200series Landcruiser noise
Submitted: Tuesday, Mar 11, 2008 at 14:38
ejsjcruisers
Has any one had a clunk coming from tail shaft when accelerating
Toyota fix was to put a thick grease on the spline,but it only lasted a short time
Reply By: Member - bill - Tuesday, Mar 11, 2008 at 17:01
if that is what they did to yours you want to get up em
292116
Reply By: time waster - Tuesday, Mar 11, 2008 at 17:10
Reply By: Member - Jeff R (SA) - Tuesday, Mar 11, 2008 at 18:26
This is common across the 200 series range.
I had the problem on
mine and after a Toyota greasing, it was fine. The should have taken out the shafts, regreased them and replaced the grease nipple. Not simply chuck some grease in!
I suggest you take it back to Toyota to fix it again. In extreme cases they have been replacing the tailshaft(s).
292135
Follow Up By: Member - Graham H (QLD) - Tuesday, Mar 11, 2008 at 20:43
I was talking to a rather unimpressed owner last week who thought it was diff backlash that was the problem. If this is incorrect perhaps I will tell him to read the above
557527
Reply By: CJ - Tuesday, Mar 11, 2008 at 22:22
For what it's worth all forums as
well as formal Toyota advice is that it the noise does not represent damage. Noise is normal, and is all models. Personal opinion is that it is not worse than previous 4wd I owned, but accentuated by the generaly low noise levels of the new 200
Cj
292217
Reply By: Stephen M (NSW) - Tuesday, Mar 11, 2008 at 23:10
Common problem in the 95 series prado's and also the 120 series. Clunks when you come to a stop then when accelerating away from a stop as
well. I was concerned with this on my'n when I first got it but now just grease up every 5k. Apparantly the proper way is to remove the shaft, clean all the old grease off it, put this copper based stuff on the splines then regrease once back together. Toyota now are trialling a new shaft for the prado's due to this problem but havnt heard anything on the 200 series. Regards Steve M
292228
