GMC/Powerbase 800w 2 stroke Generator Fuel Mix
Submitted: Saturday, Mar 15, 2008 at 20:43
ThreadID: 55566 Views:11070 Replies:5 FollowUps:3
I purchased one of these from Bunnings about 4-5 years ago, for $145, ran it once for about and hour, and put it under the bench. Bought it because it was cheap for the farm! (I Have a Honda 2000i also)
I am now selling it along with my old caravan, but cant find the manuals, so am at a loss with the fuel mix.
I started at 25:1 (to be safe), and it smokes significantly when under load. Went to 50:1 and it still smokes to some degree, although not visibly so except in bright light.
I am surprised at how quiet it is thought, and it seems to have a ton of guts, and runs very well under heavy load.
I even tested it with a $89 Microwave from Woollies, and it run that on low and medium power settings along with all the 240v lights in the van, plus a 150w floodlamp.
I'm not sure I would use it on anything "voltage sensitive" though. It does hunt a fair bit under medium load. (around 300w load)
Does anyone know the correct fuel mix. I accept possibly that all 2 strokes will smoke to some degree, but I have been spoilt by the Honda's.
Reply By: Shaker - Saturday, Mar 15, 2008 at 20:45
50:1
AnswerID: 292849
Follow Up By: darrell.QLD - Saturday, Mar 15, 2008 at 21:41
its the SPARK PLUG .been there done that///
FollowupID: 558492
Follow Up By: Shaker - Sunday, Mar 16, 2008 at 09:20
They all seem to "hunt" with a low to medium load, increase the load & they smooth out.
FollowupID: 558511
Follow Up By: Graham & Lynne - Tuesday, Mar 18, 2008 at 22:04
darrell.QLD
What plug do you run in yours?
Thanks Graham
FollowupID: 559097
Reply By: Rock Ape - Sunday, Mar 16, 2008 at 11:18
You will find that with a good load on the genny and a mix of 50:1 the smoking will stop after a short time.
AnswerID: 292891
Reply By: nowimnumberone - Sunday, Mar 16, 2008 at 12:09
isnt the petrol cap also the amount of oil you put in a tank?
AnswerID: 292898
Reply By: Go-N-Grey (WA) - Tuesday, Mar 18, 2008 at 09:51
Thanks, yes 50:1 works much better, the problem was a lot of residual oil in the tank from when I filled it years ago, and the petrol evapourated and the fuel didn't.
I sstill am surprised how smoothy it runs when under load.
AnswerID: 293296
Reply By: inspired - Wednesday, Mar 19, 2008 at 11:29
50:1 is the recommended amount (not just for these GMC's, but most 2-stroke motors).
Each of those segments in the blue container under the cap holds 20 mls, enough oil for 1 litre of petrol.
BUT --- I've just removed the muffler off mine, and emptied out much oil which used to leaked out onto whatever surface the generator sat. I rinsed it out thoroughly.
The spark plug fouls quickly and then needs to be wire brushed clean before the unit starts.
A decent plug might remedy some of these problems.
AnswerID: 293555
