Nissian 4.2 or 3 ltr common rail
Submitted: Tuesday, Feb 05, 2008 at 21:13
Member - Colin P (SA)
Can any one tell me which is the best motor to constantly carry a 1000k loan in the form of a slide on camper. I will buy one or the other tomorrow or the next day. I have a 2005 Navara 3 litre so I now how that performs in a slight head wind. Back to 4th gear
on a flat road. Will the 4.2 be a better option (2007) model or the new common rail 3 ltr.
Would appreciate help. I know this has been talked about many times. Can someone point me to the right thread to save you time.
Many thanks Colin
Reply By: blue one - Tuesday, Feb 05, 2008 at 21:21
4.2
285844
Follow Up By: Member - Colin P (SA) - Tuesday, Feb 05, 2008 at 21:34
Thanks Blue. Have you got one and how does it pull in a head wind? Do you drop back to 4th when carrying 1000 Klgs. Pulling in a head wind is not a lot of fun.
Colin
550841
Follow Up By: blue one - Wednesday, Feb 06, 2008 at 21:10
Well the 3 ltr went boom.
The 4.2 is a reliable beast I can take into remote
places.
551055
Reply By: TrevorDavid- Tuesday, Feb 05, 2008 at 21:31
Colin, i am no expert but i reckon you answered you own question.
TDB
285850
Follow Up By: Member - Colin P (SA) - Tuesday, Feb 05, 2008 at 21:39
Thanks Trevor.
Colin
550846
Follow Up By: Truckster (Vic) - Tuesday, Feb 05, 2008 at 23:30
yes he did answer his own question since ther are no more 4.2's.... And none in dealers. What there was has gone.
"Will the 4.2 be a better option (2007) model"
But you would go used 4.2 before buying a grenade.
550879
Reply By: Member - Derek L (QLD) - Tuesday, Feb 05, 2008 at 21:31
Colin 4.2 TD it will be easier to drive plus it will last longer.
285851
Follow Up By: Member - Colin P (SA) - Tuesday, Feb 05, 2008 at 21:38
Dear Derek,
Thanks for your reply. If you have the time could you explain what you mean by easier. Thanks - Colin.
550845
Reply By: Leroy - Tuesday, Feb 05, 2008 at 21:32
the 4.2 with a
beaudesert exhaust and a tune. (yeh I know it's a new vehicle)
Leroy
285853
Follow Up By: Member - Colin P (SA) - Tuesday, Feb 05, 2008 at 21:43
Leroy,
You have obviously done this. If you have the time can you tell me more or have you written on the
forum before about the changes.
Colin.
550848
Follow Up By: Leroy - Tuesday, Feb 05, 2008 at 22:02
I personally haven't done it as I have a 3lt. I drove my mates before he did the exhaust and tune and I thought what a pig of a vehicle. He almost traded it in on a 3lt and decided to do the exhaust and tune at Diesel tek in
Lilydale. What a huge difference. Chalk and cheese. The extra torque and pwr and not to mention just the drivability. I didn't want to give the vehicle back after a day driving it in the vic hc!! If you seach the
forum you will see that many have made similar coments.
Leroy
550855
Reply By: time waster - Tuesday, Feb 05, 2008 at 21:41
Toyota TD V8
I would if I could afford one
285856
Follow Up By: Member - Colin P (SA) - Tuesday, Feb 05, 2008 at 21:48
I know they are a great 4WD but my wife and I have seen the results of an accident without air bags. Until Toyota remedy that,
it is not on option. A V8 Nissan diesel is only a dream.
550849
Follow Up By: fisho64 - Tuesday, Feb 05, 2008 at 22:09
doesnt the 200 have airbags?
550857
Follow Up By: fisho64 - Tuesday, Feb 05, 2008 at 22:12
sorry, I see you talking "slide-on camper", my mistake!
550860
Reply By: Member - Derek L (QLD) - Tuesday, Feb 05, 2008 at 21:50
More torque less gear changes. Less torque more gear changes. I had a ZD 30 Patrol it was a more work driving it to keep it on boost so I didn't loose steam on the hills. I've a 4.2 TD Criuser now.
Derek
285860
Follow Up By: Andrew(WA) - Tuesday, Feb 05, 2008 at 23:16
hey..snap
me too
550876
Reply By: Member - Phil G (SA) - Tuesday, Feb 05, 2008 at 22:05
1000kg is a lot of camper.
