"Scangauge" heaps of info from your vehicles diagnostic port
Submitted: Monday, Mar 17, 2008 at 22:36
ThreadID: 55650 Views:4049 Replies:7 FollowUps:11
Scanguage2.. A 3 in 1 automotive computer that plugs into your vehicles OBD2 port (on-board diagnostic port).
It basically connects you to your vehicles computer giving you:
a small digital backlit readout sits on your dashboard giving info in real-time.
OBD2 has been around for some years so is probably suitable for 100series V8 and many other vehicles. OBD2 port is on all 2008 vehicles onward. This is apparently how vehicles will be checked in the future to ensure compliance of emissions etc.
Unsure if this OBD2 is applicable to modern diesels, I guess it does as they have similar sensors as petrol vehicles..
TRIP COMPUTER
Max speed
Av speed Maximun coolant temperature
Max RPM
Driving time
Driving distance
Fuel used
Trip fuel economy
Distance to empty
Time to empty
Fuel to empty
DIGITAL GAUGES
Displays 4 digital gauges at one time out of 12 gauges
Fuel economy
Fuel rate
battery voltage
Coolant temp
Intake air temp
Engine speed (RPM)
Vehicle speed (MPH)
Manifold pressure
Engine load
Throttle position
Ignition timing
Open/closed loop
SCAN TOOL
Troubleshooting your error codes
Read trouble codes
Reads the conditions that set the trouble codes
Clears trouble codes
Turns of the "Check Engine" light
Tells you when your vehicle is "Ready" to pass OBD2 testing
Make and stores up to 10 rewritable codes special codes to send to the vehicles computer.
All the info is resettable and is available in real time.
www.scangauge.com
Check it out, i just found it on the net and no affiliation with this product.
regards, Michael
Reply By: Member - John (Vic) - Monday, Mar 17, 2008 at 22:41
"Check it out, i just found it on the net and no affiliation with this product"
Michael as Member you of all people should know to do an archive search first before posting. :-))
Its been done to death in the last few weeks.
AnswerID: 293244
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 17, 2008 at 22:46
HMM I must have missed it completely,, anyway, some others may have missed it also.. I thinks its pretty good, i guess if others know about it already they will ignore.. Michael
FollowupID: 558894
Follow Up By: Member - John (Vic) - Monday, Mar 17, 2008 at 22:50
Yeah maybe, 15 hits come up for "Scangauge" in the search function.
Gone Bush's post was well posted.
Look here GB's Scangauge Post
FollowupID: 558897
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 17, 2008 at 22:52
Gee John.. Im aiming to be perfect but its taking a little longer than i expected.. How long does it take?? Michael
FollowupID: 558899
Follow Up By: Member - John (Vic) - Monday, Mar 17, 2008 at 22:59
As long as it takes to type your subject into the search function.
FollowupID: 558903
Reply By: Michael ( Moss Vale NSW) - Monday, Mar 17, 2008 at 22:43
Forgot to mention A$199 and it works on Petrol, gas, diesel and hybrid vehicles from 1996..Electronic Fuel injected vehicles of course.. Michael
AnswerID: 293246
Follow Up By: Richard W (NSW) - Tuesday, Mar 18, 2008 at 07:36
Michael,
Not the 2005 TD100 1st variant though. :(
FollowupID: 558928
Follow Up By: Member - Mike DID - Tuesday, Mar 18, 2008 at 07:44
" it works on Petrol, gas, diesel and hybrid vehicles from 1996.."
- in America, yes
- in Australia - MAYBE
FollowupID: 558929
Follow Up By: Member - JohnR (Vic)&Kath - Tuesday, Mar 18, 2008 at 08:29
Not on Michael's 4.2 Nissan, not on Landcruisers before the Sep 05 update.
FollowupID: 558932
Follow Up By: Russell [SA] - Tuesday, Mar 18, 2008 at 08:36
Not on Mitsubishi 1999 NL or 2003 Pajeros
Russell
FollowupID: 558934
Follow Up By: hazo - Tuesday, Mar 18, 2008 at 13:01
Not on an 06 Troopy RVTD it does't !
FollowupID: 558968
Follow Up By: zacc - Tuesday, Mar 18, 2008 at 17:59
not on 2001 3.5 pajero
FollowupID: 559031
Reply By: Richard Kovac - Tuesday, Mar 18, 2008 at 00:44
"Im aiming to be perfect but its taking a little longer than i expected"
Michael Hi, now that funny.. LOL
AnswerID: 293263
Reply By: Member - Sam (NSW) - Tuesday, Mar 18, 2008 at 08:03
Not much good for most if any of the patrols either as they still use Nissans own proprietary system, although I believe there is something out there that is similar that does the job for the Patrols. Some fairly useful info on the patrol forum about this.
AnswerID: 293280
Reply By: Michael ( Moss Vale NSW) - Tuesday, Mar 18, 2008 at 09:37
Sorry to everyone that had seen this product before on this site. I must have missed it totally a few weeks ago, my brother who is not into 4x4's, mentioned the site and told me to look it up. I guess as the diagnostics become standard in the next few years, there will be a heap more of this type of fantastic gear on the market.. regards Michael
AnswerID: 293292
Follow Up By: Gramps (NSW) - Tuesday, Mar 18, 2008 at 17:47
Michael,
No need to be sorry. Just remind the mongrels when they post something about tyres, fridges, etc etc hahahahahaha
FollowupID: 559028
Reply By: HGMonaro - Tuesday, Mar 18, 2008 at 10:11
someone (probably Wooders, the local agent) should start a list of known vehicles that they so work in as the US based list isn't reliable.
Works in our 2006 Prado (petrol)
regards, Nige
AnswerID: 293299
Reply By: Mr Fawlty - Tuesday, Mar 18, 2008 at 17:43
For all you lap top affianados I searched EBay and found the following plethora of OBD readers scasnners etc that are USB compartible....
http://search.ebay.com.au/search/search.dll?from=R40&_trksid=m37&satitle=OBD&category0=
AnswerID: 293385
