Fixing a Waeco Fridge Transformer
Submitted: Monday, Mar 03, 2008 at 22:49
ThreadID: 55160 Views:8156 Replies:7 FollowUps:7
My Waeco CF50 Fridge's transformer is playing up when I try to run the fridge on 240v. It keeps blowing the 163mA fuse.
I opened it up and there is nothing obviously wrong with it (although I don't know anything about them). Is there anything that I should be looking for which would be the likely cause of the problem.
Paul
Reply By: Member - Phillip S (WA) - Monday, Mar 03, 2008 at 23:32
does the fuse blow without the fridge plugged in??????????
AnswerID: 290694
Follow Up By: Member - Phillip S (WA) - Monday, Mar 03, 2008 at 23:50
I just had a look at mine and it should be a 630mA fuse....the unit itself when plugged in should make a distinctive sound that you would associate with any high frequency electronic device( a zinging type sound).......the unit is capable of 6 amp output @ 12VDC ( see underneath)..........try plugging in a known load of say 5 amps (5x12=60 watts...ie a globe)....if it still works...then plug your fridge into your usual car (12vdc) fridge socket and see if your fride is working......by doing these two simple checks you should be able to determine the where the fault is....the power supply OR the fridge...hopefully not the fridge....do not fiddle with the power supply,.........but have a electronics expert deal with it or purchase a new one
FollowupID: 556082
Follow Up By: MrBitchi (QLD) - Tuesday, Mar 04, 2008 at 08:55
"the unit itself when plugged in should make a distinctive sound that you would associate with any high frequency electronic device( a zinging type sound)"
Mine makes no noise at all.
Beware, the output of these units as supplied by Waeco is 24v, NOT 12v. DON'T plug your 12v devices into it or they'll fry. Been there. done that :-(
FollowupID: 556104
Follow Up By: pauls - Tuesday, Mar 04, 2008 at 09:07
No, when the fridge is plugged in
Paul
FollowupID: 556109
Follow Up By: Mike Harding - Tuesday, Mar 04, 2008 at 09:30
Or you can't hear it? :(
My hearing now tops out at around 9KHz - probably due to early years spent in noisy factories.
If I turn my TV onto stand-by and forget to turn the power to it off I can't hear any noise from it but my younger son (in his 20s) can hear a high frequency noise - probably the line transformer at 15.625KHz.
Mike Harding
FollowupID: 556113
Follow Up By: MrBitchi (QLD) - Tuesday, Mar 04, 2008 at 09:37
"Or you can't hear it? :(" LOL
No, even my teenage daughter doesn't complain, and she has VERY sensitive hearing. Not all switch modes make a noise.
I do admit that now days I probably wouldn't hear it anyway.. or I'd just get it confused with Tinnitus ;-(
FollowupID: 556115
Reply By: obee - Tuesday, Mar 04, 2008 at 05:58
if the cost of fixing the transformer is more than it costs to use a generic power supply then get one. I have an evacool partly because I already had a 20 watt supply on the shelf and evakool dont build them in. They will sell one for about a hundred bucks but look around.
I would say there is something seriously wrong with your built in job. The switch mode supplys are fairly compact these days unlike my old regulated job and you can put them to other uses like charging the battery. Without looking at the specs I would say a 20 watt supply will do it. Your fridge unit is the same as the evakool.
my opinion
owen
AnswerID: 290700
Follow Up By: MrBitchi (QLD) - Tuesday, Mar 04, 2008 at 09:14
"I would say there is something seriously wrong with your built in job"
The CF50 uses an external "brick" power supply for 240v use.
FollowupID: 556112
Reply By: Member No 1- Tuesday, Mar 04, 2008 at 07:53
blows the mA fuse?...must be on the primary side of the tranny......as the fridge would be on the secondary side, (as it pulls some 5 amps)......If I recall correctly, if the fridge was pulling too many amps i would expect the tranny to collapse ie not blow the primary fuse....
so my best bet would be that the tranny has failed on the primary side windings.
AnswerID: 290706
Reply By: Rocky_QLD - Tuesday, Mar 04, 2008 at 08:27
Thes are a switched mode power supply, if it fails get a new one. About a $100 should do.
Rocky
AnswerID: 290708
Reply By: patrolmann - Tuesday, Mar 04, 2008 at 14:26
I have a waeco 80 lt and the transformer packed it in. I spoke to waeco who said it only has a 12 month warranty on that part and they dont repair them $137.00 for a new one. Since mine was just on 12 months old Waeco came to the party and sent me a new one.
patrolman
AnswerID: 290747
Reply By: patrolmann - Tuesday, Mar 04, 2008 at 14:38
patrolman
AnswerID: 290751
Reply By: PradOz - Tuesday, Mar 04, 2008 at 19:36
You can buy the genuine waeco external "brick"type power units from big w. maybe worthwhile trialling one. if it fails maybe you could then take it back as a faulty unit?? not sure if that is an ethical way of doing business but u wouldnt be the first to do a return like that :)
AnswerID: 290803
Follow Up By: Member - Frank (QLD) - Wednesday, Mar 05, 2008 at 01:35
Remond me not to sell you anything :) :) :)
FollowupID: 556267
