Pathfinder V Prado V Patrol
Submitted: Friday, Mar 14, 2008 at 18:43
Member - David K (VIC)
Hi all, I currently have a 17ft Jayco towed by a 6cyl Jackaroo. In the next few months we will be upgrading the van to a larger model with manufacturers ball weight spec of 200kg and 2200kg Tare weight. We therefore need to upgrade the tow vehicle. I have been looking at new Pathfinder, Patrol or Prado. I was wondering with the wealth of knowledge from all subscribers to this
forum, what your experiences are regarding these vehicles towing such a load. Thanks in advance.
Reply By: Dunaruna - Friday, Mar 14, 2008 at 20:28
I was a bit surprised to see the towing capacity of the prado was only 2500. With all your gear and sundries, that put you close or even over the limit.
292719
Reply By: Gronk - Saturday, Mar 15, 2008 at 09:22
Heavy load = heavy vehicle = Patrol !!
The bigger the tow capacity of the 4x4, the easier the job of towing will be !!
292785
Follow Up By: Member - David K (VIC) - Saturday, Mar 15, 2008 at 09:54
Hi Gronk,
Thanks for the advice. One thing I should have mentioned in my post is that I want an auto turbo diesel. The Patrol is then limited to 2500kg. Not sure why when the manual turbo is 3200kg.
558333
Follow Up By: StormyKnight - Saturday, Mar 15, 2008 at 10:27
The automatics have a tendancy to overheat with the bigger loads & as such derates the maximum towing weight.
In addition, the braking provided normally by the engine through a manual gearbox is much less thru an auto & so the braking reserve in the vehicle is also reduced.
558339
