Vehicle to tow an 18Ft Pop top
Submitted: Sunday, Feb 10, 2008 at 22:40
bing
I tow an 18 Ft Jayco Pop Top Van and am looking to buy a new vehicle. I am thinking about a 4X4 3.0 Litre Turbo Diesel. Any ideas about this type of vehicle for this job?
Reply By: Notso - Monday, Feb 11, 2008 at 07:08
A lot depends on the towing capacity of the vehicle, for instance a 3.00 Patrol will tow up to 3.5 tonnes, a prado will tow around 2.5 tonnes so you need to look at your ATM Of the Van which is probably less than 2 tonne so either one of the vehicles mentioned will tow it.
If the ATM is up around 2.5 tonnes then you should go to a vehicle with a higher capacity than the Prado as it would be right at it's limit.
286829
Follow Up By: Member - Peter R (QLD) - Monday, Feb 11, 2008 at 08:20
Bing, I tow a 17' Jayco Poptop , loaded weight around 1.7t with 2007 Prado D4D and it tows it easily.
Much better than with my old 94 80series.
Pedro
552062
Follow Up By: Ircon - Monday, Feb 11, 2008 at 12:05
3.0L Patrol is rated for 2500 kg with Auto transmission. 3.500 with manual transmission . (I think)
Rosscoe
552083
Reply By: Nav 8 - Monday, Feb 11, 2008 at 12:58
The Navara ST-R or ST-X rated at 3000 Kg tow capacity will also tow it with ease. Nav.
286865
Reply By: jeepthing - Monday, Feb 11, 2008 at 14:46
Take a Jeep Grand Cherokee or a Commander CRD V6 3.0l turbo diesel for a test drive. 160kw and 510nm of torque towing capacity of 3500kg ball weight of 375kg...you'll get a shock at the performance, comfort and power of these things :)
I tow a 6m boat weighing close to 3 tonne and it walks it in.
286880
Reply By: Member - Bob C (NSW) - Monday, Feb 11, 2008 at 16:56
Hi bing
Spare a thought for a Kia
Sorrento 4x4. Rated to tow 2800kg with 280ball weight. I just bought one but haven't towed with it yet.They had a good review as a tow vehicle and are very competatively priced
New Member Bob
286907
Reply By: Jim from Best Off Road - Monday, Feb 11, 2008 at 18:42
The most economical way to tow is with a Petrol 4wd fitted with LPG.
If you have your heart set on Diesel, the Terracan 2.9L CRDi is a lot of vehicle for not a lot of money.
Jim.
286923
Follow Up By: Shane (QLD) - Tuesday, Feb 12, 2008 at 16:21
Jim,
The Terracan has now been discontinued, although there might be a few around.
552290
Reply By: Shane (QLD) - Tuesday, Feb 12, 2008 at 16:25
Might pay to look for a different brand of towing machine unless you want that lingering doubt about completing your journey each time you use the vehicle.
287068
Reply By: BMKal - Wednesday, Feb 13, 2008 at 03:57
Landrover Discovery -
either a D2 with the 2.5 litre TD5 or the new D3 with the 2.7 litre TDV6.
Either will do it standing on its ear.
Prado 3.0 litre D4D is also a good choice, but make sure you go for the new D4D engine - the older 3 litre was a good engine, but nowhere near the same grunt and a bit on the thirsty side.
Nissan - the new Navara / Pathfinder diesel is
well regarded - haven't driven one myself so can't really comment. The 3.0 litre Nissan engine in the Patrol -
well there's plenty of bad press on them both in this
forum and in many others - I'd steer
well clear.
My choice would be the Discovery - but I'm biased - I am on my second one after four Prado's.
287190
