Question for Truckster
Submitted: Sunday, Jun 15, 2003 at 22:31
ThreadID: 5472 Views:1685 Replies:1 FollowUps:0
Truckster, I am about to fit a 6" lift and 35's to my GQ, I wanted to know when you fitted your 6" lift if you got away with an adjustable panhard rod or if you had to fit an "A" frame to keep your rear diff centered. I have currently got a 4"spring an 2" body with 33's, Can't wait to see the differance.
Thanks.
Mark.
Reply By: Truckster (Vic) - Sunday, Jun 15, 2003 at 22:56
CALL ENGINEER FIRST, they are getting picky with 6inch lifts... and prices for Engineers have shot up thru Roof.....
I have Adjustable panhards.......
You can fit 35s now with 4/2 lift... Dont need the 6inch.. You wont see much difference in a 4 and 6inch lift.... :(
But even with 6inch suspension lift, you MAY have to trim the bottoms of guards a little with some tires, and Engineers in Vic only Engineer BFG MT's in 35's.. But thats changing, to NO 35's soon I hear.. So call and check things out.
You also need to space the Control arms 10mm pushes diff forwards 10mm to clear guards more..
AnswerID: 22610
