FollowupID: 555744 Submitted:
Sunday, Mar 02, 2008 at 15:03
Mainey (wa) posted:
Derek,
YES, your correct, it is true, what do you want me to say, I agree with you too, because ""240V plugs and sockets are for mains use only and current can travel in both directions"" yes, unless you use it for 12v.
Derek,
will you please read this slowly:
At the far end of the (12 Volt) Solar panel extension cable, the *opposite* end to the OUTLET or MALE plug, where the electricity enters the extension cable, there is NOT a 240v FEMALE INLET plug or connection !! (fact)
There is a 12v "alligator clip" (for example only) because everyone knows what they look like, NOT a 240v plug. (fact)
So can you please tell me how the 240v electricity will get INTO the extension lead, when there is ONLY a 240v *OUTLET PLUG* at one end ???
question is: HOW does anyone plug it into a 240v SOCKET ???
Steve,
Can you put the male end into a 240v socket -> NO
Can you put anything in the female end -> YES, as with any plug it has a 'hole'
More to the point could a child put the socket into a 240v socket, and then put something in the other end -> NO
Does the extension lead have 2 female end or similar -> NO
And does the panels have the male end -> YES
Mainey . . .
 Click Image to Enlarge |
* check-out how SÔLAR PÔWER & ¹² Vølt Batteries will work *
click-> "My Profile"
below
