HF ?
Submitted: Friday, Mar 21, 2008 at 16:45
ThreadID: 55787 Views:4160 Replies:11 FollowUps:34
If you were limited to a single source of emergency communication, what would you choose? HF,satphone or.....? Do you need a particular licence to use HF or will my very old radio licence from my flying days cover me? Who outside of aviation are you listening/talking to?.....any other suggestions?....silverback
Reply By: Member -Signman - Friday, Mar 21, 2008 at 16:52
G'day David..
Guess it depends on what level of emergency..
If it's a Mayday (and the crap has really hit the fan BIG time) I reckon an EPIRB may not be out of the question...
If the co-driver has fallen over & broken a leg- HF with VKS737 facilities would be the go (if necessary could activate RFDS)..
Etc Etc
AnswerID: 293998
Follow Up By: Kev & Darkie - Friday, Mar 21, 2008 at 16:54
Also the $96 a year membership fee is a lot cheaper than ongoing monthly and call costs of a Sat phone.
Cheers Kev
Russell Coight:
FollowupID: 559744
Follow Up By: Member - David P (VIC) - Friday, Mar 21, 2008 at 17:07
We used to call "All station (with acft callsign)....." do you get yr own call sign? Are you able to chat on HF or strict rules as in aviation eg "all stations etc?....silverback
FollowupID: 559746
Follow Up By: The Explorer - Friday, Mar 21, 2008 at 17:17
Read all about VKS737 here
VKS737
FollowupID: 559749
Follow Up By: Member - BIGDOG G (WA) - Friday, Mar 21, 2008 at 17:22
Gday David,
You can chat (choose your channels) but as far as whats best....well youll open a can of worms....you know, holden or falcon, toyo or nissan.
This year we have given away our sat phone and will rely on..UHF, HF and EPIRB.
If you get an HF and join VKS737 your licence is covered with your subscription.
Cheers...............BIGDOG
FollowupID: 559751
Follow Up By: Member - David P (VIC) - Friday, Mar 21, 2008 at 19:22
Thanks all, just wading thru it all. The 95AUD annual subscription covers all, thanks BIGDOG. I used to cancel SAR on the ground at Warracknabeal (W Vic) almost always with Mt Isa ! Melbourne Flight Service didn't seem to monitor HF.....silverback
FollowupID: 559772
Follow Up By: Member - David P (VIC) - Friday, Mar 21, 2008 at 19:30
In our HC do the loggers use CB only?.....silverback
FollowupID: 559775
Follow Up By: Member - Mike DID - Tuesday, Mar 25, 2008 at 13:16
"Also the $96 a year membership fee is a lot cheaper than ongoing monthly and call costs of a Sat phone."
. . . but if you put an existing Telstra SIMcard with International Roaming into a Motorola 9500 or 9505 you have satellite access with ZERO extra monthly costs.
FollowupID: 560483
Follow Up By: Member - David P (VIC) - Tuesday, Mar 25, 2008 at 17:10
I agree with BIGDOG, what a can of worms. I think HF plus EPIRB for me...shall we just leave it at that?.....silverback
FollowupID: 560523
Reply By: Member - Rod N (QLD) - Friday, Mar 21, 2008 at 17:29
The HF Radio Club is another option. Similar to VKS737. See the web site here HF Radio Club
Rod
AnswerID: 294005
Reply By: SoloGirl - Friday, Mar 21, 2008 at 17:30
If it's an emergency situation, costs be damned. I would like to call specific people and have them call me back directly as often as I need. I don't want to have to worry about range or suchlike hiccups.
I read all the posts about the options on the Forum and spoke to all sorts of people, and decided to go with my Iridium satphone.But as has been said, it's very personal and must be whatever works for you.
AnswerID: 294006
Reply By: MEMBER - Darian (SA) - Friday, Mar 21, 2008 at 18:25
See the comms page here for guidance - also, a few years back I wrote a short article on the VKS737 site (to the extent that my experience would permit :-o)....... it may be of use.............http://www.vks737.on.net...... hit the Satphone TAB, rightside........ as others have mentioned here at times, the HF Radio Club has a following too ........ may be worth a look.
AnswerID: 294017
Reply By: Footloose - Friday, Mar 21, 2008 at 18:42
I'd hazard a guess that aviation comms isn't that different to 4wd.
