Garmin "IQUE 3600"
Submitted: Monday, Mar 24, 2008 at 01:08
ThreadID: 55854 Views:3584 Replies:4 FollowUps:3
Hello, I was just wondering if any of you have had some success in uploading "Tracks and Routes" from your computer to your IQUE 3600. Every time I try this I get a message that the computer is not communicating with the GPS unit. But it will perform the "Hot sink" without any problems, so I am at a loss as how to transfer my intended "route" onto the unit. Would appreciate any help that could steer me in the right direction.
Regards: Phil
Reply By: Skippy In The GU - Monday, Mar 24, 2008 at 07:25
Hi pf11 , There could be a number of reasons, not enough information given. to name a few, Is the icons correct,a route on it's own could have a .gdb or a .mps extension , you are using Mapsource software, are you downloading the tracks/routes to the SD card or main unit?.
It should be possible to create a route using the pda itself.
AnswerID: 294340
Follow Up By: pf11 - Monday, Mar 24, 2008 at 10:19
Sorry for lack of info, yes i'm using Mapsourse but when I go to "transfer" only the map check box is highlighted leaving the the "route" "way points" and "tracks" check boxes unclickable.
This problem occurs when transferring to both unit or Sd card.
FollowupID: 560170
Reply By: Member - Doug T (FNQ) - Monday, Mar 24, 2008 at 09:55
I had an issue transfering waypoints to the PC , Garmin USA directed me to to download a 45.5mb file , issue is now rectified
MapSource software version 6.13.7 as of February 27, 2008
Garmin Link
Hope it works , been having problems with links lately
AnswerID: 294365
Follow Up By: Member - Doug T (FNQ) - Monday, Mar 24, 2008 at 09:57
Changes made from version 2.03 to 3.00:
Added capability to transfer waypoints, routes, and tracks to and from the GPS.
Added capability to edit waypoints and routes both graphically and textually.
Added capability to inspect track data textually.
Added capability to print the map view.
Added Auto Detect capability to automatically find the correct communications port.
Improved serial-port communication code to eliminate occasional problems on Windows 95 machines.
Added 'No Map' option to allow viewing of waypoints, routes, and tracks against a bare background (with reference grid).
Changed startup sequence to allow MapSource to continue running even if the most-recently used CD-ROM is unavailable (turns off 'GPS Map Detail' or goes to 'No Map' as appropriate).
Added 'Undo' function.
Added information boxes that pop up when the user hovers the mouse over a map feature.
Added capability for the user to choose the name of the map set as displayed by the GPS power-on screen.
Added capability to import PCX5 v2.09 files.
Added capability to export documents to tab-delimited text format.
Added continuous-world scrolling to allow a smooth map transition at the anti-meridian.
Added preference settings for Distance/Speed, Heading, Altitude, Position Format, and Map Datum.
Changed toolbars to be docking-type toolbars.
Added capability to choose Region and Zoom scale directly from the View menu (in case the required toolbar is hidden).
Added capability to turn off the status bar.
Space bar no longer aborts a transfer in progress.
Added proximity waypoint support, including red-circle on graphical map.
Moved Find City to the View menu.
Added the following tools: 'Selection,' 'Waypoint,' 'Route,' and 'Distance/Bearing.'
Changed the name of the 'Add/Remove Map' tool to 'Map.'
Added Product Info button on the About Box to allow the user to see the data version of each installed product
FollowupID: 560160
Reply By: Member - Doug T (FNQ) - Monday, Mar 24, 2008 at 10:06
pf11
I'll get around this yet. click the link below and when it opens along the top you will find SUPPORT , place cursor on it and select Updates & Downloads
You'll have to copy and paste this to the address bar
http://www8.garmin.com/support/download_details.jsp?id=209
AnswerID: 294367
Reply By: Member - Duncan W (WA) - Monday, Mar 24, 2008 at 17:48
Doug's Garmin Site Link
Dunc
AnswerID: 294450
Follow Up By: Member - Duncan W (WA) - Monday, Mar 24, 2008 at 17:49
Doug just had a play with your link I had the same problem you had. No Hyperlink just the URL.
Dunc
FollowupID: 560326
