200 Series Twin battery setup - Advice
Submitted: Sunday, Feb 03, 2008 at 21:58
ThreadID: 54207 Views:6617 Replies:6 FollowUps:7
The 200 comes with a twin battery set up. I want to set it up to run one battery as a second to power the Engels etc. Have conflicting advice - Auto electrician advises no problem splitting the two with solenoid between, one will be primary battery etc. Two different 4WD shops told me you shouldn't touch the existing set up, but add a 3rd battery to run the Engels (apparently they can squeeze one in near the passenger side engine bay - moving some components). I am cautious, the Auto lecy is doing some consulting to ensure I can split the existing set up, in the interim, anyone out there have experience with the new 200 series who can assist??
Many thanks
TD
Reply By: Gone Bush (WA) - Sunday, Feb 03, 2008 at 22:04
Have a look on LCOOL, on both the 200 series and 100 series sections.
AnswerID: 285445
Reply By: Member - Mike DID - Sunday, Feb 03, 2008 at 22:23
In Japan and other very cold countries the Pajero Diesel comes with two batteries - elswhere with one.
Where there are two batteries they are just wired in parallel.
AnswerID: 285451
Reply By: chardthechippy - Sunday, Feb 03, 2008 at 22:46
Gday Terry,
I would be leaving the dual batt set up alone mate, that is one beast of a motor to crank!!
Huge compression and cold starts after a night opening the engels continuously would be leaving you stranded. Remember starting a diesel isn't just a quick turn of the key, you should be leaving the ignition in the on position for a five or a ten count before starting. A lot of circuits open and pumps start drawing power in that short time.
I don't know your fridge size or camping requirements but if you intent on starting the V8 in the morning I would be investing in a third battery isolated from the two crankers for sure.
I don't suppose your initials has anything to the engine choice.LOL.
Cheers Chard.
AnswerID: 285455
Follow Up By: Willem - Sunday, Feb 03, 2008 at 23:32
>starting a diesel isn't just a quick turn of the key, you should be leaving the ignition in the on position for a five or a ten count before starting. A lot of circuits open and pumps start drawing power in that short time.<
That is the first time I have ever heard that. You must have gained that knowledge from a higher authority.
BTW I believe the new LC 200 has a Push Button start. My GQ has one as well. Just flick a switch and press the Go button.
FollowupID: 550355
Follow Up By: Member - andrew B (Kununurra) - Monday, Feb 04, 2008 at 11:48
I would agree with the cold climate thing, and I'm sure the one battery will start the engine (it can't be much harder to turn over than the engine in the utes, and I'm pretty sure the ones at work only have the one battery
Cheers Andrew
FollowupID: 550436
Reply By: Mainey (wa) - Monday, Feb 04, 2008 at 10:01
Terry,
Ever wondered why the 200 comes with a twin battery set up?
Maybe the manufacturer fits the second battery because they buy them really cheap and just want to get rid of them, nahh probly not lol.
The ""two different 4WD shops told me you shouldn't touch the existing set up"" so why not believe them, can they can explain why not ?
I have NO personal experience with the vehicle, however I have a small amount of experience with batteries, I even know aa is smaller than aaa, cause one a is missing, lol.
My advice, use an AGM Deep Cycle battery
place it in a battery box in the vehicle, near the fridge
Mainey . . .
AnswerID: 285490
Follow Up By: Member - andrew B (Kununurra) - Monday, Feb 04, 2008 at 11:51
aa is bigger than aaa......, must have smaller a's LOL, is there an a size, and a b size, or does it go aaa, aa, c, d ????
Cheers ANdrew
FollowupID: 550439
Follow Up By: Member - Andrew (QLD) - Monday, Feb 04, 2008 at 12:26
don't forget AAAA....found within 9v batteries. :-)
FollowupID: 550450
Follow Up By: Member - Andrew (QLD) - Monday, Feb 04, 2008 at 12:28
......."some" 9v batteries
FollowupID: 550451
Reply By: Member - joc45 (WA) - Monday, Feb 04, 2008 at 12:55
A couple of observations;
The two batteries are probably there to cope with very cold start situations. The 4.5 V8 motor is not much bigger than the Nissan 4.2 diesel, which has higher compression than the V8, and that starts ok with a single N70 battery.