Want to call the wife? Satphone
Want to call aircraft in your vicinity? Radio
Going to crash and burn ? EPIRB. :))))
AnswerID: 294018
Reply By: Mike Harding - Friday, Mar 21, 2008 at 18:57
EPIRB is a final source - the new UHF with in-built GPS will do the job well in life or death situations.
If it's less than perceived life/death then an Amateur Radio is the best bet
Suggest Yaesu FT857D/897D
this will provide the ability to communicate across the whole HF radio spectrum (and more) and in an emergency it's perfectly legal to transmit on any frequency.
Outside an emergency; many people use such sets on VKS737 although, even better, is to obtain an Amateur Radio licence which has been made fairly straightforward with the introduction of the Foundation Licence
Foundation Licence
Mike Harding
AnswerID: 294024
Follow Up By: Footloose - Friday, Mar 21, 2008 at 19:19
"to transmit on any frequency" but unless it's a matter of life and death, NOT legally.
FollowupID: 559771
Follow Up By: Mike Harding - Friday, Mar 21, 2008 at 19:42
/ignore
FollowupID: 559782
Follow Up By: Stu & "Bob" - Friday, Mar 21, 2008 at 19:46
Mike,
The foundation licence is power limited to 10 watts only.
None of the permissable bands cover VKS network, and only a few cover the RFDS.
I think that I will stay with my 100 watt codan, as in an emergency I can tx on any frequency between 2-26.5MHz.
And the RFDS is only a push of the big red emergency selcall button away.
If you connect your GPS to the Codan, your position is sent with the emergency selcall to RFDS.
Each to their own, I guess.
FollowupID: 559783
Follow Up By: Mike Harding - Friday, Mar 21, 2008 at 19:59
In an emergency (which was the thrust of this post) no limits apply - as you have implied above - what are you going on about?
Stu: are you simply being obtuse?
Mike Harding
FollowupID: 559789
Follow Up By: Footloose - Friday, Mar 21, 2008 at 20:11
Stu, don't worry about Mike. He's never tried to pass emergency traffic through 737 on his plastic radio.
FollowupID: 559795
Follow Up By: Member -Signman - Friday, Mar 21, 2008 at 20:13
Hi Mike
I note your recommendations on Amateur HF for emergency situations...
However- when a ' situation' arises- who ya gonna call?? Maybe you have a network of Hams sitting around monitoring your frequencies- just in case !!!
Do the recommended rigs have selcall facilities?
If you just happen to be on a RFDS frequency- do you have Emergency Call facilities???
Not trying to be too obtuse- Yers, Amateur Radio does have a place in travelling/touring-
But I really think that a purpose type rig- with a purpose type network is the way to go..
I have been an Amateur (Full Call or whatever it's called these days) for 27 yrs- but only carry the old box of bolts 8528 when out & about.
The Kenwood 520 stays home...
FollowupID: 559797
Follow Up By: Footloose - Friday, Mar 21, 2008 at 20:22
Signman, don't try and confuse Mike with facts LOL
FollowupID: 559802
Follow Up By: Footloose - Friday, Mar 21, 2008 at 20:35
"Outside an emergency; many people use such sets on VKS737 "....MH doesn't as he's not a 737 member.
And if you can't use them properly and quickly in an emergency, then what's the point? Might as well buy a cheap plastic radio.
FollowupID: 559804
Follow Up By: Mike Harding - Monday, Mar 24, 2008 at 17:08
Hi Signman
>frequencies just in case !!!
Pretty much, yes.
The ethos of Amateur Radio is that of helping one-another and this is constantly demonstrated in the way people give of their time and knowledge to the hobby. After 27 years I'm surprised you are not aware of this!? Frankly I can think of no other community activity which exhibits a similar generosity.
Aside from that there are many daily nets (and I'm not including the Travellers Net) which one could contact - I regularly drop in on an early morning net and one of the members makes phone calls for me if I request. Afternoon nets are frequent and evening ones even more so.
Additionally both my sons hold Amateur licences and I usually set up a sched. with them when I'm away also many of the other Amateurs I know will monitor my 80m and 40m frequencies each day when I'm bush. Frankly I'm spoiled for choice and if I have problems I'd prefer to be in radio contact with one of my sons than a VKS737 operator.
Mike Harding
FollowupID: 560305
Follow Up By: Footloose - Monday, Mar 24, 2008 at 17:15
/ignore
FollowupID: 560308
Follow Up By: Mike Harding - Monday, Mar 24, 2008 at 17:21
I'll be more than happy if you can manage that Jim.
