Problems with 1HDT
Submitted: Thursday, Jun 12, 2003 at 11:28
SteveA
Recently had injectors done on the 80 series, cost arm and leg but after the injectors were removed, tested, serviced and refitted I have found my fuel consumption (was 8.75k's to the litre now 8k's to the litre) has increased and it get the kangaroo hops at 1600 to 1800 rpm.(Getting bloody annoying)
Taken back to the repairer he suggests that it has nothing to do with the injectors being serviced but the injector pump (governer within the injector pump) that is the problem.
I find it just a little too coincidental that the injector pump starts to play up straight after the injectors are done.
Feedback would be very appreciated
Steve
Reply By: Truckster (Vic) - Thursday, Jun 12, 2003 at 11:57
Where did you have the work done??? interested as Im due to have my injectors done next week.
If you have questions, the lastest 4wd mthly has an article on West End Diesel.. I called them, and being a nuffy on Diesels, they took the time to explain bleep to me..
Id call Devish there and ask his opinion, he has 14 yrs experience, so sort of knows his stuff.
West End Diesel
Services (NSW)
26 Davis Rd
Wetherill
Park
(02) 9757 2100
OR...
(02) 9757 2200
Mob Service 0412 309 969
22352
Follow Up By: SteveA - Thursday, Jun 12, 2003 at 12:41
I'm in
Brisbane area Truckster, Rocklea Diesel Injection Service did the the job
thanks for the info and I'll give them a call
thanks Steve
14693
Follow Up By: KiwiAngler - Thursday, Jun 12, 2003 at 16:07
I would also recommend Devesh at West End...he(they) have really looked after me and my Toyota 4.2lt Turbo...carry out all my work and service needs.....suggestion for all...get a dyno done BEFORE you get any work done and then get one after....you will see your $$$$ working for you...no guessing or subjectiveness required...hard cold facts...mind you pretty scary sitting in the passenger
seat strapped to the dyno bed and seeing the speedo at 120k!!!!!!!!
They explain everything and are all a great bunch.
14700
Follow Up By: Truckster (Vic) - Thursday, Jun 12, 2003 at 16:23
"...mind you pretty scary sitting in the passenger
seat strapped to the dyno bed and seeing the speedo at 120k!!!!!!!! "
120 kph or mph??
14701
Follow Up By: KiwiAngler - Thursday, Jun 12, 2003 at 16:28
120 Km/Hr...metrics have arrived...even in Australia :-)
14703
Follow Up By: Truckster (Vic) - Thursday, Jun 12, 2003 at 16:30
was wondering what was scarey@120kph thats all...... thought you must have meant mph...
ymmv
14704
Follow Up By: KiwiAngler - Thursday, Jun 12, 2003 at 16:34
Yeah 120 on its own shouldnt be a prob..we all do that on the move everyday...it was the fact that all there was holding almost 4 tonne of metal in place was a couple of straps (albiet fairly grunty ones) I just had a mental pic of the
wheels 'slipping' off the rollers...grabbing the floor and catapulting me through the back wall :-)
14705
Follow Up By: KiwiAngler - Thursday, Jun 12, 2003 at 16:41
PS
what does the 'ymmv' at the bottom of your message mean?
14706
Follow Up By: Truckster (Vic) - Thursday, Jun 12, 2003 at 16:42
YMMV
Your
Mileage
May
Vary ;)~
14707
Reply By: Member - Andrew- Thursday, Jun 12, 2003 at 14:58
Aswell as injecters, they would have changed filters aswell surely, so that is a variable aswell. Some guys on the landcruiser list run a lift pump aswell at the
tank to help the fuel get to the pump. It assists the pump to give full advance and makes the motor produce as much power as s possible, so might be worth a look. Also, there might be some algai in your
tank, so dose the fuel with Nissan fuel treatment, (comes with algai inhibitor) and then change the filter the next
tank full. Pull it appart looking for green gunge in the bowl after removing filter.
Andrew wheredayathinkwer mike?
22356
Reply By: desert - Friday, Jun 13, 2003 at 20:09
Yeah have heard of this before. Basically the engine is spinning up quicker and cleaner now that the injectors are atomising the fuel correctly. The tired and worn pump(remember it is the same age as what the injectors were) is having trouble governing the speed ramp up due to it being, behind the eight ball so to speak. It will probably not get better and with the phase in of low-sulphur, you may pay to have the pump reconditioned now sooner than later. Budget around $1000. The suggestion of a before and after dyno reading is also a great way to be able to come back to the diesel
shop and say, hey, since you blokes touched it, it's lost power.Whats going on? They have no excuses, but to rectify the anomaly.
22464
