Under Tray tool boxes - where to move fuel filler ?
Submitted: Wednesday, Mar 12, 2008 at 00:57
lizard
I have a GU ST Cab chassis (Trayback) have had two excellent underTray toolboxes made (for between cab & rear
wheels) I have to move auxillary fuel
tank filler hose .... I guess forward to just behind cab ... have got some hoses (main & vents) and getting some 40 mm pipe bent - any other suggestions ?
Reply By: Member - Craig D (SA) - Wednesday, Mar 12, 2008 at 08:01
Probably not much help, but I had a cut-out in the right hand tool box to enable the filler to exit around the original point, but still had to extend the filler hose. Not much room behind the cab I'm afraid.
292253
Reply By: desert - Wednesday, Mar 12, 2008 at 16:04
I did the same mod, allowing a cut out "step" in the right hand tool box to allow the filler to remain in the stock position and extended the tube with the use of some exhaust tubing bent up to suit. I have stretched the wheel base by 330mm, this now allows for a couple of decent sized toolbox and a 85 litres
water tank on the passenger side, between cab and wheel, 90 litre
water tank mid-mount above the axle, plus the existing factory fuel tanks. 90 litre fuel
tank mid-mount forward of
water tank and on passenger side of tail-shaft.
292336
