Fuel
Submitted: Sunday, Jun 15, 2003 at 15:58
ThreadID: 5462 Views:2291 Replies:6 FollowUps:5
Hello
Does any one know the average fuel consumption of Nissan Gu 4.2D Turbo towing a trailer out in the back blocks.
Thank's
Darren
Reply By: Michael - Sunday, Jun 15, 2003 at 17:11
Hi Darren, i covered about 12,000 ks on a trip to the middle and northern Queensland in my GU 4,2 turbo when it was only a few thousand ks old, I think i was gwtting about 600/650ks out of both tanks , around 115 litres. Family of four, all the gear, trailer 550kg plus gear, Patrol laden the the hilt,90 litre Liemack fridge.
HEAVY I'D SAY.. Regards Michael.
AnswerID: 22571
Follow Up By: Darren - Sunday, Jun 15, 2003 at 20:01
Thank's Michael, I'm intenting to go from Kalgoorlie-Brisbane via Uluru & Donuhue Hwy, then down East Coast and back across by the Nullarbor. And as you with family of 4 and laden to the back teeth.
Darren
FollowupID: 14908
Reply By: Member - John- Sunday, Jun 15, 2003 at 19:12
Darren,
My work GU 4.2TD coil cab (about 3500kg all up) generally gets about 15lt/100km. All of it in the Kimberley, about 80% of the kms at 110-120kph on the highway.
It's not really an issue as any diesel fourbie of this weight is going to be using at least this much fuel in any conditions.
Only cripe with the GU is that Nissan changed the gearbox from the original GQ bulletproof version to one with a weak 5th gear. Many GU's in the Outback use lose 5th gear every 30,000 - 40,000km and Nissan keeps on fixing them under warranty but not addressing the real cause (bad design of a hard worked part in Aust conditions).
Endless hours with a heavy loads at highway speeds at 40+ degree temps seems to be the 5th gear killer. When it goes metal shards will fly around and take up residence in all the bearings, so Nissan will usually agree to a complete change over of all bearings as well as the 5th gear.
This is a sad situation for a vehicle wih an excellent bullet proof drive train. We hope Nissan fixes this issue quickly. Put the GQ gearbox back in??
JohnS
AnswerID: 22581
Follow Up By: desert - Monday, Jun 16, 2003 at 08:37
Mate, Nissan did not "change the bulletproof gearbox of the GQ". A manufacturing tolerance problem krept into the production of the mainshaft/fifth gear assembly, which is made by a gear supplier Not Nissan, and the first Nissan knew about it was when they started failing.The fault has now been identified and all subsequent parts are correct to plans. Where Nissan Motor Co has blood on it's hands, is not calling a general recall to fix ALL vehicles. For every vehicle that they do not have to repair (eg, those that rarely get into 5th, ie city work) Nissan saves about $1100 per unit.
Essentially, the gearbox design has not changed since series two GQ that deleted the PTO outlet off the side of the box.
FollowupID: 14937
Reply By: Darren - Sunday, Jun 15, 2003 at 20:15
Thank's John, Have heard of this problem. Still waiting to get to that 30-40,000 mark see what happen's on this trip.
Darren
AnswerID: 22585
Reply By: Michael - Sunday, Jun 15, 2003 at 20:27
Hi darren & John, if you look in the archives on the fifth gear problem, its only about 9months of builds, around 2000 to 2001 i think, just wrong machining clearances, check it out, someone goes into good detail about the problem. As a comparison with the figures i gave you earlier, i drive from Mittagong to Sydney daily and get 900 ks from both tanks till the idiot light comes on, i gather there would be 10 litres left then, so 900ks for 115 litres, highway running. Cheers Michael
AnswerID: 22588
Follow Up By: Darren - Sunday, Jun 15, 2003 at 22:35
Hi Micheal, Mittagong nice spot. Have done much the same mileage with the best about just over 1000k's but no trailer.
Darren
FollowupID: 14923
Follow Up By: Tony - Monday, Jun 16, 2003 at 07:24
Just as a compero Loaded to the hilt 15.2 lts per 100k.
Towing trailer only 13.4
Light touring 12.2
Unladen 10.26.
Going to church on sundays 9.9.
GU 4.2 T with intercooler. 265 75 16. and a nagging wife when i get over 130. The best range on the road has been 973k for 105.5 lts
FollowupID: 14936
Reply By: Member - Simon- Monday, Jun 16, 2003 at 07:59
Darren,
If you send me your email address I will send you an excel spreadsheet of the fuel consumsption record of our GU 4.2TD when we had one. We found our fuel consumption was never better than about 14L/100KLMS, and pulling a heavily laden Kimberley Kamper at 90-110 would give us about 18L/100KLMs, and crossing the Simpson with it used about 24L/100KLM.
Simon
AnswerID: 22622
Follow Up By: Darren - Monday, Jun 16, 2003 at 13:27
Simon,
That would be much appreciated. E.M is dlhoward1@bigpond.com
Darren
FollowupID: 14950
Reply By: desert - Monday, Jun 16, 2003 at 08:44
Darren, I concur with Simon. His figures are spot on, same as mine.
General unladen pottering about: 7km/litre.
Desert work about the same;
Heavy going, off road, cross country: 5km/litre.
High country 4x4: 5 to 6 km/litre.
Absolutely best ever figure, Highway:
7.8 km/litre.
Thats it, it doesn't get much better. Generally less fuel efficient than the older model, probably because it is a much heavier car.
AnswerID: 22628
