Section Image
2.5kg Lemair washing machine issue
Submitted: Sunday, Mar 02, 2008 at 22:27
yakodi
Hi all, we are after a cure for our 2.5kg Lemiar washing machine continually syphoning the water while filling. We have raised the drainage hose, levelled the machine perfectly, with little improvement. Any advice???
ThreadID: 55127 Replies: 5
Views: 1198 FollowUps: None
AnswerID: 290509   Submitted: Sunday, Mar 02, 2008 at 22:53
Member - Terry D (QLD) replied:
Hi yakodi
I did all what you have done, but still problematic. Latest fix was to install a relief valve that fits top of raised drainage hose - got a valve (U shaped from boat shop). They have a one way valve at top that lets air in to stop syphon action. The valves are designed for marine toilets - they have three sizes, Large, Medium and Small. That latter fits the Lemiar hoses. It cost me about $45 and took about 10 minutes to install - will try it out this week at Maroochydore.
Lots a luck
TD
Reply 1 of 5
AnswerID: 290511   Submitted: Sunday, Mar 02, 2008 at 23:05
yakodi replied:
Thanks for your advice, sounds like it could work - let us know how it goes. Not too many boat shops in Alice Springs.....
Reply 2 of 5
AnswerID: 290531   Submitted: Monday, Mar 03, 2008 at 08:09
Member - Mike DID replied:
Many washing machines have the drainpump running continually and start the water emptying by opening a valve.
There could be something stuck in this valve or the rubbers could be damaged. If the valve shuts properly then it can't siphon.
To test if it's siphoning or a leaky valve, fill the machine and run it until it starts to pump out water, then switch the power off. If water keeps on flowing, it's siphoning.
Mike R
Reply 3 of 5
AnswerID: 290545   Submitted: Monday, Mar 03, 2008 at 09:30
2grumpy replied:
Hi Yakodi,
We have had the same problem, it took a while to solve it. You must have your drain hose at about 1.2m off the ground, as per instructions in your manual. Next drain your hose into a larger diameter drain hose to drain away your water. If there is a solid join where you join a drain hose to to your washing machine hose it will most likely siphon the water out of the machine as it fills with water as you know. By draining the hose into a larger one, air is getting into the join and it will not siphon the water out of your machine.
I hope you can follow this, I'm not too good at explaining what I'm trying to get across.
Reply 4 of 5
Activities Index
Great Ocean Road 4WD Tour Great Ocean Road 4WD Tour
Great Ocean Road - VIC
Come with us on our ultimate full day 4 wheel drive experience and discover one of the world's most
Performance Driver Training - Warwick Performance Driver Training - Warwick
Warwick and Southern Downs - QLD
Ever wanted to drive your own car at unrestricted speeds on one of Australia's best club race circui
Full Day Trike Tour and Historic Train Ride for 2 Full Day Trike Tour and Historic Train Ride f
Sunshine Coast - QLD
This trip has it all - a fun ride on a custom built trike as well as a rollicking journey on a wonde
Simply Sumptuous Cooking Class Simply Sumptuous Cooking Class
Sydney - NSW
Our simply sumptuous cooking classes are where you can enjoy creating and devouring a delicious 3 co
Sydney Harbour Coffee Cruise Sydney Harbour Coffee Cruise
Sydney - NSW
Sydney's No.1 sightseeing cruise.
Helicopter Whitehaven Beach Picnic Adventure Helicopter Whitehaven Beach Picnic Adventure
The Whitsundays - QLD
Join us for a scenic adventure!
4 Hour Private Yacht Charter on Sydney Harbour 4 Hour Private Yacht Charter on Sydney Harbou
Sydney - NSW
Cruise the Harbour in style on board a luxury 33 foot Hunter yacht with friends or family.
Barossa Valley & Adelaide Hills Wine Tour Barossa Valley & Adelaide Hills Wine Tour
Adelaide and Adelaide Hills - SA
For Wine or Reason specialize in personalized guided Wine Tours, perfect for corporate clients or th
Sovereign Hill & Ballarat with Australian Wildlife Sovereign Hill & Ballarat with Australian Wil
Bendigo and Goldfields - VIC
in 1850 the world focussed on Ballarat as the cry 'Gold' echoed around the globe.
Quick Spin Harley Tour Quick Spin Harley Tour
Alice Springs and Central Australia - NT
Short on time but want to a taste of Uluru?
Book Now - Things To Do
AnswerID: 290575   Submitted: Monday, Mar 03, 2008 at 12:06
hazo replied:
You must have what is called an "air break" to stop the syphoning.
The hose must be higher as stated and a simple method I was shown for zero cost is just drill a smaell hole in the top of the hose, just past the "u" bend, and install a drinking straw into the hose and down into the outgoing flow section, leaving the straw about 25mm sticking out.
It doesn't leak and problem solved.
The other way is to install a small length af 25mm white re-tic pipe on side wall with a 25mm coupling on end, and a hose connector on other end then just hang hose "u" bend into it.
The small difference in pipe sizes allows the air to enter and stops the syphon action again.
Brian
Reply 5 of 5
