Hotwire electric windows
Submitted: Friday, Feb 29, 2008 at 23:53
ThreadID: 55067 Views:3165 Replies:7 FollowUps:21
Gday all,
I want to hotwire my lecky windows on the 2008 70series dv8.
Got the wiring specs from Toyo and it ment zilch to me.....so I gave it to an auto sparky and.......it ment zilch to him, said he would study it.
Does anyone know?
Cheers...........BIGDOG
Reply By: Richard Kovac - Saturday, Mar 01, 2008 at 00:27
Maybe we could help if we understood the question..??
Sorry
Richard
AnswerID: 290153
Reply By: Member - Phillip S (WA) - Saturday, Mar 01, 2008 at 00:44
A lot of the control for accesories are computor driven nowdays to cut down on the size and amount of wiring required in vehicles today.....this cuts down on costs and weight and resourses etc.
For example lighting...high and low beam...wipers, speed, intermittent control etc....doors for alarms, seat belt alarms.....interior light control......handbrake position....footbrake position..etc etc etc are fed into the same computor that controls the engine...sometimes transmisson(usually that has it's own computor).....braking and nowadays a host of things that also control traction with ABS etc etc.....in other words where the wiring loom used to huge and wired to every device( so that you could intercept the wiring and hot wire....now they simply have a series of inputs to a what is essentially a PLC ( programmable logic control) the CPU of that PLC contains a program installed via a laptop and this program can look at a whole range of analogue and digital inputs, then it can make decisions and control the vehicle with a variety of digital and analogue outputs some via relays to control for example lights...windows...doorlocks...even starting the motor....like it must be in park, with your foot on the brake, then when you turn the key, it will start....and just try to remove the key after you have stopped and turned the engine off, when it still in drive...it soon tells you!!!
I have seen all these things operate just by using a laptop(which contains the right programme) and highlighting a function and then hit enter....turn lights on...turn lights off for example.......so if you know your way around, you can cheat and bypass the system or even trick it to think to do it for you......REMEMBER CHRISTINE(Steven King)...so be carefull
AnswerID: 290155
Reply By: Member - BIGDOG G (WA) - Saturday, Mar 01, 2008 at 00:47
Oh Jee Richard....
Sorry, too much "Wild Turkey"
The electric windows only work when the key is turned on.
I would like to have power to the windows at all times, so I guess I would need to have them "HOT" wired,
Hope this is clearer.
Regards................BIGDOG
AnswerID: 290156
Follow Up By: Member - Graham H (QLD) - Saturday, Mar 01, 2008 at 08:18
I believe this is illegal in the interests of safety.
EG kids in car when you arent and they play with windows and wind one up trapping head and choking.
Worth looking into before you do it
FollowupID: 555497
Follow Up By: Richard Kovac - Sunday, Mar 02, 2008 at 00:28
Bigdog
you will need to do it at the fuse box cut power wire to fuse from ignition, then wire it up to a power supply from the ass. side of the iginition switch
Richard
FollowupID: 555663
Follow Up By: Shaker - Sunday, Mar 02, 2008 at 12:05
Before you do it, put your fingers on top of the glass, operate the window switch, then ask yourself, "is this really a good idea?"
FollowupID: 555700
Follow Up By: Member - Roachie (SA) - Sunday, Mar 02, 2008 at 12:37
Graham,
I've done this mod to my Patrol (the windows can only be operated from the driver's door control panel, not the individual windows....not sure why that is, but it's okay by me).
It's funny you mention the safety aspect as a "negative"..... I actually thought the opposite. In the event that a child was locked in the car and could not get out on a hot day, at least they would be able to wind the window down etc.
I did mine cos I was sick of stopping somewhere after a trip with the kids in the back, switching off the motor and then finding that the boys hadn't put their window/s up in the back.....I've even done it myself on occasions. In my case I have a warning buzzer (SURPRISE, SURPRISE!!!! haha) for low oil pressure so if/when I turn the ignition on, the blasted buzzer sounds. Easy for me now to just operate the windows from my driver's position.
