oziexplorer
Submitted: Wednesday, Feb 20, 2008 at 17:20
ThreadID: 54755 Views:2507 Replies:6 FollowUps:7
Have a registered copy of ozi and am trying to set up which gps i have. I have a Garmin Quest, i can tick the Garmin box but can't find that model?
Any help would be appreciated.
Thanks Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: DIO - Wednesday, Feb 20, 2008 at 17:29
In the absence of anything to the contrary, I suggest you contact Ozi and get it from the horse's mouth. I too have a Quest and am interested in your findings. Good luck with it. Link Contact details are at bottom of screen (depending on your screen resolution of course).
AnswerID: 288467
Reply By: The Explorer - Wednesday, Feb 20, 2008 at 17:43
Hello - in configuration try using "other Garmins" in the model list and follow screen instructions...assuming you haven't already.
AnswerID: 288470
Follow Up By: Member - lyndon K (SA) - Wednesday, Feb 20, 2008 at 17:46
Ok, saw that option, just didn't want to stuff it up!
Thought the Quest would be a popular model therefore assumed i may be "doing" it wrong if i couldn't see it on the list.
FollowupID: 553807
Follow Up By: The Explorer - Wednesday, Feb 20, 2008 at 17:52
No idea why its not in the list - they have been out for a while, anyway as far as I can see "other Garmin" is the only (logical) option.
Not sure how you approach the symbol selection process which you will be confronted with - all I can say is have fun
FollowupID: 553808
Follow Up By: Paul (WA) - Wednesday, Feb 20, 2008 at 18:40
Lyndon,
Agree with Greg. I have a Quest and "Other Garmins' in configuration works for me .
Regards,
Paul
FollowupID: 553831
Follow Up By: Member - lyndon K (SA) - Wednesday, Feb 20, 2008 at 21:09
Hi Paul
Is there a series of options you have to click,if so which one's?
Thanks Lyndon
FollowupID: 553868
Follow Up By: Zebra400 - Thursday, Feb 21, 2008 at 05:11
Hi Lyndon
Have you ticked the Garmin USB box on the COM tab in your config file?
FollowupID: 553916
Follow Up By: Paul (WA) - Friday, Feb 22, 2008 at 00:42
Hi Lyndon,
Apologies for taking so long to get back to you.
Under the drop down "File" menu, select "Configuration"
then select the "GPS" tab at the top of the window
then select "Garmin" and "Other Garmin" from the respective drop down lists in the upper left section of the window.
Hope that helps.
Regards,
Paul
FollowupID: 554096
Reply By: Member - Doug T (FNQ) - Wednesday, Feb 20, 2008 at 18:31
lyndon
Some time back when I had Ozi....before I binned it I had my Quest hooked up and you have to set it for USB , if you can't find it download the drivers or whatever,
AnswerID: 288477
Follow Up By: The Explorer - Wednesday, Feb 20, 2008 at 22:32
Douglas you old fart - what would you know about OziExplorer? How many cylinders are firing tonight? Just that worn out one?
PS Just kidding - hope all is well
FollowupID: 553887
Reply By: Von Helga - Thursday, Feb 21, 2008 at 10:52
Does the Help file help
AnswerID: 288595
Reply By: Wizard1 - Thursday, Feb 21, 2008 at 12:47
99.9999999999999999999% of setup issues are answered in the FAQ section of the Oziexplorer website.
AnswerID: 288609
Reply By: Member - lyndon K (SA) - Friday, Feb 22, 2008 at 11:17
Thanks for all the reply's, i'll get there in the end! :)
AnswerID: 288792