I'll do the same - as I have for some weeks.
Mike Harding
FollowupID: 560311
Follow Up By: Footloose - Monday, Mar 24, 2008 at 17:30
/ignore
FollowupID: 560315
Follow Up By: Member -Signman - Tuesday, Mar 25, 2008 at 08:25
'Morning Jim..
I think I'll take your advise...............& ignore !!!
Cheers & 73s
FollowupID: 560429
Reply By: Stu & "Bob" - Friday, Mar 21, 2008 at 19:28
I use HF. Codan 9323/9350 combo.
Codan 6924 with VKS frequencies as backup
AnswerID: 294029
Reply By: Member - Mark E (VIC) - Friday, Mar 21, 2008 at 20:34
David,
This is my take on the whole HF vs Sat Phone thingy. Take it as you will with all the other replies on this topic.
To start off with, I have had an interest in radio for many years, but as yet, haven't had the time to do the Amateur Radio thing, but I have 20+ years experience with HF comms as a traveller, but none with Sat phone.
The way I see the argument is this: both forms of communication have their advantages and disadvantages an it depends on the type and amount of travelling you plan on doing, as well as your own interests.
Personally, when I travel, I am often alone and have enjoyed listening in to the various 'skeds' in the evening (RFDS, VKS737, Amateur frequencies and travellers Nets, VH2RGC, HF radio club, and whatever else I care to tune into...aircraft, marine, ABC, VOA, BBC, and a host of others). Some HATE the crackling noise of HF in the bush and would prefer to ....sit by the fire drinking beer or sitting in their caravan watching TV or sleeping or cooking.....or whatever else takes your fancy. We all have different interests, likes and dislikes and we tend to travel with people who can cope with each others' idiosyncracies. If someone HATES listening to the HF skeds....don't travel with me.
As has been stated many times on this forum and others, some of the advantages of HF is that, like me, many listen in regularly and may be in a position to help someone in distress, whether it be with a medical emergency or car breakdown and may well be in a position to give advice, bring parts/medications etc with them if they are heading in the same direction or likely to meet up. The HF network is huge and it has a real community feel to it. Most are more than willing to help others and will often go out of their way to do so. This situation will not be available with the sat phone option. My feeling is that they are more convenient to make telephone calls and it is possible to summon assistance with the thing, but you do lose that wide 'community' network of help.
Also, the sat phone is easier to use...just like a normal phone, whilst the HF takes some degree of training and experience to get the best from it. This 'learning curve' is much easier is one is 'interested' in how the thing works and does a little reading on the principles of HF and how the radio waves travel, i terms of finding the right frequency for the right time of the day etc..
Ideally, I would like to have both, as I think it would be the best of both worlds. But for me, given that I can make telephone calls from the HF radio, via numerous providers (albeit with a little more difficulty and slightly less user friendly for the person called) the one option that does it for me is the HF.
I will not get into the debate about amateur rigs versus the commercial rigs, as I have never had an amateur rig, but suffice to say that I have never had a commercial rig let me down in over 20 years use and I have had a number of them over the years of both 'main' brands. Currently I have a Codan 9323 with remote head and front control panel so I have control from either the drivers' seat or at the back of the car so I can hear things with the back door open. The autotune antennas available these days are very reliable, unlike the one of a few years ago, which were a little 'precious' about when they would tune and were more susceptable to noise generated by the vehicle. I also carry a couple of tapped whips (just in case of autotune failure) and a centre-fed broadband dipole for when I'm in one place for a longer time. I do plan to do the amateur licence when time permits and I know that the Codan will do what I want it to do on the amateur bands. It will also allow me to scan several key frequencies for selcall contacts as I often have mates who are also travelling and it's nice to get a call from them occasionally...amateur sets will not perform this function adequately from my knowledge. Also the amateur network, whilst great for information about radio communication does not have the 'travelling' population of the VKS network.
I guess it's over to you........... if you like the idea of radio and can cope with a little training and learning curve. then the HF is the go. If you can't be bothered with fiddling about with radios and want the convenience of dialling a number and talking to someone immediately then get a sat phone (the right one though!!!!)
Mark
AnswerID: 294044
Follow Up By: Member - David P (VIC) - Friday, Mar 21, 2008 at 21:50
Thanks Mark for the missive, I know what you mean by noise/hash, VHF was preferred coms in Vic aviation. I know why Melbourne didn't want to monitor it, it would give you a headache. I got a GPS from Telstat in Seaford I think they specialise in coms so I shall prob go there. ...silverback
FollowupID: 559819
Follow Up By: Member - Mark E (VIC) - Friday, Mar 21, 2008 at 23:22
David,
I live close by to Seaford. MM me if you would like to have a gander at the setup.