I was told when I did mine that it was illegal due to some insurance reason.... WTF!!! To me it's no different to having a manual wind-up mechanism on the windows (can anybody remember those???? haha). Your issue with a child getting trapped in a window cos some other kid hit the up button and head was caught etc, could have happened in the "old days" too with the manual wind-up windows! How far is all this safety BS gunna go before people start to take a long hard look at 'emselves. Crikey, when I was a kid we rode around in the back of the old man's ute.....no restraints, no helmets etc etc.
If you're gunna worry about kids getting their head caught in a window winder accident, what about the equal possibility that they could strangle 'emselves in the seatbelt? The possibilities of a way a child can hurt themselves are limited only by your imagination.
As to the answer to the question, I would imagine that no matter how much jiggery-pokery there is with these new fangled computerised cars, there still has to be a POWER wire (ie: "hot wire") at the switch inside the door panel, which you could cut into and supply remote power from another source.
Roachie
FollowupID: 555704
Follow Up By: Member - Lost Dog(WA) - Sunday, Mar 02, 2008 at 13:14
On my Mitsi, a small amount of pressure against the top side of the window is enough for the window to roll down again.
Col
FollowupID: 555707
Follow Up By: Mike Harding - Sunday, Mar 02, 2008 at 13:33
There was a tragic accident here in Vic about two years ago iirc,
child playing in car whilst mum took the weekly shopping in to the house, keys in ignition, child choked to death with neck stuck in electric window. If I still had small children I wouldn't do it. It's only a minor inconvenience to turn the ignition on to operate the windows.
Mike Harding
FollowupID: 555709
Follow Up By: Dunaruna - Sunday, Mar 02, 2008 at 17:32
IMHO the tragedy there is the mothers ignorance, not a hot window winder button. The child could have just as easily released the handbrake or started the car.
BTW Roachie, most vehicle manufacturers have (or soon will be) adopting the Controller Area Network (CAN) wiring system. The hot wire is on the way out I'm afraid.
FollowupID: 555776
Follow Up By: Mike Harding - Sunday, Mar 02, 2008 at 18:30
I suggest it is unlikely either of those events would have led to more than a dented car. The _reality_ is the child died because an electric window was active.
Mike Harding
FollowupID: 555786
Follow Up By: Dunaruna - Sunday, Mar 02, 2008 at 18:56
It's settled then, we agree to disagree.
FollowupID: 555788
Follow Up By: Mike Harding - Sunday, Mar 02, 2008 at 19:14
Of course.
You think it's a safe thing to do when young children are around and I don't.
Mike Harding
FollowupID: 555791
Follow Up By: Dunaruna - Sunday, Mar 02, 2008 at 19:17
Are you serious?
FollowupID: 555792
Follow Up By: Steve from Top End Explorer Tours - Sunday, Mar 02, 2008 at 19:21
As a father of a whats that button for 5 1/2 year old I'm with Mike on this one.
Cheers Steve.
FollowupID: 555793
Follow Up By: Mike Harding - Sunday, Mar 02, 2008 at 19:23
Reading back on this thread I'm a little confused by your comment.
Let's try again: my contention is that it is not a sensible thing to bypass the wiring in such a way as to make the electrical windows work when the ignition is switched off, if there is any likelyhood of young children being passengers in the vehicle. Do you disagree with that?
Mike Harding
FollowupID: 555794
Follow Up By: Mike Harding - Sunday, Mar 02, 2008 at 19:24
Good God Steve! You OK? :)
FollowupID: 555795
Follow Up By: Dunaruna - Sunday, Mar 02, 2008 at 19:26
I didn't say it (live window button) was safe, I said that the mothers ignorance made it unsafe. I stunned by Mikes last comment.
Would you leave a small child in a car with the keys in the ignition?
FollowupID: 555796
Follow Up By: Steve from Top End Explorer Tours - Sunday, Mar 02, 2008 at 19:29
The wife is taking vitals as we speak.LOL
Seriously if it could affect a child, It needs to be considered.
Cheers Steve.
FollowupID: 555797
Follow Up By: Dunaruna - Sunday, Mar 02, 2008 at 19:30
Sorry Mike, we were typing at the same time.
My opinion is - Hot window button + small child = unsafe.
Hot window button + small child + unsupervised = extremely unsafe.
My argument is not whether or not the window is hot, it's the lack of supervision and ultimately an ignorant parent.
FollowupID: 555798
Follow Up By: Mike Harding - Sunday, Mar 02, 2008 at 19:31
No, I never did with either of my two.