The chassis will be the issue. Most people I know reinforce the rear spring towers on the Patrol coil spring traytops. I'd choose a leaf spring rear end, if you still have that option. Do they still make the 4.2?? I thought you could only get the 3.0 in the traytops now.
I appreciate what you say about airbags - rules the 79series out for you.
285867
Follow Up By: Member - Colin P (SA) - Tuesday, Feb 05, 2008 at 23:18
Dear Phil,
Thanks, for your reply. I am just adding up the payload. The camper weight is approx 600 kgs. With my fat old body and one other passenger, an aluminium front bar, gear on board for
camping, fuel and perhaps a tow ball down force of 100kg max ( not all the time) you could be right. I may have to go a aluminium tray, 2400mm. I wander what the ride on the leaf spring version is like without the load. Any ideas.
Thanks once again.
I will have to look into it.
Colin
PS. I know where I can get a 4.2 ltr Coil spring version near new.
550877
Follow Up By: Truckster (Vic) - Tuesday, Feb 05, 2008 at 23:31
Buy it.. rare as rocking horse, and they are increasing in value.
Get a bit of turbo work done to them, not much just pump timing and fuel and you will never look back.
550880
Follow Up By: Marn - Wednesday, Feb 06, 2008 at 10:17
Put airbags inside your coils and it will carry a ton all day long with a comfy ride to boot!
550913
Follow Up By: Leroy - Wednesday, Feb 06, 2008 at 10:49
and put more stress on the spring towers becasue they have to take/absorb the impact instead of the spring.
Leroy
550920
Follow Up By: Member - JohnR (Vic)&Kath - Wednesday, Feb 06, 2008 at 15:37
"Put airbags inside your coils and it will carry a ton all day long with a comfy ride to boot!" what crap.
Take note of what Leroy says or
the springs will fall out. Reinforce the top of the spring towers or they push out of the chassis or tear the towers themselves.
550969
Follow Up By: Member - Phil G (SA) - Wednesday, Feb 06, 2008 at 16:47
"I wander what the ride on the leaf spring version is like without the load. Any ideas."
Colin,
I haven't drive in a rear leaf patrol. But I expect that with a camper on the back, it wouldn't be any different.
My Toyota has coil front/leaf rear, and rides better than the all coil Prado I had, but it has a longer wheelbase and the leaf springs are very long.
I know a couple of people who've had their rear towers strengthened as soon as they bought their vehicles, and they have peace of mind, and no hassles with the vehicles.
550989
Reply By: TerraFirma - Wednesday, Feb 06, 2008 at 13:33
A Toyota Landcruiser 100 or 200 series or the new Hilux Turbo Diesel..! The Hilux TD in Auto does change back a gear when towing 1 tonne going up a
hill though..!
285956
Follow Up By: Member - Phil G (SA) - Wednesday, Feb 06, 2008 at 17:07
What, like this??
550996
Follow Up By: TerraFirma - Wednesday, Feb 06, 2008 at 17:21
I want one Phil...! She looks a beaut..!
550999
Follow Up By: Member - Phil G (SA) - Wednesday, Feb 06, 2008 at 17:37
Yep, not bad if you're happy with IFS. Chopping the 200series TTD would be rather nice!
Some details of this vehicle (TD 100series)
here on LCOOL.
Another one (V8 100series 5th wheeler)
here is well.
551005
Reply By: d04 - Wednesday, Feb 06, 2008 at 21:00
I bought one of the last 4.2s in wa,2006 model, no more 4.2s after this, have 3inch exhaust fitted, turbo mod done, gives me 150hp and 400 odd nm of torque, go like the proverbial shower,need to get a good
suspension done on it now to keep every thing neat and tidy on road and off.
286046
Reply By: Member - Colin P (SA) - Sunday, Mar 02, 2008 at 23:21
Hi guys,
Well thanks for your suggestions. But guess what, I missed out on a 4.2 litre and ended up buying a new 3 litre common rail cab chassis. Got a great deal from the people in Warrnambool Victoria.
Found a good tray maker in
Hamilton. Mc Ervale steel Construction, and I live in
Hahndorf South Australia but that is another thread.
Thanks for your assistance. I have arranged the air bags and a lot of other goodies.
Colin.
290506