Mark
FollowupID: 559840
Follow Up By: Member - David P (VIC) - Friday, Mar 21, 2008 at 23:59
Ta for that Mark, I shall take you up on that. I am RYE based every 2nd week , work up in the smoke the other week, semi retirement you see.....silverbackImage Could Not Be Found
FollowupID: 559851
Follow Up By: Member - David P (VIC) - Saturday, Mar 22, 2008 at 00:03
Mark, did you get my reply incl pic? Still learning how to do this. How do you guys get an active link on the post?.....silverback
FollowupID: 559852
Follow Up By: Member - Mark E (VIC) - Saturday, Mar 22, 2008 at 08:50
Yep, can see the pic. Been up on Blue Rag, but not for a few years Email me on markeaust at bigpond dot com when you want to drop in.
Mark
FollowupID: 559878
Follow Up By: Member - David P (VIC) - Saturday, Mar 22, 2008 at 09:21
Ta, will do
FollowupID: 559880
Reply By: geocacher (djcache) - Friday, Mar 21, 2008 at 22:10
Hi David, (there seem to be an awful lot of us David's on here these days...)
I personally travel with a Codan NGT and an Iridium Satphone (using the International Roaming GSM SIM card method.)
If you told me I could only take one or the other, I'd happily hand you the satphone and travel on HF alone.
The reasons are detailed in many other threads, but the VKS737 network is comprehensive in it's ability to help, and you can selcal a phone link to many emergency services via the bases.
AnswerID: 294061
Follow Up By: Member - David P (VIC) - Friday, Mar 21, 2008 at 23:02
Hi Dave its Dave here, I just got a message about a chain saw, I think he had the wrong Dave, er sorry I am confused. I agree HF is the go for me after I have found the 5G I need to fund a front tooth IMPLANT ! Now lets see I have 28 teeth........
I must have fainted.....silverback
FollowupID: 559835
Follow Up By: geocacher (djcache) - Friday, Mar 21, 2008 at 23:40
I take it your dentist needs the months repayment for a 4wd that doesn't go off road... X5? Lexus?
There's plenty of good 2nd hand HF's around. Keep your eye out. Something will turn up.
FollowupID: 559845
Follow Up By: Member - David P (VIC) - Saturday, Mar 22, 2008 at 00:27
Ta Dave,
are there any compliance issues with 2nd hand . Is there a cut off date with non-comliant older sets?....silverback
FollowupID: 559856
Follow Up By: Footloose - Monday, Mar 24, 2008 at 17:17
No compliance issues at all.
FollowupID: 560309
Follow Up By: Member - David P (VIC) - Monday, Mar 24, 2008 at 17:37
Thanks all for the divisive(?) replies, didn't mean to start an argument (tic).......silverback
FollowupID: 560317
Reply By: Bware (Tweed Valley) - Tuesday, Mar 25, 2008 at 09:48
Hi David,
Just a point for all those actually making this type of decision; if on your travels you spend a lot of time doing non-vehicle based activities like bushwalking, canoeing etc, then perhaps comms that you can carry with you might be the better option? If you've fallen off a ledge while bushwalking and broken your legs then the HF wont be much good to you.
AnswerID: 294557
Follow Up By: Member - Mike DID - Tuesday, Mar 25, 2008 at 16:23
The QMAC HF90 is an Australian portable HF radio that can be easily carried - especially with a LithiumIon battery.
It will provide comms out of very narrow valleys and is used by the volunteer Rescue Association's Bushwalkers Wilderness Rescue Team.
FollowupID: 560514
Follow Up By: Bware (Tweed Valley) - Tuesday, Mar 25, 2008 at 17:31
Well there you go. Another thing learned on ExplorOz. Thanks Mike :-)))
I presume though that most people here when talking about HF are referring to in car units.
I'm off to google the unit you mentioned.
Regards,
Brian
FollowupID: 560532
Reply By: The Landy - Tuesday, Mar 25, 2008 at 12:30
Personally I feel both have a role to play as part of any outback communication stategy and neither should be considered exclusive over the other.
If you can afford it (or value your life?) take both. If the buget doesn't extend that far go HF.
AnswerID: 294585
