.
FollowUp 4 of 5
FollowupID: 550237   Submitted: Sunday, Feb 03, 2008 at 16:52
Member - Frank U (QLD) posted:
They may have replaced the whole board - the first repairer I called said that I did not know what I was talking about - there is no known faults and they would be replacing the board he thought depending on what they found when they look at it.
This would obviously fix it because the fuse is on that board.
The scond one - which I took it to, knew all about it and fixed it the same day because they just replaced that faulty componentrather than replacing the whole board...
Either way - I reckon yours will be fine now :)
EURO ONE PIECE HEADLIGHTS High/Low Beam ONLY PARK LIGHTS TURNED ON
Regards,
Frank
FollowUp 5 of 5
AnswerID: 285195   Submitted: Saturday, Feb 02, 2008 at 19:14
Derek from Affordable Batteries & Radiators replied:
Hi Chris
If your wire is true 6mm2 core it would be fine but if it is 6mm automotive cable which is actually 4.58mm2 it would be too light for 2 fridges.
Here is a formula for voltage drop. Ideally we don't want more than 0.15V drop for a fridge.
Voltage drop equals (cable length (in metres) X current (in amps) X 0.017) divided by cable CROSS SECTION in mm.sq.
Lets take the 2 fridges running at the same time. Lets say 6 amps once they have started up. I would say your cable run is closer to 5m in a patrol.
5m x 6a x 0.017 / 6mm2 = 0.1v drop
using the same formula on 4.58mm2 (6mm Automotive cable) = 2.35V drop.
This could be your problem.
If your cable is true 6mm2 and not 6mm automotive then the relay or other joins / crimps / plugs are causeing the drop. Failing which have the fridge tested as some Waeco's need a modification done.
Derek.
ABR - SIDEWINDERABR - SIDEWINDER
Business Member: My Profile
Reply 2 of 7
FollowupID: 550014   Submitted: Saturday, Feb 02, 2008 at 19:17
Cobes posted:
Hi Derek,
thank you for your answer.
Upon closer inspection the cable is labelled 10AWG??
Is this the same as 6mm?
Chris.
FollowUp 1 of 6
FollowupID: 550045   Submitted: Saturday, Feb 02, 2008 at 21:44
Member - Mike DID posted:
Yes, 10AWG is pretty close to "6mm" although it depends on how cheap the manufacturer wants to get - 6mm outside insulation diameter tells you nothing about how much copper should be in it.
Mike R
FollowUp 2 of 6
FollowupID: 550048   Submitted: Saturday, Feb 02, 2008 at 22:07
Derek from Affordable Batteries & Radiators posted:
10 AWG is 5.3mm2 and not suitable for your application.
Here is a link to a great calculator. Derek's Link to AGW
conductor size 10 AWG
area 5.261 mm^2 (square-mm)
area 10383 CM (circular mil)
diameter 117.7 mil (1)
diameter 2.989 mm (1)
DC-resistance 0.00334 Ohm/m
tensil strength 157.83 kgf (2)
weight 46.772 kg/km (Cu)
weight 14.205 kg/km (Al)
construction: stranded
Note: lay factor of stranded conductor is assumed 2 %.
Note:
1. diameter of stranded conductor is an approximation.
2. tensil strength of crimped terminal is about 60 % of conductor.
FollowUp 3 of 6
FollowupID: 550053   Submitted: Saturday, Feb 02, 2008 at 22:30
franku posted:
Hi Derek,
Can you explain to me how you get 2.35V drop on 4.58mm2 wire in the above example?
I get this...
5m x 6a x 0.017 / 4.58mm2 = 0.11v drop ?
FollowUp 4 of 6
FollowupID: 550078   Submitted: Sunday, Feb 03, 2008 at 08:55
Sorry typo.
Try this automatic calculator.
Voltage Drop Calculator
FollowUp 5 of 6
FollowupID: 550140   Submitted: Sunday, Feb 03, 2008 at 12:04
Here is another one that is easier to use.
Voltage drop calculator 2
FollowUp 6 of 6
AnswerID: 285197   Submitted: Saturday, Feb 02, 2008 at 19:32
Jim from Best Off Road replied:
Try this, use welding cable. It is expensive by wire standards, but 5 or so metres won't break the bank. Considering the outlay on a fridge, dual battery etc, a little more on robust cable is a drop in the ocean IMHO.
