HF radio
Submitted: Saturday, Mar 15, 2008 at 13:57
Member - Daryl N (NSW)
Hi All
I'm at a loss. Am trying to work out how I can fit a autotuneing aerial to a new Nissan Navara ST-X. The isn't enough room between the bul bar and bonnet and because of the drop down tail
gate there is no where on the back.
Does anyone have any suggetions
daz
Reply By: Member - Roachie (SA) - Saturday, Mar 15, 2008 at 14:25
Off to one side of the tailgate would be my suggestion. Ocoolone (member on here) has a current model Hilux with canopy and he has a HF auto tune on one side and a sat phone antenna on the other. I think he has a bracket attached to the top of
the tub, sandwiched under the canopy.
292809
Reply By: Hairy (NT) - Saturday, Mar 15, 2008 at 15:20
Gday,
I moved by bullbar forward a couple of inches.
Do you have a wheel carrier on the back?
292815
Follow Up By: Member - Daryl N (NSW) - Saturday, Mar 15, 2008 at 15:58
Thanks. Moving the Bullbar might be my best option. Unfortunately don't have a spare wheel carrier on back
558399
Follow Up By: Hairy (NT) - Saturday, Mar 15, 2008 at 16:36
If you do move your bull bar forward, try to incorperate your aerial bracket into your bull bar mounts so its actualy fixed to a metal bracket (bolted to your chassis) rather than tothe bull barImage Could Not Be FoundImage Could Not Be Found .
558401
Reply By: Member - Daryl N (NSW) - Saturday, Mar 15, 2008 at 15:56
Thanks. Contacteda compay that makes brackets for Hiluxs to hang of the side of the tailgate but they don't do a similar one for Navara's
292818
Reply By: Member -Signman - Saturday, Mar 15, 2008 at 17:19
Single/Dual Cab??
What type of bullbar??
292827
Follow Up By: Member - Daryl N (NSW) - Sunday, Mar 16, 2008 at 09:48
Its a dual cab with a standard Nissan alloy bull bar
558512
Follow Up By: Member -Signman - Sunday, Mar 16, 2008 at 19:26
I don't know where you are?? But I do have a bracket made up (out of 6mm Al. CheckerPlate) ready to go...
Tried & tested on Rodeo ute...
558579
Reply By: Stu & "Bob" - Saturday, Mar 15, 2008 at 18:53
Get a couple of tabs welded to the top pipe of the bar and mount it there. As far as possible to the LHS.
292839
Reply By: Member - Mark E (VIC) - Saturday, Mar 15, 2008 at 23:51
Daz,
Not too sure about the rules in NSW, but here in Vic, it is now illegal to fit Autotunes to the bullbar or anywhere on the front...back mounting is the only option.
I have also seen them mounted in the tray (no good if you have a canopy, though). Just some thoughts, though not helpful, I know.
Mark
292867
Follow Up By: Stu & "Bob" - Sunday, Mar 16, 2008 at 13:42
Nearly all Autotunes are mounted on the bullbar here in QLD.
Could be interesting travelling through Vic in QLD registered car with autotune on the bullbar?
558534
