Engel Freezer.
Submitted: Sunday, Mar 16, 2008 at 10:29
Hi,in
Darwin so it is hot.Have a new engel fridge with 32 litres fridge and 25litres freezer ,the most the fridge will pull down to is 2.5c and the freezer -18c ,it does not matter if it is on mains or
battery power,I thought the frig should pull down a lot more.Any advise is it good enough.
Reply By: Member - G N (VIC) - Sunday, Mar 16, 2008 at 10:46
probably is enough.
I am surprised its that good. I parked myine years ago as it was useless in 38C + temp.
The old ones work great as they are on the old gas! According to a fridge mechanic the new ones struggle because they never redesigned the fridge for the new gas and the evaporator or condensor (cant recal which) is too small.
GN
292885
Follow Up By: 2517 - Sunday, Mar 16, 2008 at 12:59
Thank you reply.
558524
Reply By: Jim from Best Off Road - Sunday, Mar 16, 2008 at 11:05
IMHO it is working perfectly.
4 degrees and -18 are the recommended temperatures by various food safety authorities.
Jim.
292888
Follow Up By: 2517 - Sunday, Mar 16, 2008 at 13:00
Thank Jims
558525
Follow Up By: Racey - Monday, Mar 17, 2008 at 21:30
-18 is fine for frozen foods however milk you be store at below 4 deg. Therefore suggest +2 deg for the fresh food
558880
Reply By: oz doc - Sunday, Mar 16, 2008 at 11:12
We have same frig as you. Camped in 45 degrees at
Onslow last long w/end and the fridge went down to -1 when on highest setting. I think you can have problems with efficiency if the freezer is allowed to get iced up a lot. What sort of thermometer are you using to test it with?
292890
Follow Up By: 2517 - Sunday, Mar 16, 2008 at 13:01
Sure is hot in the west,just a engel one.Thank for the reply.
558527