But, knowing manufacturers, if you change their wiring configuration, and if you have an electrical fault, or it's hard to start, they will knock you back on warranty. They will probably even blame that for the back wiper or the audio system not working.
If the vehicle was out of warranty, I'd have no hesitation in reconfiguring the batteries, one for start and one for aux.
But...I've found that even as a technical person, arguing a technical issue with a dealer is like arguing evolution with a creationist.
just my thoughts, Gerry
AnswerID: 285517
Reply By: Member - Alan H (Narangba QLD - Monday, Feb 04, 2008 at 16:09
Question was asked on another fourum about extra battery and warranty problems.
TOYOTA H.O. CONTACT RESPONSE...
Toyota published information relating to modifications is:
Toyota New Vehicle Warranty will not apply to any non genuine part or accessory, nor to an original component or accessory if a failure occurs that is attributable to a modification or to a non genuine part.
Additional comment:
Toyota would not usually specify any particular modification in regard to any “blanket ban” on warranty coverage, and can only provide specific information and advice in relation to genuine Toyota vehicle components and accessories. It is essential that owners considering modifications to Toyota vehicles ensure they are carried out only by expert suppliers who can demonstrate a full understanding of, and will accept responsibility for, any impact of the modification on the vehicle systems and components.
To assist forum members, the following observations are made in regard to fitting an additional battery to the LC200 1VD-FTV common rail diesel engine version (w/dual battery std.equipment)
• Space in the engine bay is very limited and, critically, the engine wiring harness connectors to the main engine ECU are located at the firewall at the rear passenger side. It is essential that no interference or loading is placed on the wiring harness and/or on these connectors if an additional battery is located into this very limited space.
• Other components in this area include electrical junction box, the fuel filter/sedimenter, the EDU relays / injector drivers (300V output) - very careful consideration required if relocating these parts.
• Mounting additional batteries on inner fender panels applies significant additional loadings, especially if operating in severe conditions - panel cracks may occur.
As a possible alternative to fitting an additional battery in the engine bay, consideration is being given in the aftermarket industry to upgrading the original LC200 55Ah dual batteries with batteries of similar or more capacity to the single 65Ah battery fitted to the LC 7# with the basically same 1VD-FTV engine. (Same capacity /compression ratio, reduction type starter motor etc, - additional battery capacity provided on LC200 to cope with the many additional electrical systems). (LC 7# w/1VD has 1560watt alternator - LC200 w/1VD has 1800watt.)
The LC200 drivers side battery is wired in parallel to the passengers side battery which is connected directly to the vehicle electrical systems. The proposals noted consider using the addtitional capacity of an upgraded battery on the drivers side to power accessories, in conjunction with low voltage cutout and suitable isolator to protect the passenger side battery capacity for starting.
In considering any such modifications, owners are again urged to engage only expert suppliers who can assure a complete understanding of the vehicle electrical systems and specifications.
end
AnswerID: 285552
Follow Up By: Member - Terry D (QLD) - Monday, Feb 04, 2008 at 19:52
Alan H
Thanks for your very informative comments - thanks also to everyone else for commentary. I think my cautiousness over this issue was well founded given the comments. Whilst I am leaning towards splitting the existing set up with battery upgrade to drivers side, I will further consult with my auto electrician (will show him the comments) and also discuss with Toyota when I take it in for the 1,000k service (next week or after).
Once again thanks
TD (Not short for Turbo Diesel)
FollowupID: 550599
Follow Up By: Gone Bush (WA) - Monday, Feb 04, 2008 at 19:56
Alan what Forum was that?
FollowupID: 550602
