LC WHEEL CARRIER will it fit?
Submitted: Wednesday, Feb 20, 2008 at 11:56
ThreadID: 54747 Views:2610 Replies:4 FollowUps:3
Hi just wondering if anyone would know if a kaymar rh side spare carrier off a 2004 std diesel barn door cruiser will fit a 98 gxl petrol?
thanks in advance
Reply By: Rossco td105 - Wednesday, Feb 20, 2008 at 14:35
G'day,
I think the shape of the main external bracket would be quite different (the one that bolts to the chasis bracket and goes over the bumper).
Ross.
AnswerID: 288444
Reply By: Member - DOZER- Wednesday, Feb 20, 2008 at 15:40
same if the 98 is a 100 series different if it is an 80 series
AnswerID: 288449
Follow Up By: Member - Graham H (QLD) - Wednesday, Feb 20, 2008 at 18:25
Would check with Kaymar as the chassis widths are different on the IFS models. They are about 45mm wider apart than the Solid axle model. I found out when I bought the wrong towbar and it was too short one end. LOL
Not sure about you model but best to check.
FollowupID: 553824
Follow Up By: Member - DOZER- Wednesday, Feb 20, 2008 at 18:59
Graham
The 04 std is still a 105 with solid front diff...same chassis dont know about bumperbars, but if they are different, they should be able to be swapped too.
FollowupID: 553835
Follow Up By: Member - Graham H (QLD) - Wednesday, Feb 20, 2008 at 19:30
Should fit then I guess I wasnt sure but I got a solid front towbar and it doesnt fit my 2005 GXL.
Bumpers are much the same as I got a 99 with the towbar and it appeared the same.
I got a Kaymar wheel carrier and luckily got the bumper with it all drilled etc and even the correct colour All up cost me $450
I might still have the fitting instructions if u need them. One thing you will need is longer bolts if you have a towbar fitted. Need to be at least 10mm longer than whats there now as they are only just long enough with the towbarWell at least mine were.
FollowupID: 553843
Reply By: bloosted - Wednesday, Feb 20, 2008 at 19:07
sorry yeah the 98 is a 100 series
AnswerID: 288481
Reply By: Rossco td105 - Friday, Feb 22, 2008 at 00:38
Sorry,
As above, thought the 100 series came out in '99. The chasis is the same for all live axle 105 cruisers (and bumpers!) I had a '99 live axle GXL and the rear wheel carrier brackets are exactly the same as the 2004 std model I have now. Thought you meant 80 series.
Ross.
AnswerID: 288753
