A pig in my engine?
Submitted: Wednesday, Mar 05, 2008 at 21:33
ThreadID: 55227 Views:2350 Replies:3 FollowUps:14
1Hz engine. No turbo or supercharger..my pig can't fly :)
Well it sounds like it from time to time with the air con on. No pig with the button off.
Now it's intermittent, but always comes along when the air con is being used.
I'm leaning towards the compressor bearing? Or would the noise be there all the time in that case?
It's not liable to be the belt I suppose ?
TIA guys.
Reply By: rumpig - Wednesday, Mar 05, 2008 at 21:51
i'd guess the belt slipping without seeing it, pretty common. my 1 HZ has done it aswell as a mates.
AnswerID: 291020
Follow Up By: Footloose - Wednesday, Mar 05, 2008 at 22:14
Thanks, Rumpig. I'll take a peek tomorrow.
FollowupID: 556450
Reply By: Vince NSW - Wednesday, Mar 05, 2008 at 21:53
Try some dry lube on the belt. Or tighten it.
AnswerID: 291024
Follow Up By: Member - Ian H (NSW) - Wednesday, Mar 05, 2008 at 21:58
To check if it is the belt just spray a little water on it. If it is the belt the noise will stop immediately.
Then try tightening it a bit but it may still squeal.
FollowupID: 556439
Follow Up By: Footloose - Wednesday, Mar 05, 2008 at 22:13
Ian, that's a great tip, thank you.
FollowupID: 556449
Reply By: Footloose - Wednesday, Mar 05, 2008 at 21:56
I thougt that the belt would tighten when the air con clutch engaged ? No?
I'll try the belt tighten tomorrow and see if the pig is greased :)
AnswerID: 291026
Follow Up By: Tony - Wednesday, Mar 05, 2008 at 22:08
It could be the idler pully. With the A/C on it puts a bit more load on the pully.
FollowupID: 556444
Follow Up By: Footloose - Wednesday, Mar 05, 2008 at 22:12
Thanks, Tony. forgot about that one :((
FollowupID: 556447
Follow Up By: Steve from Top End Explorer Tours - Wednesday, Mar 05, 2008 at 22:14
100% idler pully.
Cheers Steve.
FollowupID: 556452
Follow Up By: Footloose - Wednesday, Mar 05, 2008 at 22:20
Steve, what's the cure? Don't tell me the mech has to xray my wallet AGAIN ? LOL
FollowupID: 556454
Follow Up By: Steve from Top End Explorer Tours - Wednesday, Mar 05, 2008 at 22:25
If you do it your self the cost of the pully, last time I bought one was about $45.
Thats a couple of years ago, there easy to do a 14 mm spanner a 14 mm socket and off you go.
Cheers Steve.
FollowupID: 556457
Follow Up By: Footloose - Wednesday, Mar 05, 2008 at 22:31
Thanks, Steve. I appreciate it :))
FollowupID: 556462
Follow Up By: pop2jocem - Wednesday, Mar 05, 2008 at 22:42
Footy
If you can press the old bearing out and I think from memory they are retained in the pulley with a couple of stakes, you could buy a new bearing for about $5 and refit
Cheers Pop
FollowupID: 556465
Follow Up By: pop2jocem - Wednesday, Mar 05, 2008 at 22:43
Footy
Cheers Pop
FollowupID: 556467
Follow Up By: Footloose - Wednesday, Mar 05, 2008 at 22:47
Thanks, Pop, but that would be a mech job. My workshop facilities are about 2 steps better than the kitchen table whilst my hands on mech knowledge is...well...can I just say neglected? LOL
FollowupID: 556468
Follow Up By: Rossco td105 - Thursday, Mar 06, 2008 at 01:51
Hey footloose,
There is a step by step guide on the LCOOL site if you want to give it a try, worst case scenario is you buy a new tensioner anyway! Not a huge job to have a crack at.
www.lcool.org/technical/100_series/ac_bearing.htm
Ross.
FollowupID: 556491
Follow Up By: Footloose - Thursday, Mar 06, 2008 at 07:56
Rossco, thanks. I'd forgotten about the LCool sites.
FollowupID: 556498