I think you're missing the point; the child died because the windows were active when the vehicle was parked - in this case it was an error by the parent which made then so. If you bypass the the ignition dependency of the windows then they'll be active all the time so, in effect, you're leaving the keys in the ignition all the time in regard to the operational capability of the windows.
Mike Harding
FollowupID: 555799
Follow Up By: Mike Harding - Sunday, Mar 02, 2008 at 19:41
I do take your point about parental responsibility and think it's well made but none of us are perfect: the phone rings, the neighbour calls over the fence, child No. 2 falls and injures themselves etc etc etc - it's always the "unlikely" combination of events which leads to disaster.
Mike Harding
PS. As a 3 year old (or abouts) I managed to lock my mother in our outside toilet - I remember it well :)
FollowupID: 555801
Follow Up By: Member - Roachie (SA) - Sunday, Mar 02, 2008 at 19:47
Okay, this post has stirred me into action today.
I had modified my windows to be able to be operated regardless of the key in/out...on/off etc.
I've had a niggling doubt about my mod for some time. Not because of kiddies getting their head caught etc (my youngest is 7 and smart enough not to muck about with ANY......ANY of the controls in the Patrol, for fear of death by dad!!!).
However, I've noticed that the very dim light in the driver's window switch is always illuminated since I did the mod, which I wasn't all that keen on.
So.....the fix..... I've just fitted another bloody switch. This one is located on the front of the plastic moulding that holds the 4 window switches + central door lock + the factory window cut-out switch. The toggle switch cuts the power off, but still enables me to throw that new switch, thus providing power to the windows without key considerations.
For those who are concerned about the kiddie situation, you could still do the mod, but instead of fitting a toggle (on/off) switch, you could fit a push-button, momentary contact switch down near the gear lever. To operate the windows would require an adult or larger child, who could press the new button near the gearshift with left hand, whilst operating the window switch with right hand. Bit of fiddling, but would work okay.
As I said before, my system only works on the driver's door buttons anyway, so that may minimise the possibility of a child operating the window anyway.
Parental supervision is still the 1st line of defence.
FollowupID: 555802
Follow Up By: Dunaruna - Sunday, Mar 02, 2008 at 19:50
The child should not be in the car in the first place.
In america, there is a switch on the dash to de-activate the passenger airbag, do you know why? It's the same reason McDonalds put HOT on their coffee cups. People do stupid things and sometimes there are serious consequences.
The child in question pushed a button, if that button didn't produce any results he/she could have gone onto other interesting looking stuff like the ignition switch or the handbrake and please don't tell me about a dented car, there are way too many driveway runovers on the news these days.
Most drivers door master switches have the disable feature for the other windows, it's so easy to use that feature.
Yes, the electric window caused the ultimate damage but the parent was at fault, in my humble opinion.
FollowupID: 555803
Reply By: Member - Barnesy - Saturday, Mar 01, 2008 at 01:54
Why not simply take the door trim off, find the wires that connect to the window motor and switch and run wires straight to the battery?
I suppose you would need to be careful of the existing wires coming from the computer that they aren't part of an existing circuit that is cut off when the wires are cut. eg some other computer function doesn't work because the power window wiring is cut.
Barnesy
AnswerID: 290160
Reply By: Mike Harding - Sunday, Mar 02, 2008 at 08:34
If (and it's quite possible on a late model vehicle) the whole system is CAN Bus controlled (do Toyota use CAN or do they have their own bus?) with the windows being handled by the Body Control Module or similar rather than the old style of power wires and switches them my strong advice is... don't mess with it.
Mike Harding
AnswerID: 290339
Reply By: Member - Graham H (QLD) - Sunday, Mar 02, 2008 at 20:46
Personally I really dont care what anyone does with their windows.
I was merely pointing out that I have read that it is illegal.
If anyone wants to do it fine.
You have to live with any consequences not me.
I was trying to help not be negative.
AnswerID: 290457
Reply By: Member - Mike DID - Sunday, Mar 02, 2008 at 20:48
On all Pajeros it's easy - there's a Relay that only powers the Window motors.
Pull out the Relay, wind a few turns of heavy wire across the switch contacts, replace the relay.
AnswerID: 290458
