gu clutch advice needed
Submitted: Wednesday, Feb 06, 2008 at 10:16
ThreadID: 54295 Views:1573 Replies:1 FollowUps:1
I have had the clutch master cylinder resleeved and installed it last night,cannot see how to bleed air out of the system,pedal is low and works after "pumping"several times....have i missed something ??? any advice appreciated...its a 3litre 2002 model
Reply By: donks1 - Wednesday, Feb 06, 2008 at 11:56
hi there
you need to bench bleed it first
fill the reservoir and push the piston a few times , blocking off the outlet as it returns
then fit it to the car and bleed from the slave cylinder
alternatively you can bolt it up and bleed it on the car by pushing pedal down and "cracking" the pipe
then you still need to bleed from the slave
donks
AnswerID: 285943
Follow Up By: pepper2 - Wednesday, Feb 06, 2008 at 17:26
thankyou for your assistance
FollowupID: 551000
