Nissan GQ/GU front wheel bearings on ebay
Submitted: Thursday, Mar 06, 2008 at 00:39
ThreadID: 55238 Views:3242 Replies:2 FollowUps:3
G'day all you Nissan (GQ & GU) owners, if you're looking for a new (or even a spare) set of front wheel bearings, you may wish to check these out....
Nissan dealer is asking around $180 a side, and the best I could find from the local bearing places was around $130 per side, so at $145 (both sides) delivered, these are a deadset bargain IMO...
Yes, I picked up a coupla sets, and they are "as described" :))
Confucius say.....
Reply By: madcow - Thursday, Mar 06, 2008 at 12:24
You would not have the actual bearing & seal numbers handy would you.
AnswerID: 291129
Follow Up By: Member - Ed. C. (QLD) - Thursday, Mar 06, 2008 at 13:27
Yep...
Outer .. Nachi (Japan) LM501349 (cone), LM501310 (cup)
Inner .. NSK (Japan) HR 33110Ja1 (cone), HR 33110J (cup)
Seal .. LYO (Taiwan) Lyo No. 65845 + 65846, parts No. 40227-C8200 ..
Confucius say.....
FollowupID: 556536
Follow Up By: madcow - Thursday, Mar 06, 2008 at 13:34
Ta for that! I keep a record of such things for my own reference
FollowupID: 556539
Reply By: TrickGU - Friday, Mar 07, 2008 at 09:24
Hi, did the bearings come with cups as I contacted the seller and they said that cups are not included, I can't imagine changing bearings without replacing the cup to match.
AnswerID: 291351
Follow Up By: Member - Ed. C. (QLD) - Friday, Mar 07, 2008 at 12:00
You musta been talkin' to the cleaner;-)))
By "cup" I presume you mean the outer raceway, the bit that is pressed into the hub, yes? They are definitely included..
The kits supplied to me are as per my follow-up above, + the lock-washer (this is for the GQ, not needed on GU)..
i.e., 2x complete (inner & outer) bearing assemblies....
Regards, Ed C
Confucius say.....
FollowupID: 556741
