Tyres for teh C/T
Submitted: Friday, Mar 14, 2008 at 10:29
Kiwi & "Mahindra"
What do you guys do??? Put the same on as the 4b .... assume same size too please....!!
The C/T is in need of new tyres ..... the Navara has only 15000km so the tyres are still pretty good.....cannt remember what type they are ...Bucky will know....
Laura
Reply By: Wayne (NSW) - Friday, Mar 14, 2008 at 10:40
Laura,
It would be good to have the same tyres and rims on both vehicle and camper.
You have said that you are off to
Innamincka latter this year.
If I was you I would put two new tyres on the back of the Navara, put the best of the tyres that are on the Navara now on the front and the other two,"the worst" on to the camper.
If the rims aren't the same on the vehicle and camper some tyre swapping will have to be done.
Wayne
292649
Follow Up By: Kiwi & "Mahindra" - Friday, Mar 14, 2008 at 10:59
Im 99% sure they are the same size...Nathan said that we'd sawp things over....Im even a little sus on how the tyres on the 4b will go heading out to
innamincka!
558143
Reply By: Member - Barnesy - Friday, Mar 14, 2008 at 11:00
More important than type of tyre is that they are compatible with the tow vehicle. I have 5 splits and 4 fats and depending on where I'm going will put either on the car or trailer. If I got several wrecked tyres I could always chop and change tyre combos. Same diameter wheel/tyre on each axle is a must.
Strictly speaking the same tyre is perfect but not really necessary if you only plan to keep them as trailer tyres and use them as spares for car when travelling.
Barnesy
292651
Reply By: Member - DAZA (QLD) - Friday, Mar 14, 2008 at 12:29
Laura.
I would be fairly sure the tyres on your Nissan Navara are similar
to
mine, Bridgstone Duelers AT. 265/70R 16-112S-693.
ours have done just over 42 thousand ks.and have about 10 thousand
ks left, they have never done any serious off road stuff, only on
bitumen or concrete M1, they are a soft compound tyre, I would
get a new set for the Nissan and keep the old ones for the C/T.
Daza.
292659
Follow Up By: Member - DAZA (QLD) - Friday, Mar 14, 2008 at 12:33
PS
Check the Tread Pattern on my rig photo, to see if they are similar
Daza.
558155
Follow Up By: Kiwi & "Mahindra" - Friday, Mar 14, 2008 at 13:26
That sounds right....Id go look but it getting the tow bar put on....might do that...gonne be the safest option i think....
558165
Follow Up By: Vince NSW - Friday, Mar 14, 2008 at 13:31
Mine are the same as yours DAZA.
Only 13000km on them so far. Did the trip to Mt Dare & the Simpson last year with no problems. I will change them to an AT or MT when they wareout, but tooo tight to do it now. I have bigger tyres on the CT but in a pinck could swap these around if I had more than 2 flats on the ute.
Vince
558166
