Holden Frontera Rear wiper relay board
Submitted: Tuesday, Feb 12, 2008 at 14:57
ThreadID: 54500 Views:5619 Replies:1 FollowUps:0
Hi All
Can anyone help with the location of the rear wiper motor relay board.
I am told that it is behind the glove box but all I could find were 2 units one with Honda key alarm or somthing similar held in by 2 screws and another unit held in by 1 screw and a clip which appeared to have abs alarm or somthing on it.
Can anyone advise if it ws one of these units and if so what would be the change over procedure.
Told that I had to change over because the rear wiper blade stops mid way on the window or doesn't go at all so had to remove the blade assembly.
Reply By: DIO - Tuesday, Feb 12, 2008 at 18:12
Suggest you might try this Link. It will put you in touch with other Holden (range) owners Frontera etc. I'd be careful playing around with anything ABS or SRS (Air Bag controller) boxes. Could have catastrophic outcome in an emergency.
AnswerID: 287089
