Is it possible?
Submitted: Wednesday, Feb 13, 2008 at 17:43
ThreadID: 54548 Views:2501 Replies:5 FollowUps:5
Neighbour just dropped by and in talking about caravans, is it possible to swap a 100 series L/C hub on to an 80 series axle or vice versa ? We know a 100 series is 5 stud and 80 is 6 stud but are the axles the same- I'm pretty sure they are not.
Thanks blokes & ladies
Cheers Nick.
Reply By: obee - Wednesday, Feb 13, 2008 at 18:38
you have to ask why they would change something that works already but I have given up.
Owen
AnswerID: 287302
Follow Up By: Nickywoop - Wednesday, Feb 13, 2008 at 19:29
Owen,
He is looking at a van with ioo series wheels on and wants to know if he bought it could he match them up the 80 series he would tow it with.
Thanks Nick
FollowupID: 552516
Follow Up By: obee - Thursday, Feb 14, 2008 at 08:36
sorry, I was talking about the manufacturers. They keep changing things that are better left alone.
Owen
FollowupID: 552622
Reply By: Member - reggy 2 (VIC) - Wednesday, Feb 13, 2008 at 20:49
HI NICK
I HAVE A VAN WITH 80 SERIES HUB PATERN COULD BE INTERESTED IN A SWAP IF BEARINGS AND DRUM SIZE WERE SAME DEPENDS WERE YOU ARE OF CAUSE
REGGY2
AnswerID: 287330
Follow Up By: Nickywoop - Thursday, Feb 14, 2008 at 09:16
Hi Reggy2,
I'll see me neighbour Friday nite, he's coming over for a BBQ.
He's 30 k's from here so will show him this thread then as he hasn't got a computer.
Thanks Nick
FollowupID: 552631
Reply By: Member - Derek L (QLD) - Wednesday, Feb 13, 2008 at 22:47
Nick what ya mate needs to look at what rim offset they are. Are they off narrow or wide chassis hundy? If they are off a narrow (deep lookng dish) they might work and he werent have to change the axle lengh if they are off a wide chassis (shallow looking dish) hundy they wont work the rims will rub on the chassis rails of the van then you wiil have put in a longer axle.
Hope it helps
Derek L
AnswerID: 287357
Follow Up By: Nickywoop - Thursday, Feb 14, 2008 at 09:18
Thanks Derek, Will pas that on fri. nite
FollowupID: 552632
Reply By: Ingtar - Wednesday, Feb 13, 2008 at 23:24
If it is the axles on a caravan they should match. Best would be speak to a trailer place, there tend to be only a couple of bearing patterns and they stock different hubs (and hence stud patterns) to fit these standard axles.
The comment on offsets is a good one though.
AnswerID: 287370
Reply By: Sand Man (SA) - Thursday, Feb 14, 2008 at 17:07
I would expect it would be much cheaper to swap the hubs on the van to match the six stud pattern on the vehicle.
Bill
AnswerID: 287479
Follow Up By: Nickywoop - Thursday, Feb 14, 2008 at 19:52
Sandman,
That's exactly what he wants to do, swap 100 series rims on the caravan to 80 series like his vehicle that tows it.
regards Nick
FollowupID: 552758
