Tyre Operating Temps
Submitted: Friday, Mar 14, 2008 at 09:46
Time
Might be a silly question but, assuming tyre pressures are OK what would be the normal operating temperature range of a tyre. I ask because I have just gotten hold of a tyre monitoring gizmo that has warning settings for both pressure and temperature. A search of this site and the web has not helped answer this one.
I'm running 285/75/16 Dick Cepek FC IIs. Usually run 42 - 44 psi on the tar and around 30 psi on the dirt (and lower if the going requires extra traction).
Reply By: traveller2 - Friday, Mar 14, 2008 at 10:08
The 4 psi rule has always worked for me.
Inflate to recommended pressure or whatever you fell is right.
Drive for a half an hour or so then check the pressure, if it has increased by 4lbs then you are about right for the speed and load you are travelling at.
If the pressure has increased by more than 4lbs then you did not have enough in originally for the speed and load.
If the pressure has increased by less than 4lbs then you originally had too much pressure originally for the speed and load.
Tyres should always be checked cold initially.
292641
Follow Up By: Time - Friday, Mar 14, 2008 at 10:23
Thanks for that, I understand about pressures, it's "normal" tyre temperature range that I'm not sure of.
558130
Reply By: Robin Miller - Friday, Mar 14, 2008 at 11:07
Hi Time
I don't have one of those units so I can't give precise advice but I'll just kick in a little theory until someone comes up with something better.
The air temperature inside a tyre rises approx 6c per psi increase over ambient.
Normally tyres are adjusted to give up to 6 psi above ambient and a 10 psi rise would be coause for concern.
So on a 45c day a 10 psi increase would cause an internal temperature rise of roughly 60c
From the above I would set your monitor at about 95c
292652
Reply By: RobAck - Friday, Mar 14, 2008 at 11:28
There is no such thing as a "normal" operating range of tyre temperatures that you can rely on. Simply does not exist.
If you now monitor your TPMS and set it within the normal tolerance range, normally up to around 84C, then you will see that your tyre temperatures, regardless of pressure, will actually vary front to rear and also loaded vs unloaded.
Just make a note of what condition the vehicle is in against the temperatures and you will then establish your "normal" range.
We have seen up to 10C variations front to rear and as high as 62C on baked bitumen with the roof rack on and air temperature of over 40C.
The TPMS give you advanced warning of a slow leak as the pressure can be almost normal but as the tyre slowly leaks it creates more rolling resistance (heat).
We have tested several systems and are currently using the Schrader one which is now optional equipment on LC200.
I hope that helps
RobA
292655
Reply By: Member - Wim (Qld) - Friday, Mar 14, 2008 at 12:14
Time
Nothing silly about the question.
I run a tyre monitoring system. It has an inbuilt table it uses to determine a temp problem.
As an example of the influences on tyre temp.
Last year while traveling west in
the desert.
Mid morning tyre pressures 17-18 psi.
Tyres on the right hand side hot to touch.
Tyres on the left hand side cool to touch.
Average speed slow.
292657
Follow Up By: Member - 'Lucy' - Friday, Mar 14, 2008 at 13:49
Have you figured out why it was hot on one side and not the other???
558168
Follow Up By: Member - Wim (Qld) - Friday, Mar 14, 2008 at 14:42
Lucy.
Northern side of the vehicle, sunny day and winter (sun low in the sky)
Other side of the Vehicle was in the shade.
558176
Reply By: Time - Friday, Mar 14, 2008 at 12:38
Thanks for your quick replies. Very useful.
292660
Reply By: 10 Para (Qld) - Sunday, Mar 23, 2008 at 15:27
I am also running the same brand tyre but in a 265x75x16 size run these because we did 80psi cold for the GMC also found that the 4 psi rule which i have always used seems to be out on theses tyres could it be because there are 10ply tyres but even at 80psi can be up to p2psi after a run which would suggest that the tyres are underinflated but 80psi is the max cold pressure stated on the tyre.
294229
