What is it??
Submitted: Friday, Feb 29, 2008 at 20:28
Member - lyndon K (SA)
Have a guess at what my latest crazy invention is to be used for.
Hint,it's not a weapon of war :)Image Could Not Be FoundImage Could Not Be Found
Reply By: Kev & Darkie - Friday, Feb 29, 2008 at 20:43
Tyre bead breaker??
Cheers Kev
| Russell Coight:
290100
Reply By: Wayne's 60 - Friday, Feb 29, 2008 at 20:56
UMMMMMMMMM, an alternate Charles Atlas Chest expander??
Still in the testing stage.. LOL
Wayne.
290105
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 21:13
I love that one Wayne! :)))))))))))))))))
555426
Follow Up By: Wayne's 60 - Friday, Feb 29, 2008 at 22:06
Hi Lyndon,
Yep, had to do it......... it was just sitting up there waiting to be smacked.
Mission accomplished!!
Wayne.
555450
Reply By: warfer69 - Friday, Feb 29, 2008 at 21:07
Winching !
290106
Reply By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 21:13
ERR,no. Rough hint, i just bought a boat and it is to used in conjunction with it. :)
290107
Reply By: Garbutt - Friday, Feb 29, 2008 at 21:16
Bicycle frame?
290108
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 21:19
LOL,it's for the boat(not for fishing) :)
555428
Reply By: Garbutt - Friday, Feb 29, 2008 at 21:25
To hold the outboard up from the trailer???
GB
290114
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 21:35
Err no,but you are starting to think along the right track. It's to hold something :)
555433
Reply By: Member - glenn G (QLD) - Friday, Feb 29, 2008 at 21:27
Spring loaded oar holder (rowlock)
Giffo
290115
Reply By: warfer69 - Friday, Feb 29, 2008 at 21:34
HIYA lyndon
ANCHOR designed to belt some fish on the way down !
Is that angle or tubing on the left end ???
290116
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 21:44
square tube
555439
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 21:45
if it doesn't work it may
well be used to belt some fish on the way down!
555440
Follow Up By: warfer69 - Friday, Feb 29, 2008 at 21:49
LMAO
Gee there must be some die hard fishers of men amongst us !
555441
Reply By: Member - bungarra (WA) - Friday, Feb 29, 2008 at 21:35
for eassier removal of anchor when hooked firmly.........
the spring will engage when the rope force exceeds the designed "pull" and consequently change the direction of the force required to dislodge the anchor...hopefully the change in angle will assist in dislodging
290118
Reply By: Member - Littleborgy (SA) - Friday, Feb 29, 2008 at 21:49
It's a thingamajig made from 25x25x1.6mm square tubing, 50x6 flat bar, 20mm round, 32nb pipe, and a 6 inch long spring, to be used for holding something on your new boat :)
Cheers, Brad
290122
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 21:54
LOL,yes Brad, but what part? There is normally only one part that needs holding! :)))
555442
Follow Up By: Steve from Top End Explorer Tours - Friday, Feb 29, 2008 at 22:09
It's a spring loaded rod holder.
Cheers Steve.
555451
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 22:20
Sorry Steve, Wrong.
Not to be used in the boat once launched!! That should be a big hint,
well maybe :)))
555455
Follow Up By: Member - glenn G (QLD) - Friday, Feb 29, 2008 at 22:28
It's a fancy outboard leg holder for travelling ? or a really weird jockey wheel suspention !
Giffo
555457
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 22:40
Hi Glen, Wrong, but the right line of thinking.
I have a boat but no trailer???????????????????
Think outside the square
555464
Follow Up By: Steve from Top End Explorer Tours - Friday, Feb 29, 2008 at 22:43
You are putting a small set of wheels on the back of the boat and you are holding the draw bar,
Cheers Steve.
555466
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 22:54
G'day Steve
Thought that last clue might give it away, yep correct, it swivels and piviots etc. Will it work? No idea :)
555471
Follow Up By: Steve from Top End Explorer Tours - Friday, Feb 29, 2008 at 22:59
I have seen something similar that works, but not on road as a registered trailer, more a
camp spot to the water and back arrangement.
Cheers Steve.
555472
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 23:26
hi steve
Yeah, it's just to get the boat the 500mtr back to
camp each day without having to put the boat on and off the roof(not to mention take the outboard off)
I've swivelled the boat side to side etc and it seems to work
well, waiting on the wheels for a real
test.
Cheers Lyndon
555478
Follow Up By: cYc - Saturday, Mar 01, 2008 at 07:22
So that little thing moves a boat 500m on its own.
Imagine what one twice the size could moove.
Maybe the navy could be interested.
All the best
Eric
555493
Reply By: Richard Kovac - Friday, Feb 29, 2008 at 22:32
lyndon Hi
not sure what it is, but it was good to get your grandfather to pose for the photo...
Richard
290136
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 22:52
Hi Richard, Dad is most offended :)
555469
Reply By: Member - Luke (SA) - Friday, Feb 29, 2008 at 22:57
WTF is with the spring and 32nb pipe. I have an idea but not really sure, just guessing
Cheers Luke
290141
Follow Up By: Member - lyndon K (SA) - Friday, Feb 29, 2008 at 23:08
Another spring inside the pipe, it compresses as the top spring moves down, pipe is just to hold in place
555475
Reply By: RovingOz (QLD) - Friday, Feb 29, 2008 at 23:48
This post is the funniest bloody thing I've read on here for a long time.
Hope you never get raided by the anti-terrorist unit - you'll have a hard time convincing them it's not some sort of bloody rocket launcher.
290148
Reply By: Member - Glenn G (QLD) - Saturday, Mar 01, 2008 at 08:50
Hi Lyndon
Could you post a few picks of your invention when its operational ?
I may make one ,thats if you have not been to the Patent Office.
Giffo
290191
Reply By: Member - Willie , Sydney. - Saturday, Mar 01, 2008 at 09:01
Lyndon ,
A friend made up wheels for me that clamp onto the side of my 3.7m Dart . Then he made a clamp which utilizes the handle and the winch rope hole on the front of the boat . This clamp is welded to a universal joint and a Treg trailer hitch .
It works very
well , but obviously , its not something you can take on a public road . Very handy for that 500m you were talking about .
Willie .
290196
