Generators
Submitted: Thursday, Mar 06, 2008 at 08:58
Member - SHERYL H (QLD)
We have 34FTfifth wheeler and obviously need a generator that is quiet and powers air cons etc.Can you please tell us what size or kva we need. It is all very confusing when different generator people give you different answers.
Thanks for your help.
Sheryl
Hill
Reply By: Member No 1- Thursday, Mar 06, 2008 at 09:58
more info required such as watts input for all items you need to run/operate at any given time...
eg a 3/4 hp aircon will not require same size generator as a 2hp etc etc
lights and other apliances add up as
well
291099
Reply By: Tony - Thursday, Mar 06, 2008 at 10:32
A 2kva will do the job ok, but a 3kva Honda would do it with ease.
291108
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Mar 06, 2008 at 10:37
You say 'air cons'.
How many and what type. You may need a large RV type.
291110
Follow Up By: Member - SHERYL H (QLD) - Thursday, Mar 06, 2008 at 17:46
its 15,000 BTU with Quick Cool.....howszat for a girl.
556569
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Mar 06, 2008 at 18:15
Not bad but we need the Watts or KW. Also see is if lists the start up watts or amps.
Have you got only one a/c fitted ?
556582
Follow Up By: Member - SHERYL H (QLD) - Friday, Mar 07, 2008 at 07:42
There are two air cons. One in the bedroom 13500 BTU but this one can not be run at the same time as the primary air conditioner. I guess that would be with
battery power. Unfortunately the rig is still down at the Tweed so I dont know as yet what the kw,s are and dont know how to convert if possible. I believe we also need another battery. This is all very new and confusing and certainly nice to know I can contact an expert on the whole electrics thing. I will endeavour to ask the guy down in NSW.
556694
