Battery installation Delima !!
Submitted: Saturday, Mar 08, 2008 at 13:16
ThreadID: 55326 Views:3208 Replies:5 FollowUps:8
Should I install my deep cycle battery into my car (2007 Outlander) if possible, or onto my van (Jayco Dove 1988). I would appreciate some advise to this question as I want to do it right the first time. We are not intending to enter 'extreme 4wd country, however we do plan to get off the beaten track where possible! So far I am sold on a 'dry cell' battery as apparently they don't mind being drained completely whereas 'wet cell' can suffer from this. I have a tool box on the front of the van which I think would be a good location for the battery if to be installed on the van. I just wonder if it is a hassle to have the battery in the car as that would mean I have to hook up the car every time to use power, but would this be advantageous when it comes to recharging ?
Reply By: Louie the fly - Saturday, Mar 08, 2008 at 16:49
My cousin recently bought a Jayco offroad poptop. They have a battery inside underneath the seat.
AnswerID: 291620
Follow Up By: Redbac - Saturday, Mar 08, 2008 at 18:09
Oh that would be handy, my van may be older as it only as redback spiders under the seats :)
FollowupID: 556970
Reply By: oz doc - Saturday, Mar 08, 2008 at 17:18
If you have the battery in the tool box, you can charge from the car via the usual wiring harness when towing, but don't have to hook up all the time to use it. We carry a battery charger in the toolbox to charge up from genny or site power if available, as a backup.
AnswerID: 291627
Follow Up By: Redbac - Saturday, Mar 08, 2008 at 18:06
Thanks for reply Doc, I will rig up the same system. Did you have somebody install it on your van? Do you use a dry or wet cell battery?
FollowupID: 556969
Follow Up By: oz doc - Saturday, Mar 08, 2008 at 19:03
Bought the dry cell from a battery shop and had them professionally fit it. We have a wet cell in to tool box on one side- powers the lights in the camper trailer, and the dry cell on the other side - powers the engel when camped. Had the same mob put through heavy duty wire from car battery to the rear 12 volt plug, to power the engel when travelling without the camper. This latter wiring is independant of ignition- so we can run the engel when stopped for a while. Wet cell in the trailer charged by the tow plug, dry cell charged by a separate anderson plug connection.Despite argument - have held firm and kept the two battery systems in the trailer separate - not linked.
FollowupID: 556982
Follow Up By: Redbac - Sunday, Mar 09, 2008 at 11:22
I think I will get the system installed by a professional as well!
Thanks for all the info Doc.
P.S. Are you a real Doctor of any type......just curious :)
FollowupID: 557079
Follow Up By: oz doc - Sunday, Mar 09, 2008 at 12:16
yep - but four legs not two
FollowupID: 557087
Reply By: Member - Norm C (QLD) - Saturday, Mar 08, 2008 at 18:10
Redbac, the question is; where will you use the most power. If your fridge is a compressor type, where is it?
If your power use stuff is in the Jayco, that's where I'd put the battery. Otherwise, if you go for a drive and leave the wife (or someone else) at camp, they have no power.
I have a deep cycle (AGM) in the Hilux and two in the CT, so I'm covered either way.
If you put it in the Jayco and charge from the vehicle, make sure you use heavy duty cable to reduce voltage drop.
I'm not familiar with the Outlander, but does it have space in the engine bay for a second battery? If not and it has to go in the vehicle, make sure it is an AGM or similar. You don't want to have a vented battery inside the vehicle.
Norm C
AnswerID: 291639
Follow Up By: Redbac - Sunday, Mar 09, 2008 at 11:24
Thanks for your help Norm.
FollowupID: 557080
Reply By: mowing - Saturday, Mar 08, 2008 at 18:35
Hi Rebac,
If you have a look at the answers to your previous posts, you will see that what I suggested was to use a battery box and either if there is room in the toolbox on the A Frame put it in there or get a frame made to hold it. You could also put it securely in the side boot of the van. It could be charged from the car with a solenoid and some heavy cables. Would be reluctant to rely on the $120 genny that you have for charging. If you get a decent size battery and run the 3 way fridge on gas when camped, your lighting, especially if converted to LED will not use much and your DVD etc is 12 volts isn't it?
Mark
AnswerID: 291647
Follow Up By: Redbac - Sunday, Mar 09, 2008 at 11:26
Yes I have to read over all the info. Its a whole big learning curve for me at the moment but glad to have help from people like yorself.
Thank you for the info Mowing.
FollowupID: 557081
Reply By: Ray - Sunday, Mar 09, 2008 at 09:10
In my system I have two 75amh sealed batteries in a tool box mounted on the draw bar of the caravan. These are charged two ways. 1, via the car when moving. 2, via a smart charger when stopped and camped.
The cable from the car is 4awg via a solenoid activated by the ignition.
The batteries supply power to the caravan whether it is hitched to the car or not.
Another innovation that is in use is the three way fridge. This is powered from the two batteries when the vehicle is in motion and automatically turned off via a solenoid automatically when the ignition is turned off. I have used 8awg cable for this power. This circuit is independently fused from the rest of the system. This allows the fridge to run on 12v when on the move. Obviously I run it on gas when stationary or mains if I am in a caravan park but I never use genny to run it.
AnswerID: 291730
Follow Up By: Redbac - Sunday, Mar 09, 2008 at 11:28
Sounds like a great set up Ray, thanks for your advise.
Cheers Mate
FollowupID: 557082
