rope track
Submitted: Wednesday, Feb 27, 2008 at 20:38
Member - shane (SA)
ok im after some rope sewn in webbing that is pulled through rope track. it is for the caravan. i want to sew it to shape cloth. does anyone know who is the supplier?
Reply By: Member - Hughesy (NSW) - Wednesday, Feb 27, 2008 at 21:16
Shane, I just had a shadecloth cover for the offside of my van. I know the stuff your talking about but the canvas guy who did
mine has just used used a 2" wide plastic trim/edge all the way around the shadecloth. All he did was put a length of ~3mm poly rope into the top edge which I've fed thru the sail track. If you were going to make it your self this would be the cheapest way.
289715
Follow Up By: Member - shane (SA) - Wednesday, Feb 27, 2008 at 21:31
was this a clear colour? have seen this but was hoping for webbing for strength.
555046
Follow Up By: RosscoH - Wednesday, Feb 27, 2008 at 21:55
Hi Shane,
The stuff you are looking for is called "KEDER" Tape. I just rang around all the motor trimmers and Upholsterors until I found someone with it. It will be about $5.00 meter. Getting it sewn onto my annexe extension as we speak.
Cheers RosscoH.
555055
Follow Up By: Member - Hughesy (NSW) - Wednesday, Feb 27, 2008 at 21:56
The edging is that HD vinyl type material and he has sown the rope into it. Its exactly the same as how my orginal jayco bed flies and awning were made. I've had no issues with the jayco ones. The rope and everything on
mine is white to match the original bedflies and reflect heat.
555056
Reply By: Member - Kiwi Kia - Wednesday, Feb 27, 2008 at 21:42
Check out thread # 54659
289727
Follow Up By: DIO - Thursday, Feb 28, 2008 at 09:53
Try this
#54659
555117
Reply By: Member - shane (SA) - Wednesday, Feb 27, 2008 at 22:34
thanks all, thats the gear.
cheers shane.
289744
