rim size against weight, why.
Submitted: Sunday, Feb 10, 2008 at 16:11
Member - shane (SA)
i have a van with 15 inch rims, it has max loaded weight of 16ookg.
i have been told that if i put 16 inch rims on, it will decrease the max load weight. is this right and if so WHY?
Reply By: desert - Sunday, Feb 10, 2008 at 21:27
Only suggestion I could throw up is the increase in unsprung weight of the 16 inch
wheels. Unsprung plus sprung weight plus tare weight = gross vehicle weight. But it could only be the difference between the weight of the tyre/wheel assembly 15 verses 16 inch. I would not think we would be talking much more than 10 kg. total?
286787
Reply By: Member - Jiarna (NT) - Sunday, Feb 10, 2008 at 21:43
I'll
hazard a guess, but it is only a guess...
If you maintain the same rolling diameter with the 16" rims as you have with the 15" rims, you will have lower profile tyres. I expect that the lower profile tyres will have a decreased load rating, and hence reduce the load rating of the axle.
286794
Reply By: Member - Phil G (SA) - Sunday, Feb 10, 2008 at 21:57
The load index of most 16inch tyres is greater than the load index of 15 inch tyres. I'd suggest that your source is incorrect.
286799
Reply By: hotfishez - Monday, Feb 11, 2008 at 10:41
In my experience, a bigger tyre not rim will carry a load better.
286852
Reply By: hotfishez - Monday, Feb 11, 2008 at 10:46
Changing the rim size will not effect the load rate as the rate is governed by the build of the van and spring capacity. As for towing weight, the different size will not effect anything aside from the height. In my opinion, I would go for a wider tyre if it is a major concern, it will carry the weight better.
286854