You will experience NO voltage drop.
Best Off RoadBest Off Road
Trader: Drawers
Reply 3 of 7
FollowupID: 550075   Submitted: Sunday, Feb 03, 2008 at 08:40
Member - JohnR (Vic)&Kath posted:
The 32mmsq wire I am using to the rear of Kath is heavier than some welding cable Jim. Got to pare it to get it into Anderson plugs but that is of no consequence, soldered with heat shrink over it.
On the way to Gemtree
Who?
Multi famam, conscientiam pauci verentur
AnswerID: 285226   Submitted: Saturday, Feb 02, 2008 at 21:55
Member - Mike DID replied:
"My current wiring from the aux battery runs via a relay which under load reduces the voltage by around .04 volts. (is this normal?). "
- yes
"Also what fuses do people recommend? I would be looking at around 30amps?"
- the fuse rating must be LESS than that of the thinnest wire fed by it. 8 Gauge (8mmsq) is rated at 55 amps and 6 Gauge (13mmsq) is rated at 75 amp.
Mike R
Reply 4 of 7
FollowupID: 550240   Submitted: Sunday, Feb 03, 2008 at 16:55
For Fridges - I found MAXI FUSES the best - fuses themselves can and do cause resistance...
Using a normal blade fuse caused resistance - MAXI FUSE on the other hand was not measurable.
Regards,
Frank
Activities Index
Stunt Driving Experience - VIC Stunt Driving Experience - VIC
Melbourne - VIC
This is the only stunt driving course of its type anywhere in the world!
Revitalising Facial - 60 minutes Revitalising Facial - 60 minutes
Sydney - NSW
Why not indulge in a revitalising facial that restores firmness and improves the elasticity of the s
Rock Climbing at Kangaroo Point - 3 Hours Rock Climbing at Kangaroo Point - 3 Hours
Brisbane - QLD
Ever wanted to try something really exciting?
Fun Pass - Warner Bros Fun Pass - Warner Bros
Gold Coast - QLD
The Theme Park Pass for short breaks!
Book Now - Things To Do
AnswerID: 285247   Submitted: Sunday, Feb 03, 2008 at 06:36
Shep replied:
Hi Chris, I had similar issues with my CF50, I forund after replaceing the supply wire I still had issues, I found the waceo house lead was getting hot at the connection of the fridge (heat =energy) I cut the pug off and wired it direct to the wires on the PC board and another find I found is the the plug active which goes into the power socket that was of a small round type spring loaded button was not really making good contact, I found the plug on an inverter had a flat type spring loaded active which would make a better contact in the socket , brought one of these from Jaycar and replaced and replaced the waceo plug, Issuse Resolved.
Hope this helps
Craig
Reply 5 of 7
FollowupID: 550241   Submitted: Sunday, Feb 03, 2008 at 16:56
Anderson connectors are the best connector to use instead of that ciggarette lighter style one - Andersons are Zero loss - ie. no resistance - no voltage drop and self cleaning.
Regards,
Frank
AnswerID: 285250   Submitted: Sunday, Feb 03, 2008 at 07:21
Ray replied:
Although a bit off the subject. I am considering running 8 ASWG cable from my car to the Electrolux 3 way fridge in the caravan. I may have to make my own crimps to connect to the relay. How can I partially overcome the voltage drop at the solenoid?????
Reply 6 of 7
FollowupID: 550242   Submitted: Sunday, Feb 03, 2008 at 16:58
Now, an Electrolux 3 wau fridge uses a lot more power than a Waeco - check the specs of that Fridge and size the wirig accordingly - what works for a Weaco will be well and truly undersized for a 3 way.
Regards,
Frank
AnswerID: 285254   Submitted: Sunday, Feb 03, 2008 at 08:10
Mainey (wa) replied:
Cobes
I use 10mm² cable from battery to the actual fridge compressor, a distance of about 1.7 Mtrs.
My fridge draws ~8 Amps.
I get 0.4v drop at the compressor (fridge running)
the fridge power is supplied via the Steca Solar regulator, so it's not direct off a battery.
Mainey . . .
wake behind the Stacer 420 SeaHorse
* check-out how SÔLAR PÔWER & ¹² Vølt Batteries will work *
click-> "My Profile"
below
Reply 7 of 7
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
