waeco fridge setting
Submitted: Wednesday, Jun 18, 2003 at 10:30
ThreadID: 5518 Views:26591 Replies:7 FollowUps:0
hi , i have bought a 35 lt waeco from a garage sale it works fine
but didnt come with a instruction manual
the question i have is what is the switch, low,med,high for?
Reply By: Groove - Wednesday, Jun 18, 2003 at 12:25
I have a waeco and is has a low off and high switch. This refers to the low voltage cutout. Low and the fridge will allow the battery to discharge lower than when set to high, I dont recall the actual voltage levels.
A very handy feature to protect your battery, even deep cycles benefit.
AnswerID: 22876
Reply By: jamcage - Wednesday, Jun 18, 2003 at 15:23
According to the Waeco manual the switch you are talking about is the
'Battery Cut Out Level Switch,
LOW is for cigarette lighter connections and HI is for direct hard wiring (without plugs)'
The owner manual can be downloaded from the Waeco internet site.
AnswerID: 22894
Reply By: brett - Wednesday, Jun 18, 2003 at 17:04
From memory low is 10.5 V and med is 11.5, using the cable supplied when set to low it cut out at about 11V measured at the battery terminal
AnswerID: 22900
Reply By: Phil G - Wednesday, Jun 18, 2003 at 17:28
If you're running it off the starting battery, or a starting-type auxillary, set it to high (11.9 volt cutout). If you are running it from a deep cycle auxillary, then you can use the low (10.5V cutout) setting. I think the medium is 11.0 volts.
AnswerID: 22909
Reply By: Rod - Thursday, Jun 19, 2003 at 00:43
Try this websight
http://www.waeco.com.au
Click on technical help on L/H side of screen
The first question/answer may help or ring and ask them or a stockist
who are also listed on this sight.
Rod.
AnswerID: 22957
Reply By: theratt - Thursday, Jun 19, 2003 at 07:33
thanks for all the info all makes sense now ,as long as my beer stays cold
Cheers Theratt
AnswerID: 22962
Reply By: Joe - Friday, Jun 20, 2003 at 10:40
theratt, good question mate.
-The "high" battery protection only allows the fridge to run while the car is running,
-The "Med" setting is to protect the last part of charge in the battery allowing you to start the vehicle,(11.2 volts is the cut off)
-The "low" setting is for extended fridge run time and will cut out at 10.5 volts (flat battery). Hope this helps. Joey
AnswerID: 23051
